Sound but no picture
I have a Toshiba projection TV model#43A61. I power it on and I can hear sound but there is no picture(black screen). I am not even able to see menu. Any solutions?
ctf1800
  • 4402 Answers
SOURCE: Toshiba 43A61 - No Picture, no sound
If your set all of a sudden won't come on, e.g., the screen is blank, but the LED on the under the screen next to the on/off switch keeps flashing, then there may be an internal fault on the set that needs to be reset.
To force the reset, try this:
  • Unplug the set and wait a few seconds
  • Replug and see if the video returns
Whenever the set senses an internal fault through its monitoring circuitry, it essentially shuts down the set. The flashing LED provides the indication that a fault has been detected. Removing power to the set resets the monitoring circuitry. When plugged back in, the circuitry again does a check of the system. If it finds that there truly is a problem, then the set is shut down and the LED will again flash. In this case, you need to call a service tech. Most of the time, however, the unplug/replug routine is enough to get the set up and running.
Posted on Dec 11, 2007
  • 579 Answers
SOURCE: Philips 46PP9302 46 in. Rear projection -
The power supply section is not working.
Common possibilities are:
- Convergences amps have failed overloading the supply
- High-voltage section (flyback transformer) has failed
(happens sooner or later, about 8 years typical))
- CRT tube has failed overloading the supply
- Power surge has popped the power input circuit.
(Fuse, rectifier diodes, turn-on relay etc)
- One of a hundred of electrolytic capacitors has failed short overloading the supply. They dry out with age, are cheap to replace, but hard to find which one it is.
- Or any of many other possibilities.
In short, you need a experianced tech to troubleshoot this.
Posted on Jan 22, 2008
  • 2920 Answers
SOURCE: RCA Projection screen tv, model #D61W20B
your cameras may have gone bad
Posted on Sep 03, 2008
  • 7 Answers
SOURCE: TOSHIBA TV NO SOUND NO PICTURE, POWER LIGHT IS ON
the lamp in the projector might have went. try replaceing it. to do so try
ADTECH SYSTEMS they may help
there in mass.
call David Crepeau at 978 261 1087 tell him Ryan Bolduk sent you
depending where you live. They maybe able to send someone out from there sub company
Posted on Sep 18, 2008
Sparko1
  • 167 Answers
SOURCE: 52 inch Toshiba rear projection no picture has sound
You have bad solder connections in the deflection circuit. Call a good TV tech unless you know what you are doing. You could get an electrical shock from a charged capacitor.
Posted on Jul 29, 2009
My toshiba tv has no sound,what is causing it to malfunction
I have a Toshiba 52HM95 the red light and the green light keep coming on but I get no picture but I can hear the sound very good what could it be please help
Jan 13, 2013 | Toshiba TheaterWide 52HM84 52" Rear...
Toshiba no picture
then your optical section has fault.
Mar 17, 2008 | Toshiba 61A61 61" Rear Projection...
This could be a problem in the vertical sweep circuit, as when the vertical circuit fails, The video or screen will blank out so the picture tubes do not get damaged. In this chassis, I have seen the convergence IC's cause this, or the capacitor in the sweep power supply that feeds the voltage to the vertical IC has failed and blew out the vertical output IC. If you have no solid state repair experience, play it safe and call in a trained tech to assist you in this repair. Good Luck.
Aug 11, 2007 | Toshiba 43AX60 43" Rear Projection...
How do you tune in the toshiba quadryl tv. you can hear the sound perfectly but cannot get a picture. just horizontal line across black screen .
hello may i know the complete model of your TV, and a short description of it ex LCD, PLASMA,DLP etc.please post back.
Apr 28, 2011 | Toshiba Televison & Video
Hitachi tv no picture or sound.
my hitachi projection tv 53uwx10b screen is black with no sound or picture when the power button is on
Dec 29, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Samsung projection 42 in. floor model, powers on
tv is in shutdown, drawing to much current. usually focus or high voltage divider (sometimes they are one). not usually the power supply.
Jul 05, 2009 | Samsung Televison & Video
there in mass.
Sep 18, 2008 | Toshiba 42H81 42" Rear Projection...
Have power but no sound or picture
Goto www.magnavoxhelp.com. They have a kit that will fix this common problem.
Jul 02, 2008 | Philips 50P8341 50" Rear Projection...
Dec 11, 2007 | Toshiba 43A61 43" Rear Projection...
Televison & Video Logo
87 people viewed this question
Top Televison & Video Experts
Electro Med Services...
