You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Go to http://education.ti.com/downloads/guidebooks/graphing/84p/TI84Plus_guidebook_EN.pdf
to download the manual. On page 401, you will find the following:
INVALID DIM
• The ERR:INVALID DIM error message may occur if
you are trying to graph a function that does not involve
the stat plot features. The error can be corrected by
turning off the stat plots. To turn the stat plots off,
press y , and then select 4:PlotsOff.
• You specified a list dimension as something other
than an integer between 1 and 999.
• You specified a matrix dimension as something other
than an integer between 1 and 99.
• You attempted to invert a matrix that is not square.
Hello, The easiest and quickest way to start graphing is to reset the RAM. Press [2nd][MEM][7:Reset][1:All Ram][2:Reset], then [CLEAR] to clear the RAM Cleared Message and go to the main screen. Hope it helps.
Clear the old contents of variables .
Press [2nd][MEM][2:Mem Mngt/Del][6:Y-Vars][ENTER]. The graph functions that have been defined are listed on screen. Scroll to select the one you want to use and press [DEL].
There is amore radical way to clear the memory:
Press [2nd][MEM][7:Reset] [1:All RAM][2:Reset][ENTER].
Hope it helps.
This error show up when you are graphing out of the plot menu. If you are not graphing data points from list menu, you need to turn the plots off. In the y= screen, you will see the words plot 1, plot 2, etc across the top of the screen. If one of the plots is highlighted (black box over the words), you need to turn it off. This can be done by arrowing up and highlighting the box and pressing enter. When you arrow back down, the plot should be off and you will be able to enter an equation in the y= lines and graph.
If you are graphing from the plot menu, this error lets you know that one of the lists you are graphing is longer than the other.
Another way to fix the problem is to reset the calculator by pressing 2nd button then plus sign then 7 then 1 then 2. This will reset the calculator however if you are graphing from lists, your data will be erased. Hope this helps.
Just passing by, make sure you aren't zoomed in or panned away from the axis when you look.
Check to see if there is some way you could be referencing a matrix. I can pull up a similar error by trying to pull a value out of a non-existant slot.
I got my first TI 2 days ago, so I probably don't know as much as you.
