Ram upgrade I was wondering how many MHz my desktop is because I wanted to get the ram up to 2 gigs. I had it up to 1.50 gigs with the stock ram and a K-byte DDR2 1024 pc 4200. I took out the stock ram and replaced it with one ultra DDR2 1024 pc2-4200 533MHz and the K-byte DDR2 1024 pc 4200. I can't seem to get 2 gigs because the system properties is saying there is only 1 gig. The max gigs this motherboard can handel is 2 gigs. The ram isn't defective because it will read 1 gig if I pull one or the other out of the slot. Maybe its because there not the same brand idk.
You can upgrade it to 2 GB. For me it worked out pretty well because the computer (which also happens to be Acer Aspire L31) really reads 2 GB.
Probably because of the new memory. I installed both 1-GB modules in the same pack or brand. Yours probably be different brands. That might be the problem why it only reads 1 GB -- the computer can't read the other module (either the new or the previous-bought module).
Posted on Jul 23, 2008
The Dell Optiplex 270 has dual channel RAM so it has to be installed in pairs. It has 4 slots for RAM. If you add a single 1 GB card the system will not recognize it - dual channel RAM needs to be installed in pairs which is why your original RAM was split into two modules. The pairs are slots 1-3 and 2-4 (you will see they have different color clips). Put the modules in slots 1 and 3.
Posted on Jan 09, 2008
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 114 Answers
In order to see how many MHz is your desktop, please right click on your "My computer" icon and select "Properties" from the menu.
It will open the system properties window. select the tab "general" and you will see how many MHz is your desktop.
If you have found this solution helpful please rate it as "solved", otherwise please ask here again.
Thank you :)
Posted on Oct 12, 2007
I have a Intel D102GGC2 motherboard with Intel Pentium D 805 processor having core speed of 2.667 GHz. I was using a 1GB of Dynet RAM (DDR2-667 MHz) earlier. Recently, I got a Transcend 2GB DDR2-667 MHz...
specs on that board from Intel is 2 gig max. when you install the 2 gig alone does it show you 2 gig in windows or only 1?......with a 2 gig max I would think that would max each slot at 1 gig...
http://downloadmirror.intel.com/15112/eng/D102GGC2_TechProdSpec.pdf
Jul 04, 2011 | Intel D102GGC2 Motherboard
I have an ET1161-05- can it be upgraded to hold more memory and run faster?
Hi.
Yes, your computer came with 2 gig's of ram in the form of 2 1gig modules of ddr2 ram.
There are 4 slots for memory all together, and each slot can hold 2 gig memory chips in each one, for a total of 8 gig's of ram!
That would cause a serious performance improvement for you.
It also came with a 160 gb hard drive, so if you want to, you can get as larger drive as well.
As far as processors, a dual core, AMD Athlon 64 X2 5600+ Brisbane 2.9GHz 2 x 512KB L2 Cache Socket AM2 65W processor will fit in with absolutely no bios updates required, so all you would have to do is take the old processor out, put the new one in, and turn the computer on.
It will recognize the new processor automatically, and will work right away!
This will have a significant performance boost, possibly doubling the total speed of your computer.
I hope this helps you out, and have a good day !
May 26, 2011 | E-Machines eMachines Desktop PC
I want to upgrade my from 512 to 2GB RAM. Pls let me know which brand RAM and speed will suport to upgrade the same. my motherboard is P5RD2-VM, with intel pentium D 820 processor. pls guide me on the...
Your Motherboard will support:
2 x 240-pin DIMM's (4GB Max)
Unbuffered
non-ECC
667/533/400 MHz DDR2
You should be pretty safe with any main brand name of memory from your local computer shop.
Below is a list of ASUS TESTED and Qualifed Vendor RAM.
Jan 02, 2011 | ASUS P5RD2-VM Motherboard
I am installing a 64-bit OS in my dell optiplex 960 desktop and i want to max out the memory on my PC.What is the maximum memory it can support and what is the best memory i can put in it and what can i...
You have 4 slots and each slot can support 4 gigs so you can have 16 gigs of ram total. I like corsair or Kingston ram the best. And when you are buying ram you want to look at three things. First is the type of ram which your type of ram is ddr2, second is ram speed which is measure in mhz you want the highest mhz you can get and last is latency, which you want the lowest latency you can get :) hope this helps. Visit newegg.com they have great deals its where i buy all my computer parts from :)
Dec 30, 2010 | Dell OPTIPLEX 960S Desktop Computer
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
I have Acer laptop Aspire 5570z module Zr1 with memory 1GB I want to increase memory 2GB or 3GB Is it possible or not What will be the expenditure?
Your laptop's RAM is upgradeable to up to 4 GB using two DDR2 533/667 MHz SODIMM modules.
So your upgrade options here are:
1. Buy a 1 GB DDR2 533/667 MHz SODIMM module & install it to get a total RAM of 2 GB (Price around US$ 25).
2. Buy a 2 GB DDR2 533/667 MHz SODIMM module & install it to get a total RAM of 3 GB (Price around US$ 45).
Aug 14, 2010 | Acer Aspire 5500 5570-2609 Laptop
Will a newer monitor work with my older 2.4ghz cpu
Upgrading a monitor does not require uparading the RAM or the video card on your computer unless you want to run graphic intensive video games.
Mar 20, 2010 | Dell Computers & Internet
256 MB DIMM#1(DDR333) UPGRADE TO 2GB RAM in compaq nx6110 pc notebook
You should be able to upgrade to 2 gig. Here are specs. Good Luck.
512.0 MB / 2.0 GB (max)
  • Technology DDR SDRAM - 333.0 MHz
  • Memory specification compliance PC2700
  • RAM configuration features 2 x 256 MB
  • Nov 20, 2009 | HP Compaq nx6110 Notebook
    Intel D865GBF Ram related questions
    here are the specifications of *********** board go through it...
    Processor Support Intel® Pentium® 4 processor, Intel® Celeron® D processor and Intel® Celeron® processor in the 478-pin package
    Note: It is important to verify supported processors before using this Intel® desktop board. Supported front side bus speed 800, 533, and 400 MHz Integrated Graphics Intel® 865G Chipset with Intel® Extreme Graphics 2 Chipset Intel® 865G Chipset AGP Connector AGP 3.0 (4X & 8X Speed 1.5 and 0.8 Volt Only) Memory Type Dual Channel DDR 400 MHz (PC3200), 333 MHz (PC2700), and 266 MHz (PC2100).
    Note: Be sure to review important memory and system bus speed considerations before using this Intel® Desktop Board Max Memory Capacity of up to 4 GB Memory Slots 4 DDR DIMM Sockets Slots 6 PCI
    So it will support DDR2 and you can upgrade upto 4GB...
    Sep 28, 2008 | Intel D865GBF Motherboard
    Amd sempron 2800+
    i want AMD Sempron(tm) processor 2800+ free downloads driver
    May 27, 2008 | AMD Sempron 2800, 2.0 GHz 2800+...
    Computers & Internet Logo
    182 people viewed this question
    Alun Cox
    David Payne
    David Payne
