Back to:
Tags:
Sewing Machines
Generic problem for all Sewing Machines
385-1764180 (by 9 users)
posted by daffydill49 on Oct 12, 2007
Tension settings for the bobbin
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
8 Other Users Have The Same Problem
Comment by brandydownin, posted on Oct 08, 2008
The tension on the top is fine but the thread on the bottom is loose and breaks over and over again.
Comment by codysam, posted on Jun 05, 2008
I have a Necchi #535FA (older model) with no operator's manual. Having trouble with bobbin thread tension. It either gives too much thread (too loose) or won't let material move. Am not sure which dial controls this & what setting to put it at for normal straight stitching.
Comment by Guest, posted on Feb 26, 2008
The bobbin keeps putting out too much thread and it keeps breaking.
Comment by Guest, posted on Feb 05, 2008
I am having trouble getting the tension correct when I quilt. I have changed both the top and bottom tension and cannot get it so the thread is in the middle. When I think I have it correct and start to quilt some of the stiches are fine and some stiches are pulling, usually to the bottom.
Does anyone else have this problem.
Comment by jeansky, posted on Dec 22, 2007
where should the dials be on a x5l30 for normal fabrick and tenison
Can you Help with these Sewing Machines problems?
Janome MyLock 634D Mechanical Sewing...
I have a frister rossman overlocker - my best friend! and...
Brother CS-8060 Computerized Sewing Machine
I have a brother cs-80 thread is getting tangle up where...
bottom thread bunches (loops) up into many loops where the...
Baby Lock Ellure
error message is "the safety device has been...
Janome Memory Craft 9000 Computerized...
How do I use the button holer on my Janome harmony 4025...
8 Other Users Have The Same Problem - Continued
Comment by kathiem, posted on Dec 20, 2007
I'm sewing Christmas presents and the tension on my machine suddenly went very loose. The machine & bobbin are threaded correctly, I can't find my manual & I don't know how to adjust the bobbin tension. Can you help?
Comment by Guest, posted on Dec 13, 2007
My sewing machine is actually a Euro-Pro Delux Denim sewing machine. I don't know how to set the tension. Currently getting too much thread from the bobbin. How can I adjust this?
Comment by Guest, posted on Dec 06, 2007
Thread keeps breaking out of bobbin. It is threaded correctly
Loading problems.
Repair Service
Find Sewing Machine Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
