Question about Toshiba Satellite M45-S165 Notebook
Satelite Toshiba M45-S165. WOrked fine, now won't boot
Unplugged batt and pwr, let sit 4 hrs, plug in pwr, LED for AC pwr goes on but when I press the ON button the green lite ring around the AC button does not lite up and the laptop does not boot.... no boot rom code on screen, totally black. No disc drive noise, no fan.
Its dead, Jim.
It is may daughter's and she is in financial difficulty. Hope you can help.
  • almullaney May 19, 2009
    exactly the same here. Although, I left it powered down, battery in, plugged in to charge, overnight and I was able to boot and login this morning. Only 10% battery remaining. I think the battery is bad. I can't find anywhere that states the laptop 'requires' a working battery in order to operate on power adapter only.
  • 674 Answers
To sure the battery problem or bad. try to change another battery for testing only befor you replace at all.. I thing this over charging of the battery. then the battery became damage or bad.. to sure change other battery..
Thanks
Posted on May 27, 2009
My daughters toshiba model PSM43U- won't boot
Hi
There are a lot of reasons,
First of all, try to unplug the battery, hold the power button for 30 seconds,
then plug in the charger.
If the notebook boot, then plugin the battery and try to boot it.
If booted , then N!ce, you've done it.
If not, it seems the battery have problem,
Let's see, try it and tell us your result.
Regards.
Oct 29, 2011 | Toshiba Satellite M45-S165 Notebook
I want to connect my Cassatt Tape Recorder to Toshiba Satellite M45-S165 Laptop and record data by using Audacity Software. Recommend the connection cable
I have never used that programme but expect it uses the sound card as an interface. If it does, the manual will tell you, you will need a Phono lead with 3.5mm jack plug on one end.
Hope that helps.
Dec 30, 2010 | Toshiba Satellite M45-S165 Notebook
Remove password the bios of toshiba m45-s169
To reset the BIOS read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Dec 28, 2010 | Toshiba Satellite M45-S165 Notebook
Format problems
change the boot order in the bios and set the it so the cd is read first
Jun 07, 2010 | Toshiba Satellite M45-S165 Notebook
The laptop is dead.
It does sound like your cmos battery. It is located on your system board. If your confident you can take the laptop apart and get the details from the battery and then goto a pc shop and buy a new one if not take the laptop to the shop and they can replace it for you.
Feb 22, 2010 | Toshiba Satellite M45-S165 Notebook
Toshiba Satellite M45-S165 laptop not turning on at all.
Try taking battery out and powering up, then try resitting memory and then the same for the hardrive,
Let us know
Jan 07, 2010 | Toshiba Satellite M45-S165 Notebook
Toshiba laptop power cable won't charge battery
I had the same problem with my HP laptop some years ago. you have a broken cable/cord and it is the part that is permanently attached with your power pack. If you look at the cord that plugs into your laptop, you can be able to see the faulty part of it. it is usually very flexible or swollen. You can either take it to an electrical technician to change that part of the cord. Your power pack is still ok, but have the technician to check it out first before you change the cord. Else, you may have to get another power pack. below is the full specification of the power pack that is recommended for your laptop.
This Toshiba Global AC Adapter is a 65W external AC adapter designed to work with Satellite 1000, 1005, 1100, 1105, 1200, 3000, 3005, A80, A85, A110, L10, L15, L20, L25, L35, L45-S2416, L45-S4687, M30X, M35X, M40-S312TD, M45-S165, M45-S169, M45-S165X, M45-S169X, M55-S139, M55-S141, M55-S1001, M55-S1391, M55-S1412, M105-S10XX, M115-S10XX; Tecra L2 series portable computers. Get an extra AC adapter to be kept at home, in the office or in your travel case.
Specifications:
* Power: 100-240V/ 50-60Hz Frequency (Universal) input voltage; 19V x 3.42A output voltage
* Dimensions: 4.25" W x 1.34" D x 1.85" H
* Weight: 0.67 lbs
* Power cord included
* Compatible with Satellite 1000, 1005, 1100, 1105, 1200, 3000, 3005, A80, A85, A110, L10, L15, L20, L25, L35, L45-S2416, L45-S4687, M30X, M35X, M40-S312TD, M45-S165, M45-S169, M45-S165X, M45-S169X, M55-S139, M55-S141, M55-S1001, M55-S1391, M55-S1412, M105-S10XX, M115-S10XX; Tecra L2 series portable computers
* One year limited warranty
Note: This AC Adapter is the direct replacement for Toshiba 60W AC Adapter (Mfr. Part#: PA3097U-1ACA) and Toshiba 65W Global AC Adapter (Mfr. Part#: PA3396U-1ACA)
Apr 22, 2009 | Toshiba Satellite M35X-S149 Notebook
Toshiba m45 s165 - installing hard drive
http://www.retrevo.com/s/Toshiba-M45-S165-Laptops-manual/id/614bh526/t/2/
Above is the website for your laptop's manual. It should give reference information for hard drive installation.
Apr 02, 2008 | Toshiba Satellite A60 Notebook
Doesn't turn on at all!
Need some additional information first: -Which, if any LEDs are lighting up when you try to start. -You said you purchased another A/C adaptor, was there a reason you tried that first? -Have you been having any problems with the battery before this happened? -Have you tried removing the battery and tried starting with just the A/C adaptor plugged in? If yes was there any change?
Mar 22, 2007 | Toshiba Satellite M45-S165 Notebook
Toshiba Satellite M45-S165 Notebook Logo
350 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
