Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Our Badger garbage disposal is filled with water, won't empty out, just keeps running and spinning water around in the sink. We've tried the reset button, unplugging and plugging back in and a plunger. Any other ideas. Thanks so much.
  • 35 Answers
Sounds like the unit is fine but I think you have a plugged drain.Put an empty bucket under the trap and take it apart.Next remove the tailpiece from the disposal and clean it out.If everything is clean and you can't find the clog you will need a drain snake to remove the clog in the drain pipe.Good luck.
Posted on May 12, 2009
2 Suggested Answers
  • 5603 Answers
SOURCE: badger 5 garbage disposer does not grind
Some say to put a load of ice cubes in and run it.
Posted on Dec 30, 2009
Is there a reset button on badger 15ss?
Usually the reset button is located on bottom of disposal near where wire is connected..
Use your hair mirror to look at bottom of disposal.
More disposal resources for troubleshoot, maintenance, repair and installation:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Gene
Water Heater Timers Save Money
Feb 25, 2015 | In-Sink-Erator InSinkErator Badger 3/4-HP...
I have a brand new garbage disposer and was surprised that it was so quiet. I've been in homes with a disposer and they are noisy and the water and scraps get sucked down the drain quickly, but m
You're complaining that the garbage disposal is working quietly?
Most folks complain the opposite.
Look down opening and see if blade is spinning rapidly.
Check that disposal eats lettuce leaves and carrots.
Otherwise you have good disposal.
Nov 21, 2012 | Badger 5 All Insinkerator 76037h 1/2 Hp...
Insinkerator 100ss sounds like it is running but does not empty the food completely out, thus causing stink! Please help.
run water while unit is on
add ice cubes with water running and unit on
until all food particles are gone
ice and lemon for a pleasant sent
Sep 15, 2012 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
MY BADGER INSINKERATOR XP IS NOT SPINNING AND THE RESET BUTTON IS NOT RESETTING. WHAT WRONG.
It sounds like the garbage disposal has a fatal short, and the reset won't push in because there is an electrical failure inside the unit.
Nov 03, 2010 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
I have insink badger 5 and it is leaking from the red reset button. How can I fix?
The reset button is where the water is coming out, but the leak is probably somewhere above that.
The disposal may be rusted out and needs to be replaced.
There are ways to check for source of the leak.
Turn off switch before touching any wet electrical appliance.
Test1) Put stopper in disposal.
Fill sink with water.
If water starts dripping from disposal, then the putty seal at the sink strainer could be leaking.
Use dry tissue up at top of disposal to see if tissue gets wet.
To repair, remove garbage disposal and reset strainer using plumber's putty.
Test2)
Check if water only leaks when dishwasher runs.
Dishwasher drains into garbage disposal.
Use dry tissue around dishwasher connection when you hear dishwasher draining
Test3)
A lot of leaks start at the tailpiece.
This is where the disposal drains into the tubular pipes.
Your disposal may have a manufactured tailpiece that doesn't come off
If tailpiece is removable, then it is connected to disposal with a rubber washer.
When washer gets old, it doesn't seal perfectly.
Remove tailpiece, it usually has 2 hex bolts.
When putting the tailpiece back, you need to seal the rubber washer really well.
I use rectorseal on all tubular pipe joints under the sink.
Works on both plastic and rubber washers.
Brush it all over the washer, use plenty, then reinstall tailpiece.
The rectorseal assures that joint will not leak.
If the above repairs don't work, then the disposal is rusted-out and needs to be replaced.
Oct 26, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Here is an interesting problem. We have a Badger 5 1/2 Hp Garbage disposal hooked up on left side of double sink. The Disposer runs, spins, but will NOT drain.. at all. Left sink with the insinkerator will...
If this connects into a tee between the sinks, usually if the tee is in the middle of sinks, then often there is a divider in the tee to keep water from backing up the other drain. Remove the tee and inspect to be sure it isn't cloggged. Also put a bucket under the outlet. Try running it this way, if you get good flow you know the disposal is working
Aug 18, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Insinkerator badger 5 runs sink wont drain
Properly piped, your arrangment should look similar to this picture so that there is a separate trap for the disposal and the other sink basin.
Mar 05, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Garbage disposal doesn't empty
To me it sounds like the waste pipe is clogged
Try a plunger
Kurt
Mar 19, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
707 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Craig Butler
Craig Butler
Mike
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
