Question about Epson Stylus CX3200 All-In-One InkJet Printer
Epson Stylus CX4600 pulling paper in crooked
And then jamming?  I pull the paper out and try again.  Sometimes it will go through properly if I hold the paper,but then only half the page prints (the right side will print but not the left)
  • 94 Answers
Hi, please check if there is a paper jam or any obstruction inside that printer. Check also the platen lever or the left edge guide, make sure that paper is loaded correctly. Try printing again. If issue still present. Your printer needs to be send to service center.
--->>> Tirzo
Posted on Jun 12, 2008
Paper feeds crooked then jams?Used less paper different paper it just pulls the paper in unevenly the jams. Help
Check feed roller for contamination, fan the paper to seperate sheets and then make sure that you are using paper of the following standard:
Paper Type Thickness Weight Single sheets
(plain paper) 0.003 to 0.004 inch
(0.08 to 0.11 mm) 17 to 24 lb
(64 to 90 g/m²)
Make sure you are using paper supports and feed guides.
Apr 09, 2010 | Epson Stylus CX9400 Photo Printer
The paper twists and causes a jam on every print
sounds like something jamed in the rollers like a pin etc
Jan 05, 2010 | Epson Stylus R265 InkJet Photo Printer
My CX9400Fax printer has a paper jam every time it tries to print. As the paper starts to feed into the printer, the bottom left pulls in and the paper is then feed in crooked causing a paper jam every...
hey i had the same prob til about 5 minutes ago ,, i kept pulling and playing with the jammed paper under the lid where you change the ink,, and finally on the left side ,,a blue piece of soft plastic material came out ,,now it works great ,,i have no idea where it came from but maybe it will help you lets hope
Dec 13, 2009 | Epson Stylus CX9400 Photo Printer
The sensor lever was stuck and still blocking the sensor and that is the reason why it always say paper jam.You have to dismantle your printer if you do,you can find and trace the sensor where the paper is being inserted,most probably it is near the pick up roller (it is the one that gets the paper).
Sep 17, 2009 | Epson Stylus CX7800 All-In-One InkJet...
Ink and paper jam red ligths on ana off ?
Epson Stylus Printer
Please remove catridges from the Printer.
Clean the place with a white cloth along with cleaning liquid in the seat, where the catridges are sitting.
Use genuine Catridges for this Epson printer.
Dust and other things to be removed from the Printer.
Insert the papers in the In tray and check for the paler pulling sensor is working properly.
Paper jam can be taken care, after carefully removing small pieces of papers jammed in the printer.
Finally switch off the printer and machine and reboot the system.
Still problem comes, please contact the local printer engineer to assist you in this issue.
Jul 19, 2009 | Epson Stylus C66 InkJet Photo Printer
My Epson CX5800F is pulling the paper into the printer crooked
I had the same exact problem. Get a piece of fine grit sand paper run it though face up a coupe of times. It works!!! My printer now is great. A friend told me this because a printer repair person told her.
Jun 12, 2009 | Epson Stylus CX5800F All-In-One InkJet...
Paper feeds through crooked and comes out crunched
Make sure the blue slide device on the left side of the paper holder is tight against the paper. If not, the paper will feed corrked.
May 29, 2008 | Epson Stylus Color 740 InkJet Printer
Epson Stylus CX3200 ( loud noise like paper is jammed) error message comes up.
By pulling the paper out backwards your sister may have caused a gear to jump. You could try pulling a piece of paper out in the other direction and maybe the gear will jump back into place. Otherwise you will probably have to have the printer serviced.
May 09, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus CX4600
If all of the lights on the control panel are flashing and you see the letter E in the Copy window, the print head may not be able to move back and forth freely. Follow these steps:
  1. Turn off the Stylus CX.
  2. Open the scanner.
  3. Remove any jammed paper or other obstructions from the paper path.
  4. Carefully lower the scanner.
  5. Turn the Stylus CX back on.
alert_note.gif Note: If you can't remove the paper or foreign object yourself, do not use force and do not disassemble the Stylus CX.
And the last thing you could do, is to check if the rod where your carriage slide is dry...if so put a little bit of oil on it
Apr 03, 2008 | Epson Stylus CX4600 All-In-One InkJet...
Epson Stylus CX3200 All-In-One InkJet Printer Logo
308 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
