WILL NOT START , EVEN USING ELECTRIC START
Could be many problems, check plug, check plug gap, check plug wire an connector, check plug to see if spark is jumping gap, if so then mag is good. Check to see if shut off ground wire is killing engine, just unplug it an try to start. Fuel problems should be checked, look for cracked fuel line, clean carb, get rebuild kit, very cheap, be careful to put back properly, clean with carb cleaner, clean all ports small an large, use small brass or steel bristles from brush or what ever you have to clean small ports. Put back together it should run. Replace lines in tank as well.
