Question about Troy Bilt Tiller/Edger 26cc, Model No. 21at144r766
TB144 pull cord does not catch, pulls free--no start
I pulled on the cord to start the tiller, the cord did not engage. Nothing.
I have not taken it apart to check if spring is broken.
  • 122 Answers
Yes exactly what i would do sounds like the springs are either worn or gummed up or just broken on the dog ears
Posted on May 11, 2009
Looking for manual for norlett 3hp
the little conter wieghts have catch tabs to engage a hub. sticking springs are causing this problem spray some wd40 or similair blow gun and clean the entire assemble
Jun 29, 2014 | Garden
Starting issue
the starter gear inside the pull cord is not engaging
this is a non servicable part
approach supplier and buy a new pull starter
Mar 26, 2014 | Craftsman 2-Cycle Mini Tiller
Mtd cultivator
take your cover off then you take off your spinny thing out and take the old rope off the spinny thing and tie your new rope in it then twist it tight if its old or if its new dont worry its auto set then put it all back the way you took it off
May 07, 2013 | Troy-Bilt Troybilt Mtd Mini Tiller...
How to remove clutch?
You have to pull the spark plug and fill the cylinder with some small rope then using a big pair of locking pliers you can loosen the clutch. There should be markings on the clutch as to the direction to unloosen.
May 13, 2010 | Troy Bilt Tiller/Edger 26cc, Model No....
I have a troybilt tb-144 4 stroke mini tiller. The pull cord, pulls and retracts as it should, but is not engaging the engine when pulled...
remove the top cover. look inside while pulling rope briskly, you should see two dogs fly out and retract when the cord reaches its end. if not, check for dirt in the system and clean out. if no dogs, you will have to remove the system from the housing, be careful of the spring. check for any broken drive parts. also check flywheel cup for damage where the dogs come into contact with it.
Apr 15, 2010 | Troy Bilt Tiller/Edger 26cc, Model No....
MY TILLER HAS 4 ROUTATING BLADES IN THE FRONT,
under the housing where the pull cord is found is a latch type item with what they cal daugs, when you pull the cord the daugs fly out and catch into slots which will loch to start the engine, try some WD40 spray lube to free the daugs if this dosn't do the job you may end up getting a new housing or starter assembly
Sep 27, 2009 | Craftsman Garden
Engine stalls when engaging cultivator tines
im 99 percent sure all you have to do is get the carburator cleaned out.
Jun 28, 2009 | Troy-Bilt Garden
Troy-bilt 4-cycle Garden Cultivator TB144 pull cord not rewinding.
This type of pull starter design is very poor and fails often. Cheap parts and cheap design leads to poor performance and yet Troybuilt still doesn't give free parts or an upgraded design.
Mar 05, 2009 | Garden
Troy Bilt Tiller/Edger 26cc, Model No. 21at144r766 Logo
929 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
