Home | Hotpoint | 24 in. HDA2000Z Built-in Dishwasher | DOES NOT DRAIN
Hotpoint 24 in. HDA2000Z Built-in Dishwasher
Problem for Hotpoint 24 in. HDA2000Z Built-in Dishwasher
DOES NOT DRAIN
By WOPEALE3 on May 11, 2009
DOES NOT DRAIN
Solution #1
posted on May 21, 2009
Not Rated)
ginko
Rank: Guru  Hotpoint Expert
Rating: 89%, 4938 votes
Check drain hose first.
If you do not find any blockage, then you will need to access the pump, remove pump hose and look for blockage in there.
If there is no blockage at all, then either the water level switch, a faulty pump, a wiring problem, or a faulty timer board can be cause the machine not draining.
Was this helpful?
Yes
No
Popular Solutions for Hotpoint 24 in. HDA2000Z
Questions and Unsolved Problems for Hotpoint 24 in. HDA2000Z
Do you recommend Hotpoint 24 in. HDA2000Z Built-in Dishwasher?
Answer
Answer
wash cycles not working, load machine, select wash cycle, it then runs but does not clean
Answer
will not wash- not sure if it is the same model, but i turn it on to wash, and it doesnt start a... (More)
Answer
when i turn the dishwasher on the water comes in and it sounds like it is washing but when i open... (More)
Answer
My hotpoint dishwasher leaks every time it starts to drain the water.
Answer
dishwasher starts filling with water, but starts emptying a few seconds later
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hotpoint 24 in. HDA2000Z...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1494
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 470-7119
All the parts that you need for your Dishwasher...
appliancehelp.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
