Hughes remote will not change channels on TV
Hughes remote control will not change channels on TV. What is the problem?
    Problem Solver:
  • 4 Answers
Just a thought. Check to see if you have a TV/VCR button and make sure it is on the right one you want to use.
Posted on May 11, 2009
I have an Orion 19"
You usually need the original remote. The trouble with universal remotes is that they generally control only the basic functions of a TV (power, volume, channel) but not much else. Without the original, you often lose other functions. You can try the front panel buttons if yours has them. On some sets the on-screen menus allow you to access caption settings.
But are you sure the captions are coming from the TV? Sure, the TV is displaying them, but if you have a satellite receiver, cable box or digital set-top box, the captions may be coming from that device. This is likely to be true if the captions just mysteriously started and you don't have or aren't using the TV original remote. These devices often don't allow a TV's built-in caption decoder to work properly, so they provide captions themselves. You may have turned captions on using that device's remote. Check the menu for caption controls.
Jul 10, 2011 | Orion1934 19" TV
The tv is stuck on a game channel and none of the buttons work such as the channel page, menu, select, guide, etc. I have replaced the batteries
Good day!
may I know if your remote is original or universal remote.
If your remote is universal you have set-up the remote code.Because universal remote is need to set-up every time it loose the battery or power.
If your remote is original and the battery is new.You have to do is replaced the IR sensor of your remote.
Thank you
May 28, 2011 | Hughes HRMC9 Remote Control
NEED TO PROGRAM MY RCA TV WITH A HUGHES HRMC-13 REMOTE
Hello
Codes for RCA tv with Hughes remote are:
160 161 156 165 065 070 004 023 024
056 074 081 152 167 145
Code Entry
Use the REMOTE pane under the System Setup menu tab to program your
HRMC-11, HRMC-12, or HRMC-13 remote control to operate your TV, VCR,
SAT, AUX device, or DVD (HRMC-11 and HRMC-12 only). The AUX menu
button can be used to control a CATV box or other type of device. Use the menu
buttons to choose the desired type of device and display a brand name menu list
from which you can select the manufacturer of your device.
Code scanning
To use the Code Scanning method:
1. Repeatedly tap the top part of the CHANNEL (CH) button.
2. Continue to step through the codes until the component turns off, indicating
you have found the correct component code. If you accidentally pass a code
that responds or realize you may not have been aiming the remote control at
the component, tap the lower part of the CHANNEL (CH) button to step
backward through the codes.
3. Press the remote control POWER button to verify the proper code by
turning the device on and off.
4. Press the device button (in this example, TV) again to lock in the code.
OK
Feb 20, 2011 | Televison & Video
Have HRMC-15 remote ned the codes for sanyo tv
Sanyo tv codes for use with the HRMC-15 are 007 020 053 057 082. Also, you can do a search on the computer and download the Hughes owners manual.
Jan 15, 2010 | Hughes HRMC11 Remote Control
Lost the Hughes manual. I need the code settings for the remote
Here are two links for the manual you are in need of:
http://www.directv.com/learn/pdf/System_Manuals/Hughes/HNS_SD_HBH.pdf
http://www.solidsignal.com/manuals/HRMC-11_HRMC-12_Owners_Manual.pdf
Either of theses should get you to the correct manual and should have the code you need.
Feb 27, 2009 | Hughes HRMC11 Remote Control
I have a hughes hrmc-11 remote control and i have a proscan flat screen tv i was wondering if there is a code so i can use the hughes remote to ctrol my tv
auto code search.
hold down the tv button and mute button until the tv button light stays on. press the channel up button(this will cycle thru codes) test with the power button. process may take a few minutes. when the tv turns of press the tv button to store code
Jan 02, 2009 | Hughes HRMC11 Remote Control
How to program remote for tv and codes
dont have codes for programing HRMC-5 (11), I HAVE A SYMPHONIC tv
Please help
Instructions start on page 49 of the PDF file and have step by step instructions for your remote programming
Dec 24, 2007 | Hughes HRMC11 Remote Control
Hughes Remote works the satellite but not the TV
You have to push and hold down TV and Mute button (for 2 seconds at the same time), then release them at the same time, then push channel up until the TV turns off.  Be patient and continue channel up until the TV turns off.  When it turns off, then push TV again to lock the code.
You were doing fine, but missed to push channel up to fine the code.
Oct 25, 2007 | Hughes HRMC11 Remote Control
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
Electro Med Services...
