Question about Stanley Bostitch STB-MIIIFS Flooring Stapler
Will not staple air coming out of frame cap ?
MIIFS floor stapler will not staple, air coming out of frame cap?
It's a blown seal do'es work sometime when you disconnect the airhose and reconnect?If so thats the problem
Posted on Jun 26, 2009
Still an issue with shooting staples. the gun just clicks
Have you been oiling it regularly? Compressed air is very moist so a few drops oil oil in the unit is needed every once in a while to lubricate it properly, try and see what happens.
Dec 06, 2014 | Stanley Bostitch Ehf1838k Engineered...
What part do I need to remove to make a bostich MIIIFS floor stapler to shoot 2 inch staples
You shouldn't have to do anything to the MIIIFS flooring stapler to shoot 2" staples. It is designed to shoot 1 1/2" to 2" staples right out of the box. If your stapler won't feed 2" staples, check the magazine all the way up to the power head for any foreign material that may hold up your staples.
Apr 26, 2011 | Stanley Bostitch STB-MIIIFS Flooring...
WHERE do I open it to refill it??
Located on the end opposite of where the staples come out, there is a spring loaded cap. Push it in toward the base of the stapler and slightly down to release the retaining hook. then let the spring release the pressure rod and pull it out. Connedted to the end of the rod you will see a plunger that is shaped like a short run of staples. Make a mental note of how and where this plunger slides into the base of the stapler. Place a run of staples into the stapler in the same manner that the plunger fits then replace the plunger into the same place following the run of staples. Compress the spring into the stapler and attach the hook as it was. Now you are ready to work.
NOTE: If you cannot compress the spring enough into the stapler you have inserted too many staples, just remove some of the run of staples and try again.
Nov 12, 2010 | Arrow T50P ARROW STAPLE GUN
My bostich flooring staler wont fully drive every staple and it is getting wors....it is not leaking air
Your compressor needs to be checked first. There is an air pressure regulator on most machines - be sure all is in working order. It might help to be sure you're playing any lubricants in the stapler configuration as well.
Nov 05, 2010 | Stanley Bostitch STB-MIIIFS Flooring...
I HAVE A BOSTITCH NARROW CROWN AIR STAPLER AND THE STAPLES ARE NOT GOING FOREWARD FOR THE ROD TO DRIVE THEM IN. IS THERE SUPPOSED TO BE A SPRING BEHIND THE STAPLES TO MOVE THEM FOREWARD. PLUNGER COMES...
There is a spring to push the staples into place. Bostitch was purchased by Dewalt and moved their parts lists to the web address below. Enter your model number and order the parts needed. Good luck with your future projects.
http://servicenet.bostitch.com/
Sep 02, 2010 | Stanley Bostitch STB-MIIIFS Flooring...
Setting staples too deep
The depth is set by the bumper and the bumper spacer. Are you sure these were put back in? the air pressure only makes a small difference on the depth...
Mar 11, 2010 | Stanley Bostitch STB-MIIIFS Flooring...
Air leaks thru portals on cap after replacing rings and gaskets?
Remove the bumper cap and black exhaust hood from the gun. The three screws that hold the plunger to the poppet need to have lock washers and BLUE locktight on them. Clean them totally and reassemble.
Oct 03, 2009 | Stanley Bostitch STB-MIIIFS Flooring...
My Bostitch MIIIFS Floor Stapler wonk work
Sounds like you have a broken driver blade.
Sep 27, 2009 | Stanley Bostitch MIIIFN Flooring Nailers
With a stanley floor stapler do i nail at tongue or groove
the staple goes in the corner of the tongue, angled back into the board at 45 degrees, to make an invisible staple, the next board groove covers the staple and tongue. The floor nailer is preconfigured to make this joint
Oct 04, 2008 | Air Tools & Compressors
Stanley Bostitch STB-MIIIFS Flooring Stapler Logo
380 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
yoopertech
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
