Question about Refrigerators
Clicking noise coming from area in lower right corner (when pulled out and standing behind it - located behind freezer) of whirlpool refrigerator freezer.
  • 286 Answers
Clicking noise could be the compressor trying to start. Make sure fan is running if it is you will need a tech to test the compressor
Posted on May 19, 2009
Freezer not freezing clicking noises
Almost certainty you have a rear control board fault these boards where notorious for capacitor faults causing relays to click and water dispenser to be erratic , the board can be repaired by a confident electrical engineer or you can buy a complete unit
Mar 31, 2017 | Whirlpool Refrigerators
Every 20 minutes, my freezer would make a crackling like noise. What does this mean and how can I fix this?
Refrigerators are not the most complicated appliance in the house, but it still takes a lot of parts working together perfectly to keep your food cold. If one of those parts breaks down, or begins to, you may start to hear new noises from your refrigerator. Fridges make some noise during regular operation, but if it suddenly gets louder or makes a different noise, it is a good sign that something is wrong.
Freezer Fan
Freezers can be located on either side of the refrigerator, or may be at the top or the bottom of the unit. If you hear a noise coming from the area in which the freezer is located, you should open the freezer and see if the noise gets louder. Any squealing sounds coming from this area indicate a broken freezer fan. These units are not designed to be repaired, and eventually one making a loud noise will break and need replacement.
Condenser Fan
All motors typically require a fan in order to maintain a safe operating temperature. Like the fan in the freezer, the fan that runs on the condenser can also break down and create a similar squealing noise. The location of the fan noise is what differentiates the freezer and condenser fan problems. If you hear a fan noise coming from the lower part of the fridge at the rear, it is likely the condenser fan causing the problem.
Action to do
Open the freezer to see if the noise gets louder. If the noise becomes louder with the freezer open, the noise is likely caused by the evaporator fan. If the evaporator fan is the culprit, replace it to get rid of the noise.
Pull the refrigerator away from the wall, and check the condenser fan at the back of the fridge. A metal panel may cover the fan, which can be unscrewed. Listen to see if the fan is the source of the noise. If it is, the fan may need to be cleaned or replaced.
Thanks for using FixYa.
Good day ! : )
Sep 07, 2011 | Refrigerators
Hello I have a GE lower freezer model # PDS22SBSARSS AND THE TEMP CONTROL is clicking and the digital readout is doing weird things by indicating wrong temperature and clicking, it stops after awhile...
Roll the refrig out and determine where the clicking noise is comming from. If it is form the small rectangular cover on back, replace the main board (WR55X10942) located under it. If the clicking is comming from the compressor area (at the very bottom, behind the cover which goes all the way across the bottom of the refrig) then replace the relay (WR07X10086) and overload (WR08X10061) located where the wires attach to the compressor, and for good measure, the capacitor (WR62X79 ). (located just to the left of the compressor)
Jan 12, 2011 | GE Profile PDS22MHR Bottom Freezer...
I have a jenn air side by side and water seems to be leaking near the front left corner area at random times and when it does leak it is a slow drip.... thoughts?
Look in the freezer floor to see if you have ice built up and over flowing into the floor. If so you have a clogged drain line which is located in the freezer behind the lower basket in the litttle gap at the bottom of the back wall. If you don't have that, the water line that runs to the water in the door is located at the front left side as well and you can get to that by pulling off the bottom piece of plastic that runs along the bottom of the whole machine.
Oct 31, 2010 | Jenn-Air JCD2389G Side by Side...
Click noise in freezer, freezer not cold, ice maker not working and water not dispensing
replace the mother board in the rear area behind the unit in the lower rear area behind a panel with 3 screws securing the cover,this board controls all operations of the freezer
Jul 28, 2010 | GE GSS25LGM Side by Side Refrigerator
Kenmore refrigerator 253.57192600 making clicking noise
It could be as simple as a bit of expansion and contraction of the wall panels or the damper which allows cooling to flow from the freezer to the fridge side.
Mar 08, 2009 | Refrigerators
Freezer drain plug
Self defrosting refrigerators as well as freezers all have a defrost drain system. This drain system can become plugged or frozen causing defrost drain water to back up into the refrigerator or freezer compartment. The water may gather under the crisper drawers on top freezer models. On side by side, bottom or stand alone freezers ice will build up in the freezer at the bottom and eventually leak out the door.
Plugged Defrost Drain - Freezer on Top (Water under the crisper drawers)
At the top of the refrigerator next to the temperature controls there usually is a cup-like part that carries the defrost drain water into a tube and out the back of the refrigerator to a defrost drain pan behind the unit. Pull the cup out of the tube and clean the cup with hot water and soap. If there is no cup, pull the refrigerator out away from the wall, go behind it and disconnect the drain tube to clear it. If the drain tube is not accessible from the back or the drain can not be cleared from there the main back panel in the freezer can be removed to access, thaw and flush out the drain under the cooling coil.
Use a turkey baster to flush HOT water into the tube to clear any obstruction. The water squirted into the tube should end up in the defrost drain pan.
If the tube will not clear with hot water try blowing it out with compressed air.
Put the cup back on and make sure it is all the way on or in the tube.
Plugged Defrost Drain - Side By Side, Bottom-Freezer Refrigerator or Stand Alone Freezer
The defrost drain pan is located at the bottom of the freezer compartment behind the back wall of the freezer. On some models, the pan is accessible without removing the back panel and others are not. After you get to the defrost drain pan use a hair dryer to melt the ice from the pan.
Once the ice is removed use a turkey baster to squirt HOT water into the drain hole to clear the drain.
When the drain is clear you should hear or see the water you are squirting into the hole enter the pan under or behind the refrigerator.
TheRepairGuru ---- www.repairclinic.com
http://www.repairclinic.com/Whirlpool-Refrigerator-Parts
Jan 26, 2009 | Whirlpool ET9FTKXK Top Freezer...
Panel between fridge and freezer very hot and no sound at all
Dont know about the noise prob. but I can help with the over heating cabinet. Your condensing coil is dirty and needs cleaned. it is located under your refrigerator or behind the back panel. You should use a brush and vac. it out. Air must travel through the tubing freely in order to cool properly. It should be easy to find following the tubes coming out of your compressor.
Dec 29, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore Side by Side Refridgerator
it sounds like the compressor is short cycling,is it working at all?mike
Nov 03, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
189 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
