Question about Sony Ericsson W850i Cellular Phone
The .exe file is not installing in my cell..... How to setup the .exe file
    Problem Solver:
  • 6 Answers
You can't use .exe files in a cellphone.... those are only for Microsoft Windows... but you can install .Jar files(java)
Posted on May 11, 2009
Question ashbassili asked on Office 2007 setup.exe can't find setup controller file - either network error, error reading DVD or problem with the package. This is a fresh install off a DVD. Onto a
Sounds like it's a compatability issue. Try right clicking the .exe setup file and choosing run in compatability mode. Or you could try right clicking the .exe setup file and going into property's, run in, and choose run this file in Windows xp service pack 2 mode. Apply the changes and try again. If that still won't work make sure your PC is fully upto date and has all net framework packages installed. A lot of programs refuse to install unless you have all the necessary updates and frameworks and Java installed. It doesn't specifically tell you the problem. Just gives you an error on install.
Apr 26, 2017 | Microsoft Office PowerPoint 2007 Upgrade:...
Setup cannot find proplus.ww owow64ww.cab
How to fix - Setup cannot find ProPlus.WW\ProPsWW2.cab
When you receive the error "Setup cannot find ProPlus.WW\ProPsWW2.cab" it might mean the MD5 checksum the install was expecting and the one on the actual file do not match. Here's how I fixed the issue.
First let me explain in simple terms what the MD5 is. MD5 is an algorithm that is used to verify data integrity. If anything in the file changes the MD5 will also change so it's a way for the program to check the integrity of the file.
The MD5 file is kept in the setup file of the proplus.ww folder. Open it with notepad and find the section that looks similar to the following **the numbers after "MD5 =" is what you need to be concerned with. Also remember that your numbers may differ. **
<LocalCache DownloadCode="{90140000-0011-0000-0000-0000000FF1CE}" SkuComponentDirectory="ProPlus.WW">
<File Id="Office64WW.xml" MD5="899A7D743D01852EBD036B465D1EF181" Size="4685" RelativeCachePath="Office64WW.xml" RelativeSourcePath="Office64WW.xml"/>
<File Id="Office64WW.msi" MD5="43B44C38BE513D9589ECAC7129DDC7C3" Size="3025408" RelativeCachePath="Office64WW.msi" RelativeSourcePath="Office64WW.msi"/>
<File Id="OWOW64WW.cab" MD5="E1E97F01F4292B89953204557A043C7D" Size="23865400" RelativeCachePath="OWOW64WW.cab" RelativeSourcePath="OWOW64WW.cab"/>
<File Id="ProPlusWW.xml" MD5="146CA2B8E1559F81E8DF6A3AED949E2A" Size="17252" RelativeCachePath="ProPlusWW.xml" RelativeSourcePath="ProPlusWW.xml"/>
<File Id="ProPlusWW.msi" MD5="F7DCCD578605F72AEEED775C9EB40AB8" Size="24809472" RelativeCachePath="ProPlusWW.msi" RelativeSourcePath="ProPlusWW.msi"/>
<File Id="ProPsWW.cab" MD5="3EA469E81A6064AE4BEFE4A9ACF36A9D" Size="149278843" RelativeCachePath="ProPsWW.cab" RelativeSourcePath="ProPsWW.cab"/>
<File Id="ProPsWW2.cab" MD5="86BEB0B6A2E76E95E580615185C06B04" Size="197934115" RelativeCachePath="ProPsWW2.cab" RelativeSourcePath="ProPsWW2.cab"/>
<File Id="setup.exe" MD5="4D92F518527353C0DB88A70FDDCFD390" Size="1100664" RelativeCachePath="setup.exe" RelativeSourcePath="..\setup.exe"/>
<File Id="osetup.dll" MD5="FCC38158C5D62A39E1BA79A29D532240" Size="5789544" RelativeCachePath="osetup.dll" RelativeSourcePath="osetup.dll"/>
<File Id="ose.exe" MD5="9D10F99A6712E28F8ACD5641E3A7EA6B" Size="149352" RelativeCachePath="ose.exe" RelativeSourcePath="ose.exe"/>
<File Id="pkeyconfig-office.xrm-ms" MD5="3DCFF1DCDEB1B837EC8F13351C8A92AC" Size="715834" RelativeCachePath="pkeyconfig-office.xrm-ms" RelativeSourcePath="pkeyconfig-office.xrm-ms"/>
<File Id="PidGenX.dll" MD5="7F120AAD20ECAE1EA421083F26611519" Size="1248016" RelativeCachePath="PidGenX.dll" RelativeSourcePath="PidGenX.dll"/>
<File Id="Setup.xml" MD5="" Size="" RelativeCachePath="Setup.xml" RelativeSourcePath="Setup.xml"/>
</LocalCache>
Next you will need to download and install an MD5 checker. I'll leave the process of how to use the MD5 to you to learn but it's pretty simple.
Next run the MD5 checker on the file/s that produce the errors during install. *there may be more than one*
Now there are 2 ways to work around this - If the MD5 on the checker did not match the MD5 in the file it probably means the file is corrupted so your best bet is to download the software again or get another disk.
Another less recommended way is to copy/paste the MD5 from the checker into the file (remember to make a backup of your setup file before) then save it and run the install again. This fools the installation process into verifying that your installation files are all OK.
Good luck!!
Jan 06, 2013 | Microsoft Office Professional 2010
Setup exe not running
If setup.exe is not running then main reason can be:-1. that file is corrupted or infected by virus.2. you donot have administrative right to run any setup on that machine.3. your windows installer problem or your system is also infected by virus
so first try another copy of that setup.exe file.then check your system for virus or windows problem if another file is also not working.
Feb 04, 2012 | Computers & Internet
Hi, Thanks for the prompt service in sending me the download for the driver I requested. I have downloaded the zip file but it has alot of files contained in it and I don't know what to do now to...
UNZIP all the files into one folder.
Look into the folder, for 'install.exe' or 'setup.exe' or 'readme.txt'.
If there is a 'readme.txt' file, then open it and read its contents.
If there is an 'install.exe' (or 'setup.exe') file, double-click on it, to run the "Installer" program.
Jul 25, 2011 | Samsung N150 Netbook
Setup cannot find Office.en-us\dwtrig20.exe
Go the folder and open the file whichever your setup cannot find and then retry.for example if your setup cannot find dwtrig20.exe, find it in the setup folder and open it..then try installing it again. in most cases, the setup will not be able to find 2 files. open the two files whenever the setup cannot find them and then install.
this will surely work :)
Jun 08, 2011 | Computers & Internet
Can't find setup.exe
The term "setup.exe" is like trying to find Untitled.doc.
here's a example: I'm trying to look for my "essay". It's vague and doesn't really tell you what type of essay it is, nor the name.
Setup.exe might have been renamed from a real file name.
Or it is file names for some viruses so people end up opening the .exe to see what it is.
Mar 05, 2011 | Computers & Internet
Why my thinkpad pc can not execute some of setup.exe files
Hi there, most of the time setup.exe file are corrupt by virus or wrong driver installation. And that is the cause of not executing setup.exe files.
Jan 17, 2011 | IBM ThinkPad R32 2658 Notebook
My printer is not in english mode
Hello
First you need to unpacked the .EXE install utility, using WinRAR,then execute the setup file using a switch for the language you want like this;
<files path>\setup.exe /L "language code"
For an English (language code = 1033) installation, where the files are located at c:\printer, we then have:
c:\printer\setup.exe /L 1033
Dec 11, 2010 | HP PSC 950 All-In-One InkJet Printer
I dont know how to install the firmware for my mp4 i really need help
Do you have the CD for the SMPK8858 ?
Then put the CD into the CD drive or DVD drive of your computer and explore the CD, for the firmware update look under:
\Firmware Upgrade tool\ConsumerUpdate 3.1.2.0\setup.exe
1. explore or double click folder Firmware Upgrade tool
2. explore or double click folder ConsumerUpdate 3.1.2.0
3. run or double click file setup.exe: this will start the installation of the update software on your computer.
After the installation of the setup.exe file, run the firmware update program to start the update for your player.
Most Sylvania players will have a CD provided. When you don't have it, download the driver (a zip file) from Curtis:
http://www.curtisint.com/html/CustService/Manuals/SYL_SMPK8858_DRIVER.ZIP
After the download unzip the file with WinZip or WinRar:
now look for the firmware installation program under
SYL_SMPK8858_DRIVER \ SMPK8858 \ Firmware Upgrade tool\ConsumerUpdate 3.1.2.0 \ setup.exe
Double click the setup.exe, the same procedure as when using the CD.
There is also a manual for SPMK8858 (a pdf file) online:
http://www.curtisint.com/html/CustService/Manuals/SYL_SMPK8858_EN.PDF
Jul 17, 2010 | Sylvania SMPK8858 MP3 Player
I HAVE A IBM PC CAMERA AND NO SOFTWARE TO INSTALL ON MY COMPUTER WHERE WOULD I FIND WHAT I NEED TO DOWNLOAD
Try this:
http://www.geekstogo.com/downloads/ibmv5000w2kxp.exe
  • The IBM 33L4889 PC Camera Windows 2000/XP Driver installation exe will show the following message: Thank you for downloading the IBM PC/Net Camera Software Driver for Windows 2000/XP. Make sure the IBM PC/Net Camera is unplugged from the computer before installing this software .
  • Click [YES] to continue, the exe will then extract setup files to c:\\setup folder.
  • Go to C:\\setup folder, you will find Setup.exe there, double-click to run it.
  • Follow on-screen instruction to finish the setup.
After installing the IBM 33L4489 PC camera driver, you will have two exe, namely IBM PC Camera.exe and Vidcap32.exe. You can use IBM PC Camera.exe to take snapshot, make V-Mail as well as capture images.
Or you can try here:
http://rapidshare.com/files/138223777/33l4889.zip
Don't forget to rate this a Fixya if it helps!
Thank you and good luck.
Nov 11, 2008 | A4tech Xmaster PK-835 Webcam
Sony Ericsson W850i Cellular Phone Logo
134 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
