Slow drain
Shower drains are all designed to be opened and cleaned, usually hair builds up, if there is a visible screw remove it and lift the drain cover, if you can get fingers under the cover try lifting it off to clean it. If its stiff and its made of plastic do not use metal tools to lift it. Instead pass a trouser belt under both sides and use this to pull it up, then clean it.
