Computers & Internet Logo
Katah Joseph Posted on Dec 04, 2013
Can the Dell D410 laptop computer run Windows 8 OS?
Blake Hershberger
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Dec 04, 2013
Blake Hershberger
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
72
Points
11
Yes, it most likely can. It would be good to check for drivers for all hardware items before upgrading though and save them (or the Win7/xp version) somewhere else (usb/cd) before upgrading.
1 Related Answer
gracebie
  • 317 Answers
  • Posted on Jun 27, 2013
SOURCE: dell windows 8 laptops
The BAD_SYSTEM_CONFIG_INFO ERROR occurs when your system is corrupt
so restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.and select "last known good configuration" in the boot options.
If this didn't resolve your error then simple get the Reginout to fix all the registry issues and errors which causing this annoying message
2helpful
3answers
Bios Lock with this error code 55LXQF1-595B
sir
remove CMOS battery then shoting two cmos connection
Where can i find the process to change a D410 inverter
If the screen on your laptop is dimming or not working at all, the fault may lie in the Dell Latitude D410 Inverter --the device that powers the screen's backlight. Replacing an Dell Latitude D410 LCD inverter will require some finesse, but you do not need a technical background. If you are comfortable with opening up your laptop, then this is a do-it-yourself project.
1. Unplug your laptop and remove the battery pack.
2. Locate the rubber screw covers around your laptop screen. There are typically four, but some models may have more.
3. Remove the screw covers. Take care not to lose any. They pop off and, if you are not careful, could go flying.
4. Place your fingers between the front bezel (the plastic piece around the LCD screen) and the screen. Gently work your way around the screen to remove the front bezel and expose the screen assembly.
5. Remove the inverter from the screen assembly. It is held on by tape in most models. In some models the Dell Latitude D410 Inverter may be right at the bottom of the screen assembly, below the actual LCD. Other models have the Dell Latitude D410 LCD inverter behind the screen. To disassemble the screen, you will need to either unscrew the screen from its metal holder, or just lift the screen out to expose the inverter.
6. Disconnect the wires leading from the Dell Latitude D410 Inverter. One wire goes to the backlight, while the other goes to the video card.
7. Look on the back of the Dell Latitude D410 LCD inverter for a model number or serial number. Having this exact number will make it easier to order a replacement.
8. Connect the video wire and the backlight wire into the new inverter and affix it using the tape that held the original in place. If you do not have that tape anymore, or it has lost its adhesiveness, you can buy more from computer parts retailers.
9. Put the screen back in place if you need to, and snap the front bezel back on.
10. Screw the front bezel screws back in, and place the screw covers back in place.
Dell Latitude D410 - OS won't boot only after a few minutes
Seeing that both OS's (Windows XP and Ubuntu) are having a problem booting up, I also think the problem is with your HDD. I think you have a pretty good idea about computers from your use of terms :) There may be some corruption with the HDD. I would check that out first.
Good luck with your problem and thanks for using FixYa.com!!
HOW CAN I GET INTERNET CONECTION IN MY LAPTOP
I assume that you have loaded all the drivers for you laptop from
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=LAT_PNT_PM_D410&os=WW1&osl=en&catid=&impid=
If you need the manual,
http://support.dell.com/support/edocs/systems/latd410/en/index.htm
The instructions for connecting to a wireless network is under the "wireless local area network" instructions.
Mouse problem with Madden 08 on Windows 7
i have the same problem workes perfect on my desktop but not my laptop
1helpful
Have a Latitude D410 running Windows XP Professional. This morning, the touchpad stopped working after coming out of hibernation. If I powerdown and reboot with media base, both the attached mouse and...
try to do system restore it might one of the windows update causes the problem, if fails check system bios compare it from the dell support site if its out dated download bios then flash.
Powersurge on USB ports
Have a close look at the USB ports, make sure you don't have any bent contacts touching the outer part of the connector and shorting.
Grand Canyon Tech
Grand Canyon Tech
