According with the factory manual...
23 - Body/Door - Front/PANEL, Door Trim/Description
DESCRIPTION
Door trim modules include the hardware, window regulators, latch, remote handle and links, speakers and wiring harness. In addition to providing manufacturing efficiencies, the door modules benefit the customer too. Having all the parts assembled into a module improves build accuracy and fit and finish between the components and trim as a result of greater communication between the release engineers and suppliers.
Lower door trim (from the beltline down) is molded polypropylene. The door trim is two-tone with a darker color matching the instrument panel in the upper third and a lighter shade for the lower two-thirds, including the bolster and substrate.
2. Remove speaker (5),
3. Remove the trim screws (4) from the speaker opening.
4. Remove the trim cap (6) and the screw (1) at the inside handle.
5. Using a trim stick C-4755 or equivalent, remove the outside mirror trim (2).
6. Remove the door glass
7. Disconnect the latch linkages (1 and 2).
8. Remove the latch screws (4).
9. Disconnect main harness connector.
10. Remove screws and separate harness from door
11. Remove three upper bolts (1).
12. Lift the module (1) up off of the four trim hooks (3) and the lower regulator screws (4).
13. Pull the front of the trim module (1) out from the door and forward to remove the latch.
Check attached images.
Hope helps.
