Question about Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive
Oops I plugged my 3200 into the the wrong power supply. now the light just flashes. can I replace the internal power supply. how do I get one.
    Novelist:
    Champion:
  • 382 Answers
You have fried the enclosure. Replacing it or the dc in is not an option. Ideally , you need to extract the drive and hope the surge did not make it past the bridge board. I would seek out a more sturdy enclosure, preferably aluminum for hear dissapation. Try mounting the drive internally in a desktop and finding out is condition before spending money on a new enclosure.
Usually you can smell the drive for any hint of "electrical burn" once its been extracted, or trace the extent of the damage in the enclosure.
Posted on Oct 22, 2007
My dell latitude d630 will power on when I push the button, but nothing happens. The screen illuminates a bit and that's it. What can be the problem?
what happens when you try to connect to an external monitor? you may have a bad back light power inverter. how old are your batteries? in some cases if the batter pack isn't holding a charge then it may put a load on the power supply.
if you connect an external monitor and it stays on then it is a bad back light inverter. if it does the same thing then you may have a power supply problem. i forgot to ask if the laptop has been dropped or fell off a table, chair, bed, or desk? how is the power plug that plugs into the laptop? you also may have bad power jack!
3 things that may be bad or defective:
1) power jack
2) inverter board (i'm thinking this your problem)
3) batteries or internal power supply
items 1 and 2 can be fixed, but if it is a battery(s) or bad internal power supply. replacement batteries are about $50 and up, replacement laptop mother board it may be cheaper to buy a new/used laptop. however, you would want to save your data on this laptop if you can or someone do it for you.
i have worked on Dell computers for 10 + years out of my own repair and custom shop.
oops almost forgot with the new hd tv's there is a "PC Input" on the back where you can connect your computer or laptop to!! so if the lcd screen doesn't work and you cannot afford a replacement back light inverter board($120) then spend $15 or less for a male plug to connect your laptop to your lcd hdtv .
but doing this you will loose portability unless replace the inverter board!
Aug 22, 2011 | Dell Latitude D630 Notebook
Tv will not turn on. no sound or picture
Tv have no LED power light indication at all or it is flashing?The tv power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jan 30, 2011 | iLO 3200 32 in. LCD Television
The power supply light comes on,but when i plug it the light goes out.how do i fix this problem .ty
when the green light on the power supply goes off or starts flashing when you plug it into the LaCie drive, there is a failure at the level of the internal electronic components. Either only on the interface, or on both the interface and one/both of the hard drive.
Usually, replacing the interface would solve this, but before doing so make sure that the internal hard drives electronic boards do not have any failure else they will cook your new interface. It is advised to consult someone skilled in electronics to inspect the internal components.
Regards,
Dec 31, 2010 | LaCie Big Disk 500 GB Hard Drive
Blue light flashes 4 times but no power
U know basic electronics,have tools and know basic soldering?Take the tv aparts,the power supply,that board where the a/c power cord plug into it.That the power supply board,searches the power supply board, for those dying about to be dead,capacitors alway bulges up on it tops or puff up on it tops.Replaced these dying and about to be dead capacitors,the tv power will up again and work.Or tries websites like Shopjimmy.com,Ebay,com to buy a refurbish power supply board for the replacement.
Jul 14, 2010 | Samsung SP-S4243 Television
ILO 32" TV (4 yrs old) seems to have no power. The power light is out (not green or red). We have checked the power chord, etc and that's not the problem..
the problem goes beyond chords. most lightly its the internal power supply that failed, this part is build in such a way that its to much to repair. solution is to replace power supply
Apr 27, 2010 | iLO 3200 32 in. LCD Television
Maxtor personal storage 3200 - flashing green light.
Solution:
First, disconnect the power cable from the back of the external hard drive:
If the power supply LED continues to blink:
  1. Connect the power supply to a different outlet (or instead of connecting to a power strip, connect directly to an outlet in the wall).
  2. If the power supply continues to blink after changing outlets, this indicates that the power supply is defective and needs to be replaced.
  3. If the power supply stays solid, then reconnect to the external hard drive and see if the drive spins.
Jul 01, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Wrong power supply used with a maxtor external hard drive
You could buy another drive with the same specs and replace the circut underneath the drive with the circut from the new drive, then try it in your new enclosure
Jun 30, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
My Maxtor 3200
what was the voltage difference between the supplied adaptor and the one you plugged in by mistake ?
Robert
Dec 17, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
F-17 neovo monitor stopped working. power light is flashing yellow
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1 The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours, sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr suddenly are a blown capacitor on power board, the inverter board powering up backlight lamp has blown, or a fault on main lcd controller board.
check also the video cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Check connectors, try moving the video cable, and if the cable is not built in, then also try a replacement cable.
Regards
Jan 03, 2008 | Neovo AG 17" LCD Monitor
Maxtor 3200 power supply problem
I plugged a HP laptop charger into the drive and all it did was flash, bought a new housing and no luck. Data recovery sites said that it sounded like hardware trouble and the recovery minimum is $800. I did some more searching and found a site called PCB Solutions that sells the circuit board. You have to provide all of the specs. for the drive. The cost was $39 and I received it in 4 days. I replaced the board and the drive worked and I recovered all of my data. The URL is:
http://www.onepcbsolution.com
Nov 09, 2007 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive Logo
87 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
