Wash mach Whirlpool LXR7144EQ1 drum does not turn / grinds.
Thr drum does not turn at any dial position. The motor or trans makes a grinding sound. The tub does not turn and water is not extracted.
5 Suggested Answers
SOURCE: Washer spins but not enough to extract water from clothes or tub.
I have a MAH5500AWH and experienced the same problem twice. Both times the R11 resistor on the control board was burnt up. The board is behind the cycle selector dial. To check, remove the outside screws holding the metal backplate for the user control console. Do not remove the inside screws as these hold components to the backplate. My advice is to replace the whole board. You can buy a new one (expensive) or try and get a used one from a repliance repair/parts center.
Posted on Aug 18, 2006
SOURCE: Grinding niose from agitator.
If the fill and drain functions correctly, AND the spin cycle works correctly, AND the cycle itself starts and completes correctly, the problem being that the back and forth motion of the agitator starts the loud grinding noise, it will likley be broken gears in the transmission. The single most expensive part in the washing machine.
Posted on Feb 07, 2007
the dr
  • 447 Answers
SOURCE: grinding noise when drum rotates
may be a foreign object trapped in between the inner and outer tub. Major Disassembly required to split the outer tub. May also be the rear bearing in which case back half will have to be replaced.
Posted on Oct 04, 2007
  • 1294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Dec 31, 2007
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
My dryer makes a loud grinding sound and won't turn?
The grinding Sound is the motor attempting to start and not being able. If you find nothing binding the drum and you can turn it by hand fairly easily you will likely need a new motor. Otherwise, find and remove what is causing the drum from not turning
Nov 14, 2015 | Dryers
When doing laundry, it sounds like my washers gears are grinding very loudly. What would that be?
I think you are correct, I would suggest replacing it especialy if it is over 7 years old or has a lot of use. If you have oil in the wash you seal failed.
Jan 11, 2015 | Whirlpool WTW6400SW Cabrio Washer
Lg waveforce washer makes grinding squeeking noise drum hard to trun.
The LE error or fault code indicates that the washer motor is either overheating or has lost connection to the motor control circuit board. Turn off the machine for 30 minutes to let the motor cool down. Then, restart the washer. If the code comes back immediately the motor is not likely to be at fault and so you should check the wiring from the motor to the motor control board. Also, check the wiring and condition of the rotor position sensor, also called a HALL sensor. If the code doesn't come back on immediately, but returns after the washer has run for a while, the motor stator may be defective
The tub bearing also appears to be part of the problem.
Aug 22, 2014 | LG WT5170V 4.7 cu ft High Efficiency Top...
Whirlpool cabrio makes grinding noise on the wash cycle
On this style washer the motor has a belt and pully type clutch under the machine called a splutch.There has been an ongoing problem with the nut coming loose and dropping the belt/pully down which in turn hits the safety shield.
Mar 31, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Bearings for a AWM 5145
Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Sep 04, 2012 | Whirlpool Washing Machines
Washer motor turns, drum does not
Please be gentle with me if this is obviously not the problem, but I have made the mistake of running top load washers with the door open (which the washer notices and does not turn the basket. I fixed my problem by loading the washer, adding the detergent while the washing machine was filling and then closing the door. My washer worked fine with the door closed.
Again, please be gentle with me as you rate my helpfulness. OK?
May 21, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
When turned on, the drum makes a grinding noise as
The main bearing may be worn out at the back of the drum allowing the drum to wobble.Reach inside the drum and lift upward. If you can move it up and down this is probably the problem.
Nov 05, 2009 | Whirlpool LER4634J Electric Dryer
Kenmore washer elite top load
sounds like you have a bad coupler.mach does not have a belt it uses a coupling system between the motor and trans.if you fill mach and it makes the same noise in agitation,replace the coupler
Sep 21, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
