Question about HP Ruggedized DC Car Adapter for HP Deskjet 460 InkJet Printer
My computer will not print what im tryin to print nd my printer isnt printing any thing nd it takes n paper nd sends it bac out the way it was "blank"
    Problem Solver:
  • 9 Answers
Try to unsinstall the CD installer of your printer and install it again. you must configure the setting of ur printer in order to connect on the system of your computer. make sure that the printer device driver set us default printer driver. if it not possible you better check the hardware if you do not know you can check it for the authorize technician if your printer covered for warranty. thanks
Posted on May 11, 2009
No print only a blank page comes out
Wrong printer drivers for your computer or else they did not install properly. Also blank page may mean you are out of ink/toner.
Aug 19, 2014 | Office Equipment & Supplies
I guyz. my hp officejet printer works very fine as in you send document to the printer but the most amazing thing is that afetr printing and you discover there is no ink on the printer page. Please...
Hello
Before actually printing your report, use the Print Preview function to see how it will look. If there are blank pages, you will see them in Print Preview.
To use the Print Preview function, simply open the report, click on the "File" menu and choose "Print Preview" from the file menu. You will then see your report just as it will look on the printed page.
Scroll through the report for blank pages. If you see blank pages, it is an indication that the data on the report is wider than the paper you are using. You can use your printer properties to change the size of the paper if you wish. If you have access to legal-size paper, you may be able to print the report on the larger paper. If legal-size paper is not an option, you will need to adjust the margins so that the blank pages are eliminated.
To adjust the margins of your report, click on the "File" menu and choose "Page Setup" from the drop-down box. Go to the Margins tab and adjust the margins as needed. It may take a bit of experimentation to get the margins just right; toggling back and forth between Print Preview and Page Setup will make the process faster and easier.
Click on the "Page" tab and choose either portrait or landscape orientation. Changing the orientation to landscape may allow all the fields to print on the same page, thus eliminating the blank pages and saving your paper.
Nov 05, 2010 | HP OfficeJet d145 InkJet Printer
Printer keeps printing blank pages non stop going
drop kick unit across room:)))) sorry just kidding I had the same problem with mine. If the computer is continually printing that means the printer is receiving print orders from your computer. Best thing is just disconnect the printer from the computer and turn the computer off and wait 30 seconds then turn on . This should clear the print cache then reconnect the printer. Make sure to only request one print at at a time.
if the printer continues to print blank pages check to see if you have the latest software driver for the printer installed on your computer. You can do this by going to the manufactures website and download the software its easy to do just follow the prompts and install! Hope this helpful!!!
Jul 24, 2010 | Epson Stylus C84 InkJet Printer
Problem with printing on canon ir 2200
go to run prompt on client end and typ \\ip add of main pc where ur printer actually connected nd then u will get shared printer on display, u will get shared icon of ur network printer right click there nd connect it .... if it doesnt show any problem to connect it will work nicely ...........
Apr 16, 2010 | Canon (6981A002AA) for imagerunner 2200,...
It will not print any thing except a test sheet
Try it on another computer. I think your computer contains virus.
Jul 08, 2009 | Lexmark Office Equipment & Supplies
Prints everything blank
Check the print cartridge. Open the printers top cover and find release lever for the ink cartridge. Lift out the cartridge and check the jets (copper coloered foil with holes) for blockage. New cartridges have a piece of tape over the jets which must be removed before installing. If blocked with dried ink, dab gently with paper towel and rubbing alcohol. Dry by dabbing on paper towel. Other things to check are: Incorrect cartridge, empty cartridge, and cartridge not snapped in all the way. The cartridge that comes with the printer usually is only partly filled and runs out earlier than normal. You could always try a new cartridge which you will need eventually anyway.
Good luck,
Techjoel
May 23, 2009 | HP PSC 1315 All-In-One InkJet Printer
I used generic ink and now my printer isnt working like before
Some new printers will not take generic ink they have a metallic strip on the cartridge that communicates and sends a message this is not genuine or this is a refill
Jan 22, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Printer problems
This sounds the common problem that causes a lack of ink on paper. If you have look HERE you can find a countermeasure that should get you going again. The fix requires some dis-assembly of the printer.
(http://www.tradebit.com/filedetail.php/1594393-Documents-eBooks-Technical)
Apr 19, 2008 | Epson Stylus CX5400 All-In-One InkJet...
HP 6210 using double paper?
Try cleaning the rollers (especially in the back door). It stopped mine from jamming. Hope it will stop the double paper thing!
Apr 15, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP LaserJet 3550 spits out blank paper when job sent from computer but prints fine when printing directly from printer
Try connecting the printer via the USB port on either one of the computers. Then test if the machine prints fine then likely possibility is that the Network interface card is faulty remove the network card and install in a different slot and test. If the same thing happens then reinstall the drivers and test.
Hope this helps
Thanks J
Jan 27, 2008 | HP Color LaserJet 3500 Printer
HP Ruggedized DC Car Adapter for HP Deskjet 460 InkJet Printer Logo
50 people viewed this question
Seeker5211
Seeker5211
