Hi, I have a Alpine CDA9856 hu rf cpapacitor feeding a Infinity 475a for four speakers. In addition a RF 550 punch driving two 10' dual coil speakers. The front doors are Inf. component rears are Inf 5x7's. power led at amps are showing power. capacitor shows 12 volts. The sub lost power to speakers and currently the driver side component spker works and the pass. tweeter (only) works. Can I test for voltage at speaker terminals at amps for output? Do I use pos. prong at terminal and ground other prong to Chassis or amp? what voltage readings should I get? Can I test head unit at rca out/in?
I am repairing an old Kenwood KC-105 amp and need an electrical schematic. Any chance you can locate...
(More)
I am repairing an old Kenwood KC-105 amp and need an electrical schematic. Any chance you can locate one for me?? Dean San Ysidro, Ca.
my phoenix gold xenon 100/2 keeps blinking and putting a loud buzzing sound into my speakers, it...
(More)
my phoenix gold xenon 100/2 keeps blinking and putting a loud buzzing sound into my speakers, it went into protect mode, whats wrong with her just got it.
have a jl audio 500/1 i think something is wrong with the ground on the amp i intalled it and it was...
(More)
have a jl audio 500/1 i think something is wrong with the ground on the amp i intalled it and it was load sounded good but after a couple days i would turn it up and it would cut out until i turned it down so i relocated the ground then it worked good again but the same thing happened after a couple days the amp would only work at low volume would could be causing this
i try to fix amp INFINITY REF475 .PWM on TL494CN is not start . TL494CN I replaced - no...
(More)
i try to fix amp INFINITY REF475 .PWM on TL494CN is not start . TL494CN I replaced - no result.Please help give a tip where I can find circuit diagram of this amp or something similar?
