Question about Cameras
My photos are coming out dark on my Nikon D5100...should I be using an additional flash? An extra one attached to the camera? Sometimes they look dark on the live view and come out okay after the picture is taken when I look back at them.
    Top Expert:
  • Cameras Master
  • 6,705 Answers
The build in flash, will be useful within several meters (15 to 20 feet) if it is really dark.
Your camera should be capable of taking pictures in poor light conditions. Try to shoot in automatic mode. The mode dail to AUTO. (green camera symbol). Then view the picture with info. There you can see the ISO, Aperture and shutter time. From there you can experiment for darker or lighter pictures. For this you can choose M, A,S or P.
In each of these modes, you can use the following steps.
On top of the camera, close to the shutter release button you see a little knob with a +/- sign. If you press that button, you should see a 0.
If you see a - figure, this means the picture you shoot all be darker than normal. If you see a + sign with a figure it means the picture will be brighter. While pressing that button and turning the command dail, you can choose -3 to +3 EV. That is much darker and much brighter.
If you shoot many pictures in bad light conditions, you could buy an external flash. A Nikon flash will work very good and automatic, with your camera, because camera and flash will communicate and help each other to make better pictures. Cheaper external flashes can work too, but most of the time you must change settings manual on the flash. Never use old flashes, that were build for analog cameras. They sometimes switch with a voltage higher than your camera can handle. The camera can be damaged by such a flash.
Posted on Dec 04, 2013
2 Suggested Answers
SOURCE:
tjzteddy
  • 53 Answers
SOURCE: have a nikon d40x camera when
it is the highlight warning. When viewing the photos, simply click the up button to scroll to a different view.
Posted on Jul 21, 2008
Can metz 45CL-1 support Nikon D5100?
To use Metz 45CL-1 with Nikon D5100, you need use in apperture priority mode (A), adjust same ISO and apperture in Flash and Camera (Ex: ISO400 and F: 5.6) . The flash adjust light intensity to mantain correct exposition. You need use an adapter to conect Sync cable in your camera.
Nov 13, 2015 | Nikon D5100 Digital SLR Camera With...
Nikon D5100 dark screen on live view mode
Open your appuatue set your ISO to 200 or 1600 what ever it needs
Feb 20, 2014 | Nikon D5100 Digital Camera
Nikon D5100 camera flash does not pop-up. Any suggestions?
You can't pop up the flash in the Auto mode. In this mode the camera decides whether to use the flash or not.
Try switching to one of the PSAM modes. Does the flash then pop up when you push the flash button?
Jan 17, 2014 | Nikon D5100 Digital Camera
Zoom on nikon d5100
In either mode, you're zooming by turning the zoom ring on the lens? In live view mode, if you zoom in by pressing the magnifying glass button, all you're doing is zooming the display, not the image itself.
Feb 26, 2013 | Nikon D5100 Digital Camera with 1855mm...
Nikon D5100 Autoexposure error when camer is first turned on
Hi I'm having the same problem!!!
My Nikon D5100 camera giving a sin of Autoexposure error after it's drooped from my tripod on the deck floor (Wooden Floor). How can I fix that? I tried few does not work, please help me, it's an emergency. Thanks!
Aug 28, 2012 | Nikon D5100 Digital SLR Camera With...
Can I use one nikon d5100 with one sakar mc zoom 80-200 No. 803489
If your lens has a Nikon mount then yes, you can use it on the D5100. You'll have to switch to the Manual exposure mode and you won't get any exposure help from the camera's light meter.
May 31, 2012 | Sakar "Digital Photgraphy Macro Ring Light...
Nikon D5100 vs Nikon D3200
They both take superb pictures. The D3200 is slightly easier to learn how to use, while the D5100 is easier to use once you learn it. That is, the D3200's menus will guide you through all its settings, while with the D5100 you can change those settings with less work once you learn the proper buttons to push. The D3200 has a higher resolution, but even the D5100 will take photos that can be enlarged to 8x10 and larger.
I suggest you go to a good camera store and try them both out. See which one better fits your hands. You don't want to buy a camera based on specs, or other people's opinions. You want a camera that best works for YOU. Having said that, the D3200 is probably a better first SLR. However, try them both out and choose the one that's better for YOU.
May 19, 2012 | Nikon D5100 Digital Camera with 1855mm...
D5100 won't power on with Sigma macro lens atttached
This is not a solution but the same kind of problem.
I just bought a Nikon D5100 and found that my Sigma 105mm macro has a problem. The camera will not power up, but if I turn it on, untwist the lens and then twist it back in, the camera powers up. If I leave it for a few seconds, it powers down again. Provided I keep taking photos, it works, but this is not acceptable because it can take several seconds to get a focus on a close-up, and by time I get the focus, the camera powers down again.
I never had any problems with this lens on my Nikon D80. I also use several lenses, all of which work well with both cameras. It's only the Sigma that has the problem. And I did clean the contacts with a proper contact cleaning solution and a swab, but still no joy. My lenses are made by Tamron, Pro Optic, Nikon and Sigma, and the only problem lens is the Sigma.
Feb 29, 2012 | Nikon D5100 Digital Camera
Cameras Logo
61 people viewed this question
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
