Question about Ruud UBHC Air Conditioner
Residential HVAC - Repair vs Replace? Heat Pump? Two Stage AC?
I have a few questions regarding if I should simply repair or replace my two York units. One is 2 tons (second floor) and the other 3.5 tons (first floor). Builder grade and 10 SEER. 10 years old. Furnaces are working well.
Both units' evaporator coils are leaking and the repairs are covered under our home warranty. The house is around 2,000 sf on the first floor and 1,600 on the second floor (no basement). It seems warm on the second floor in the summer - we live in the southeast where it gets 100+ a few days a year and in the 90s for several weeks. It gets down to the 20s for a few days in the winter and the 30s for a few weeks. This summer we put a new roof on with ridgevents which may help.
Here are my options and I could use any expert advice as we plan to be in the home for around 10+ years.
1) Simply replace the coils - cost is just $65 for the warranty trip charge
2) Replace both systems with new HVAC (Heil or Ruud). One at 2.5 tons (.5 larger than current) and the other at 3.5 tons (same as current). They would also replace the coils. Cost for 410a is ~$5,000 for the two units. 13 SEER.
3) Replace both systems with variable speed two stage a/c RUUD 16 SEER Unit and high efficiency furnace. All new system. $1,500 Tax credit applies and $2K rebate from RUUD. Would be around $10K after factoring in these savings. 3 ton and 4 ton unit as it is variable speed and the units do not come in .5 sizes.
4) Same as 3 but also with a heat pump. Would be around 11K.
Note my home warranty will reimburse me around $1,100 if I get a new system instead of having them replace the coils for options 2-4 above.
Key questions. . .
Are heat pumps really worth it? I would still have a furnace for cold days, and not sure if the bang is worth the buck and if it will last as long if it is used more heavily? Are they as reliable as traditional systems?
Does it concern anyone if I go with a two stage a/c at 3 tons upstairs and 4 tons downstairs. That is quite a bit more capacity, but we would like more cooling than we currently have. I fugure the unit would run more at the lower speed and in the hot days the extra cooling would be ideal. Does this seem logical to any experts?
Any concern with RUUDs upper end systems?
Lastly, do you think we have to get new line sets for the 410a or can they just flush it out well and that should suffice for a 10 year old home.
Thank you so much for any advice you can offer. I am a novice at this and could really use your help! Again, THANKS!
  • 116 Answers
For 65 dollars i would replace the coil I do however love gas and heat pump combos it will cut your gas bill by about 75% only uses gas below 30 deg
you may want to try a honeywell 8000 stat it has random circulation fan comes on and just circulates the air also used for gas hp combo with an out door sensor and you don't need the fossil heat kit as for the copper if possible replace it due to don't trust any ones soldering as for units the are all about the same look for warranty some replace unit others have life time comp if only going to be in house for 10 yrs hard to recover cost give replacement allowance when sell
Posted on May 11, 2009
  • mike bare May 11, 2009
    another thought would be to put in a r22 out door unit 13 seer heat pump this really saves on gas use to go with your new coil they should get cheaper as the r 22 goes away the nu22 replacement gas works fine the new coil may be also rated for 410 try the 8000 stat you will love it seems that you have a good knowledge on hvac you could change it out your self and save some money good luck and thanks for a good rating
I have a ComfortMaker SoftSound 1000+ model CAC036akc4. Is this a heat pump model. I'm trying to install a nest thermostat and can't get it to work.
The model number you provided is for a 3 ton a/c only. Not a heat pump.
If you are installing a digital thermostat, the problem may be in the configuration menu. It will have to be told what system you are asking it to control....1 stage heat and 1 stage cool would be the standard residential hvac system.
Make sure there is a jumper between the terminals Rc and Rh to make sure both heating and cooling cycles will work. There should be a dip switch on the sub base to select either electric heat or gas heat. Verify all your wiring connections are correct. Thermostat connections: Rh terminal is 24v power for the heat cycle. Rc is the 24v power for the cool cycle. W terminal is the heat connection. G terminal is the fan control connection. Y1 is the a/c connection. If you have a "C" connection, that is the 24v common connection that should be connected to the control transformers common connection in the furnace.
Dec 29, 2014 | Heating & Cooling
Can't get the gas furnace to heat.
All York/JCI thermostats made by Venstar
The setup is probably incomplete. Did you configure the thermostat for a 2 stage heat pump? The heat pump should have a thermostat wire connected to R, C, Y1, Y2, and O, that makes 5 wires. I suspect you are only using first stage compression and or first stage blower speed.
Nov 23, 2013 | Source1 CTS Series Model S1-THPU32P7S...
Pump not working, kitchen sink has overflown.
check to see if you have voltage at receptacle,if yes replace pump,if no check breakers.
Nov 13, 2012 | Dishwashers
I have a evcon eb12b heat pump, it works intermitantly on heat, ihave replaced the contactor, and have 24v at the contactor, come times the heat pump will come on sometimes it wont, The hvac repair guy...
does this unit have a capacitor that is hooked up to the motor, as it may be the capacitor or motor, of course this is just a guess as I am not there to see it. I guess you can push in the contactor a few times and make sure all is coming on like it should, might be the control board. Just a matter of pluck and chuck. Good Luck Tim
Oct 24, 2010 | Heating & Cooling
How do you replace an AC compressor on 2000 Ford Taurus
AC repair require a vacuum pump. It is not a do it your self job unless you has access to a HVAC vacuum pump. Example: Robinair brand vacuum pump and manifold meter,hoses and R-134a refrigerant.
My advice is to let the professional to do the job.
Apr 24, 2010 | 2000 Ford Taurus
No heat, got great a/c....
W1 and W2 are the differences from the single stage to the two stage. Im thinking its your thermostat is not programed for 1 heat / 1 cool. You probably had 2 heat / 1 cool before.
Oct 17, 2009 | Goodman Heating & Cooling
Heat Pump compressor replacement
thats what it takes to replace compressor. Slightly easier on residential. And price will depend on how big AC is. But 1200-1600 seems right
Oct 08, 2009 | Heating & Cooling
Heat pump wiring
yes i can , you need to hookup the r and the o together so that the reversing vvalvce is allways energized . so with that im mind send r,y,c,o to theout side unit. at the ahu you'll hook up the 5 wires for the furnace, r g w1 w2 com and at the thermostat r,w1,w2,y,g,com,o then you will be set (the o get hooked up to o and goes straight out side.
Dec 03, 2008 | York Yankees Bedding MLB Comforter
Ruud UBHC Air Conditioner Logo
658 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
