Question about Refrigerators
It was fine when i had it upstair until i took it to the basement. It has been like this for a few months.
  • 83 Answers
Have it defrosted and un-plugged for a couple of days. let the oil settle down. then turn it on again.
Posted on May 11, 2009
Is it safe to connect a main support beam 26ft long in 3 peices with 3.6 connection at each end put together with cariage bolts, ?
No, because carriage bolts will rust through in time. The ends are the worst for rusting. This is why I told you to contact your local authority building officer, to check on building code regulations.
There was a nice bungalow near where I live used as an insurance business. They decided the basement although a little low on headroom would be good for storage. Someone had the bright idea to lower the floor in the basement. They got in a firm of cowboy builders who really didn't know much about building codes. Part way through the upstairs collapsed into the basement at an angle of 30 degrees. The two idiots digging the floor out, got out unscathed, but a bit shaken. Police and fire officers arrived, and the next day the building inspector. The building was condemned as a totally unsafe structure. It had to demolished professionally piece by piece and also remove all the items that were inside the upper floors. All that took about 6 months and then another 18 months to rebuild the house properly. The final part of the cautionary tale was that the although the builders were insured, they wouldn't pay out because the work wasn't done to code. The building was a State Farm office so that helped.
Feb 17, 2018 | Cars & Trucks
Have oil heater that we had serviced yesterday. Heater stays at temperature but circulating pump will not send heat to upstairs radiators. (heater in basement) Any advice?
Try putting in central heat and air in your house don't rely on some basement heater then you will have a basement heater for when it get cold
Dec 03, 2013 | Lakewood Oil-Filled Electric Radiator...
Problem with Goodman furnace electric ignition
Power is there, or no lights would blink. Steady blinking or flashing three times, stop, three times Etc
Nov 23, 2011 | Goodman Heating & Cooling
Hello there, I have a split entry home with a finished basement. I was wondering: on nice warm days, with a wind blowing through the upstairs, if I can leave my windows open upstairs while the...
Connie, it will only work if all of the interior doors to the basement are closed during this time. Even putting an old towel at the bottom of the door(s) leading to the basement will stop the air flow.
Hope this helped you and thanks for choosing FixYa.
Aug 23, 2011 | Dehumidifiers
I live in a three story house my wii is in the basement and my wireless router is on the second floor should my wii pick up a signal...i tried to hook up with netflix and my wii says cant find connection
Hi.
1. Try using it upstairs on the 2nd floor and if it works there you know its a range issue with the router.
To then solve it you could run a cable from the router down to the basement (which is a bit old school but very effective and guarenteed to work) or get a second router or modem and place it in the basement. (for modem you would need a phoneline in the basement)
2. If it doesn't work upstairs, make sure you have the correct connection information for your network and that your network is broadcasting its SSID. If your network is not broadcasting it is what is known as hidden. This means that you will have to enter all the network information manually by following the prompts on the wii console.
Jun 16, 2011 | Nintendo Wii Console
I bought an LG dehumidifier last summer and it worked fine until about 2 months ago. Then there was this constant clicking noice. It seemed like it was electrical with the switch or something. It was...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Apr 22, 2011 | LG LHD45EL Dehumidifier
What can I do to assure that my commode won't overflow? I came home after being away a week, and my basement was flooded due to the upstairs toilet leaking. Plumbers say it was just clogged. It totally...
Turn off the water at the valve going to the tank of the toilet. The valve is normally located half way between the tank and the floor, on a pipe leading to the tank. The water in the bowl will last over a week and should not be a problem. Good luck, I hope this helps Please rate me, Thanks
Dec 30, 2009 | Crane Plumbing Toilet To Go Tall...
Bad reception w/ Panasonic RF-544
I solved the problem, but I did not "fix" the problem. Rather than rig an antenna to the old Panasonic RF-544 radio, I put it upstairs where it has good reception. I put the new Sony ICF-38 downstairs where it brings in the stations I listen to. The advertsizing claim for the Sony ICF-38 is that it has "Good Sound and High Sensitivity." I believe it does have "high sensitivity" because even in the basement it brings in my desired stations. (I am still curious to know if I could have rigged an antenna to the old Panasonic RF-544.) RL
Dec 07, 2008 | Panasonic RF-544 Radio
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
