Question about HP Photosmart R927 Digital Camera
Every picture I take results in two images on my memory card. If I delete one, I no longer have access to the image.
    Scholar:
  • 152 Answers
Check the Burst setting under the Capture Menu - that can cause the camera to take more than one picture at a time. Also, check the "Bracketing" setting to make sure that is turned off. If neither of those fixes it, copy all of the pictures off the card and reformat it INSIDE the camera (use the camera's menu to reformat the card).
Also, take a close look at the files, especially the properties of each file. Some cameras store both a thumbnail AND a full-resolution shot on the card. You could be mistaking the thumbnail for another copy of the same image. The properties of the thumbnail file will be VERY small resolution, probably 120x120 pixels or some such size.
Good luck, and please rate this answer if you feel it has helped!!
Posted on May 11, 2009
I have a Nikon D5300. I can see the photo count number increasing, but I cannot view the images and they are not going on the SD card. Where are they? The SD card is not full.
many small Nikon cameras have memory to store images ON THE CAMERA. If you have a memory card installed that the CAMERA CAN READ it will put images on the card. if the memory card is corrupted the camera will not use it.
First Backup all IMAGES on Memory Card to COMPUTER make sure you saved ALL images. This is IMPORTANT.
After you SAVED all images you PUT Memory card back in camera and FORMAT it (Format is in TOOL Menu that looks like a wrench)
Now if you can take an images and it saves to memory card you are done. To see if they go to MEMORY CARD. Turn off camera and remove MEMORY CARD and Check.
If it STILL does not work you may have a defective memory card.
Feb 23, 2017 | Nikon Cameras
Delete select pictures from camera
While viewing the image, press the trashcan button. The camera will ask for confirmation of the delete.
I would recommend against making a habit of keeping some pictures on the camera or memory card and deleting others. You're guaranteed to fragment the memory, leading to camera speed loss and eventual memory corruption. The camera is an image capturing device, not an image storage device. If you need to keep some pictures on the camera, copy them to a computer, format the memory card, and then copy them back using a card reader.
Mar 18, 2012 | Canon PowerShot SD1100 IS Digital Camera
How do you delete multiple images from camera?
Are the pictures on a memory card? In that case, you're much better off formatting the card. If you continue to delete unwanted pictures, you'll fragment the card and ultimately you'll have problems. Every day somebody posts here with that problem. Formatting cleans things up.
If the pictures are in internal memory, select Internal Memory Tool from the Setup menu, and you can format the internal memory, deleting all the pictures. My earlier comments hold true here as well.
If you insist on keeping some pictures and deleting others, then go into the index (thumbnail) mode. Press the trashcan button, then select [Select] with up/down, then press *. Select images with the arrows, then press * to display the delete indicator on the selected pictures, Press the trashcan, select [OK], then press *.
May 13, 2010 | Sony Cyber-shot DSC-S750 Digital Camera
Internal memory
You can only access the internal memory, when there is no card in the camera. So, turn off the camera, remove the card, connect to the computer and save the images to the computer. After checking that images are saved, you can delete the images in the internal memory, before inserting the card again.
May 04, 2010 | Fuji Finepix Z20fd Digital Camera
If I save my pictures to the memory card Can I still delete the pictures from my phone and they will be still saved to my memory card
Yes, you can delete images from one memory(phone or memory card) if images are stored on both memory(phone and memory card).
Feb 04, 2010 | Lands Phones
How do i transfer my phone memory to the micro sd
You can store any multimedia files
on your phone’s memory in My stuff
so that you have easy access to all
of your pictures, sounds, videos and
games. You can also save your files to a
memory card. The advantage of using
a memory card is that you can free up
space on your phone’s memory.
My images
My images
contains a list of pictures
including default images pre-loaded
onto your phone, images downloaded
by you and images taken on your
phone’s camera.
My images options menu
The options available to you in My
images
depend on what type of
image you have selected. All of the
options will be available for pictures
you have taken on the phone’s
camera, but only the Use as, Sort
by Grid (List) view
and Memory
manager
options are available for
default images.
Send - Send the image to a friend.
Use as - Set the image to appear on
your phone at certain times.
Move - Move an image from the
phone memory to a memory card or
vice versa.
Copy - Copy an image from the phone
memory to a memory card or vice
versa.
Delete - Delete an image.
Mark/Unmark - Select multiple files.
Print - Print an image via PictBridge or
Bluetooth®.
File - Change the name or view the
information for the file.
Create new folder - Create a new
folder within the Pictures folder.
Slide show - Start a slide show.
Sort by - Sort images into a specified
order.
Grid view/ List view - View each
image in grid or list type.
Memory manager - View the memory
status.
Jul 26, 2009 | LG Secret ? KF750 Cellular Phone
Canon A560 will not erase pictures
Two possible solutions.
1. Apple users have reported that the switch on the memory cards performs the file lock function in either extreme positions Lock/Unlock. In some cases they have achieved success in centering the Lock/Unlock switch allowing access to the read/write operation of the memory card
2. Connect to PC
Access drive via windows explorer
Right click on drive (MEMORY CARD)
Select properties
Confirm that RO (Read Only) is not selected.
Selected RO
Try reading card
Repeat properties un-select RO
Try deleting files
If not successful card is likely defective
Hope this helps?
Mar 12, 2017 | Canon PowerShot A560 Digital Camera
Lost pictures in memory after answering "yes" in Format.
Formatting will delete all images stored on the card. They are gone
Dec 30, 2008 | Samsung L100 Digital Camera
Olympus 790SW 7.1 MP reads full 1GB memory card is full after 2 pictures
Suggestion is to format the memory card and permanently delete all of the images from it. The card should then be able to be reused and you can start taking images again. To format the card go to Menu - setup and press ok - go to format and press ok - go to yes and press Ok. This will clear the card and you are back in business.
Oct 03, 2008 | Olympus Stylus 790SW Digital Camera
Need to delete memory
You need to remove the memory card from the camcorder and place it into a pc or photo shops computer. This will allow you to view the saved items on the memory card. You can then save these to disc and delete the contents on the card.
Jun 12, 2008 | Optimus DV-5040 Camcorder
HP Photosmart R927 Digital Camera Logo
46 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
