Question about Garden
Muffler full of fuel
Echo blower will not start
  • 39 Answers
Stuck float in the carb either rebuild it with a rebuild kit or order a new carb
Posted on May 15, 2009
3 Suggested Answers
  • 5 Answers
SOURCE: Echo Blower dies out when full throttle
Find the fuel air mixture screw located by the carb and turn it so the moter starts to slow down then turn it so the blower runs smoothly this should keep it from dying out
Posted on Nov 23, 2008
slohry
  • 87 Answers
SOURCE: echo blower motor will not rev.full throttle--only about half
Check the insulator block and associated gaskets behind the carb. Sometimes the insulator block crack and reduce the amount of vacuum to the pulse diaphragm.
Posted on Apr 10, 2009
Echo pb 500t. Starts and idles OK. When I advance throttle, why does it die?
Hi Alex:
Odds are pretty good that the screen in the muffler is plugged with carbon. The back pressure will stop it from running.
My suggestion?
Remove the muffler. Clean all the bits in solvent and air blow dry.
Re-assemble and
Ta Da!
Cheers
Feb 01, 2016 | Echo Garden
Blower bogs down and kills at full throttle
Check the following, then clean or replace:
  • Fuel Filter - Located IN the fuel tank
  • Spark Plug
  • Spark Arrestor - at muffler port, creates resistance of exhaust flow, engine then bogs
  • Carburetor - may need a rebuild kit
Then watch this...
and...
Mar 31, 2013 | Echo Pb265l 25.4cc Gas Powered 158 Mph Low...
Blower no powereven on full throttle
if you run it with choke on does it make a difference ? if so your carb,fuel filter or fuel lines are problem, if choke does'nt make a difference then remove your muffler and check your screen for being plugged
Aug 29, 2011 | Echo Gas Blower 204 MPH765 CFM Blower...
Went to start bp251 blower after sitting in shed for a week, pull string was very hard to pull. took off plug a lot of fuel came out of plug hole . also checked muffler screen,was clean. there was quite a...
Take plug out turn blower to where plug hole is down pull starter cord many times until all fuel is out. Clean plug, install, try starting without priming or choking. If no start try priming just until you get fuel to engine. Try starting again. If this works when storing blower leave fuel cap slightly loose in very hot weather until you want to start.
Aug 09, 2017 | ECHO, Inc. PB-251C Handheld Blower
I have a Echo PB-260L Blower. It starts fine then gradually loses power sometimes completely shutting off. I have replaced the fuel filter spark plug air filter and have cleaned the screen.
Check the exhaust port upstream from the muffler and make sure it is not restricted with carbon. Mine was less than half way covered over with carbon. Scraped out carbon, checked muffler and screen(ok), back-blow the fuel line harness including the fuel filter and fuel tank vent and took carb apart and blew out all passages, not replacing anything and now runs fine. Would not rev past high idle before. Be sure gas is FRESH and mixed at 40-50 to 1. Hope this helps.
Jul 14, 2010 | RTO Echo 25.4 Cc Backpack Leaf Blower -...
Stihl blower - full throttle it stalls out. low speed ok. have replaced fuel line, spark plug.
Your carburetor needs cleaned or you need a carb. kit depending on how old the carb. parts are. If you need tips on carb. cleaning, feel free to ask.
Jim
May 30, 2009 | Echo Garden
Nov 22, 2008 | Echo Garden
Garden Logo
157 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
