Question about Dryers
Dryer will not work
Dryer started to run but then smelled a fum/burn smell and it was starting and stoping before it stopped all together
  • iamenergy May 11, 2010
    BE VERY CAREFUL WHEN WORKING ON ANYTHING WITH AC POWER CONNECTED !!
    What exactly do you mean by "fum/burn"?
    Does it stop tumbling?
    Does the heating element continually cycle on/off?
    There is at least one thermal cut off switch.
    It is a two terminal device usually mounted near the heating element or in/near where the hot air exhaust leaves the dryer.
    It
    should be closed (shorted) all of the time. It should ONLY open when
    dryer overheats. Check it with an ohm meter with AC power disconnected.
    It should be a short. If open replace it.
    You can also check it with power connected but you must be VERY VERY CAREFUL !!
    Connect an AC voltmeter set to read 250 VAC across the switch.
    Run the the dryer.
    It should measure zero VAC.
    If the switch opens it will measure about 220 VAC.
    If it opens when it has not overheated, replace the switch.
    Problem Solver:
  • 14 Answers
Souns like the belt or rear bearing has messed up.
Posted on May 15, 2009
My Frigidaire gallery dryer stopped working it will buzz when I turn the starter knob but never starts nor does the drum turn ,then I smell a burning smell
if you can hear the motor running then probably the belt is either too loose and/or broken (you may hear a rubbing or squeeling sound).....if you cant hear the motor running then it may be burned out....a very acidy smell.
Either problem requires taking the dryer apart to fix (new belt or new motor)
May 03, 2016 | Frigidaire Dryers
Ran gas now starts then turns off and smells like burning rubber
Not sure I follow your story. If you really did run out of gas, you may have damaged the fuel pump in the tank. But it would not cause any smells.
Can you tell where the smell is coming from ?
Feb 19, 2014 | 1987 Oldsmobile Ciera
Kenmore dryer model 86880100: Start button would just buzz when pressed, sometimes actually start the machine, then the machine would run for a few minutes and turn itself off with a burning smell. Now...
Sounds like a over heated motor which starts when the motor is cool but not after it runs and stop. Burning smell comes from the heated windings on the motor coils.
Make sure that the pully is not binding...which i doubt.
Oct 15, 2013 | Dryers
My Kennmore 79363 Gas Range/ Electric Oven electrical doesn't work. Started smelling electrical burning smell, tracked to oven. shut off breaker, smell stoped. Few hours later checked again after...
The person who installed the oven didn't do the connections up tight enough.
I would replace the breaker/power switch with a new one and trim back the wires if the burning is in the breaker. If on the rear of the oven, same applies with badly tightened connections.
If in doubt, call a qualified electrician. That will be better than having a fire!
Aug 06, 2017 | Kenmore 79363 Gas Kitchen Range
Making buzzing sound and not turning. then the buzzing sound stops and it smells like something is burning. then u will hear a clicking noise and sound will stop all together and nothing will happen unless...
The motor on your dryer has gone bad. The humming is the motor trying to start and the smell is the motor getting hot because it is not starting.
You need to replace the motor.
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
Heatman101
Mar 09, 2010 | Kenmore Dryers
The dryer timer runs but the dryer does not
burned out element probably to much lint on the element and motor unplug dryer and take back off and use a vacume to vacume up all the lint and look at the element to see if they are broken they are fairly cheap .cheaperthan a new dryer also check the belt it mighjt be broken
Mar 23, 2009 | Kenmore 62622 Electric Dryer
Dryer stoped running
Your drive belt may have broken if it smelled like rubber burning. If that is the case then your motor bearing are worn out or something has been lodged between your dryer drum and the dryer housing. If the smell was the odor of burning plastic, then your motor is probably burned up.
Feb 24, 2009 | Maytag Dryers
EZ3612 - spins for couple of times then stops with burning smell and mode light blinking 13 times
Per the service manual, if the mode light blinks 13 times, there's a bad dryer sensor or thermostat. I'm not sure if that related to your problem but it's a start.
Doug
Feb 24, 2008 | Equator EZ 3612 CEE Front Load...
Dryers Logo
63 people viewed this question
Top Dryers Experts
