Question about IBM eserver xSeries 205 8480
Network Problem (occasionally loss)
We a problem with our networking, for early its normal but sometime it just loss and then back to normal again. We try to ping the server from client, for a moment it normal and 100% connected. But when it reach about 15 minute, we have loss up to 75%. We have update the BIOS system and Network Driver Version (we download it from IBM sites). But it give no good. We also have change/restructure out network line and hub. Please if you have experience like those kind of problem or know how to solve it, we wish your assist. Thankyou.
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Are you using an integrated nic thats on the moherboard or a regular network card that plugs into a PCI slot?
  • 83 Answers
Are all clients losing connections or just one? Can anyone ping the server when your client is getting 75% loss? If you are using a hub, what traffic is running during packet loss? You might need a packet trace to see what is going on. You also need to check your server stats when it is happening and when it is not and see what the difference is. Check the hub stats for errors on the ports. Is the server on the same hub with your client? These should help you find the problem if you get this info.
Posted on May 11, 2009
Sometime when i call they can't hear me but i can hear them. when i hang up and call again they can hear me
It is your phone mic need to be replaced or has some loss connection. As that problem happens sometimes " the mic connection to phone board connect sometimes and lose sometimes"
it can be network chip also need to he replaced. As when you hang up and call again it fix the problem . And usually it is where the fault
get technician to repair.
May 07, 2015 | Cell Phones
What does a red light and a flashing yeallow light mean on a honeywell gsm radio
RED FAULT ON - No contact with network.
OFF- Normal.
SLOW BLINK - Loss of communication with the panel (ECP fault).
FAST BLINK - No network contact AND loss of communication with the panel.
YELLOW MESSAGE ON - Message transmission pending.
QUICK PERIODIC BLINK - Normal
FAST BLINK - Message waiting for network ACK.
SLOW BLINK - In unison with green LED - Registration in progress.
Hope this helps, all of this was found in the manual :P
http://site.geoarm.com/pdfs/Honeywell/gsmvlp-install-guide.pdf
Jul 21, 2014 | Honeywell Ademco / GSMVLP-KT - GSM Radio...
I have a Linksys WRT54G-AS, I can connect my wireless lap top, blackberry, PC, etc however can not connect wifi IPAD2 and ipod touch. My IPAD works at neighbors and public places...just not at home. Really...
Try This: Go to settings Select General Select Network Check that WiFi is on Choose Network If network is hidden then select other..there you will put in the SSID of your linksys and the type of security protocol that has been set
If Network name is showing then select the more arrow select renew lease if IP configuration settings are appearing If settings are not appearing select forget network
Go back to general settings and select network again select wi fi see if the network name appears go to the more arrow check network settings to see if the device has acquired ip settings
You may have to do this occasionally when connecting to various hotspots
Sep 03, 2011 | Linksys Wireless-G WRT54G Router
Should the GWU523 get hot?
Most wireless adapters will get hot during use.
Obviously the cooler it stays, the better it will operate and the longer it will last, but as long as there is adequate air flow around the device for cooling and the ambient temperature is reasonable, it should not be a problem.
Excessive heat may cause occasional loss of signal / connection or even total failure eventually, but unless the unit becomes to hot to even touch, it should continue to operate normally.
Hope that was helpful.
Jul 04, 2011 | IOGear WiFi 54g GWU523 802.11g/b Wireless...
I loss my Driver
windows error.update 1st all mother board drivers then install again the VGA drivers but 1st uninstall the old drivers..good luck
Jun 18, 2009 | D-Link DE-528 Network Adapter
WEP code loss
Did you loose the network key so now u cant connect to your router or you cant access the admin area of your router!
In case that its the network key u can run the wizard again in admin area and reset your network key!
Dec 27, 2008 | Buffalo Technology WHR-G54S Wireless...
Disconnects while working.
it may be as simple as the wireless connection signal strength, as doors, solid walls or any solid object that is in it's line will cause the signal to be very low, and at that point it will disconect from the internet as it is unable to send packets of information to your wireless card from the router. You can try your router in another telephone point that is nearer the pc to see if the connection drops, or use a different channel number which can be changed in the routers settings and the wireless cards properties as interference from other electrical appliances on the MHZ level can cause signal loss. Laptops tend to suffer less with the signal loss because they normally have a signal booster in the screen of the laptop within the wireless receiver ariel.
May 08, 2007 | Belkin (F5D7000) 802.11g/b Wireless...
IBM eserver xSeries 205 8480 Logo
145 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
