Question about Philips Audio Players & Recorders
I washed it .. now it wont turn on
I ACCIDENTALLY WASHED THE PLAYER AND DRYED OUT THE BACK... HELP
Put it in a bag of rice for a day with batteries and battery back off if applicable
Posted on May 11, 2009
How can i fix my zune hd when its been washed?
my zune was washed in the washer and i was wondering how do i get it back to working?
Aug 04, 2012 | Microsoft Zune HD MP3 Player
I lost my instruction manuel and i dont know how to put oil in the airfilter
pop air filter of.Carefull not to let anything get down into engine. Remove sponge. If theres 2 sponges then you need to coat the inner sponge. pour a little onto sponge and squeeze so it gets into all the holes. give it the sponge a good last squeeze holding over jar to get rid of excess as this will prevent air from entering engine. Fit air filter back on. Good idea to have a few spare so when one is used others can be washed and dryed. Either wash in wasing up liquid and dryed or nitro fuel and dryed.Hope this helps.
Aug 06, 2010 | Tornado 110 Nitro 4wd 2 Spd Off Road S30...
I just washed the electrostatic grid and didnt have it thougholy dryed before inserting it back into the unit. Now I cant get the power light to turn on
As long as you have the cells in the correct direction, the air flow direction you should be O.K. If you have a way of turning on a constant fan that will help dry them. I would shut the power button off to the electric air cleaner and run a constant fan for 24 hours. After that, turn the power on and the constant fan off. Turn up the heat and see if it works.
Nov 24, 2009 | Air Purifiers
My 1991 toyota camry wont start after I washed the engine. I've dried the distributor but it still wont start.
give every thing a good spray with WD40 that may help start her up,, its a bad idear to use a high presher water hose for cleaning your engine up,,
you just found out way that is! she will go again after she has dryed off again,,
Nov 02, 2009 | 1991 Toyota Camry
WASHED CLOTHES - FOUND LG LOTUS IN BACK POCKET OF JEANS. HELP. fyi-cold wash only
i had it before with my phone and after it dryed out the inside it started working so you gotta give it a day atleest till it drys
Oct 19, 2009 | LG Lotus Cell Phone
My mp4 has a few critical difficulties.
this means the hard ware isn't meant to be washed and is broken so the best course of action would be to buy a new mp4 player
Aug 30, 2009 | SanDisk Sansa E280 MP3 Player
Odor in clothes
run an empty load in the washer but add 3 cups of vinager and set the washer to hat wash, this will help kill the smell, After you get done running it leave the door open this will stop it from happening again
Jul 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washed bike - now no power
does it crank? Or just run badly?
Apr 20, 2009 | 2007 Yamaha V Star 1100 Silverado
Washed
You have to try in powering it up.
Unfortunately, when such kind ofelectronics are washed, the only solution i to open it immediately, clean all the water and moisture residues, dried it, and then charge the battery again and test it.
When time passes (say 2-3 months) after being washed, there is corrosion and moisture in the electronic components and internal connecttions, and the device is permanently damaged.
Best regards,
Jan 06, 2009 | RCA Lyra RD2765 MP3 Player
24 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
