Question about Amana D545M Dehumidifier
AmanaD545M Runs but no water comes out
Took the back off. The compressor is running but is extremely hot. Coils are warm. Is the compressor bad. The appliance is less than 3 years old and only used from May to November each year. Purchased 7/3/06.
If the compressor is running and the coils dont cool, then you have a refrigerant leak or a plugged capillary tube. it would cost more to fix than to but a new one. sorry but its time for a new one.
Posted on Jul 31, 2009
Has there been a recall on this product? My compressor seems to run but no water is collected. I took the back cover off and the compressor is extremely hot and I know that other Amana dehumidifiers were...
Your description indicates a loss of refrigerant in the dehumidifier. The metal heat exchanger above the water collector should become cold when the compressor is running - if it does not, your dehumidifier likely has lost it's refrigerant charge. You will have to take it to a certified (refrigerant handling) technician to repair. It may make more sense to replace with a new dehumidifier.
Check the CPSC website for dehumidifier recalls. they will have details of the brands/models/serial numbers of recalled units.
Oct 23, 2013 | Amana D545M Dehumidifier
The compressor on my Danby dehumidifier turns on for a few seconds, very weakly, and quickly cuts out. The fan and control panel are all working properly. The humidity is high enough for it to turn on...
Sounds like you've lost a lot of freon. Find the pump on your unit. Be careful, but after running it a while, touch the tube somewhere between the pump and cooling coils. If it is not hot then you have lost fluid. What happens is under normal working conditions the compressor would compress the freon making it hot, which then gets cooled by the radiator coils. In your case, there isn't enough fluid to compress to make it hot. Unfortunately, you need to have it refilled by a repair shop. Try your local A/C or HVAC shop. Don't be surprised if they can't refill with freon as it's bad for the ozone and being phased out.
May 04, 2011 | Danby DDR586R Dehumidifier
Fan runs ,coils are room temp. should they be hot or cold , no water is collecting in bottom
A dehumidifier is basically an air conditioner, so some coils should feel hot, the others should feel cold.
If no water is collecting, then the unit's compressor is not starting. Typically you have four possible failures causing this: the switch/wiring for the compressor has an open circuit, the motor-start capacitor for the compressor has failed, the compressor itself has failed, or all the refrigerant has leaked out.
If there is evidence that it is 'trying to start', but then clicking repeatedly, this can be a symptom that the refrigerant has leaked out, as some devices have a pressure switch to prevent compressor damage.
Also, a failed start-capacitor can also cause the click-click noise if the device has a current limiter switch on the compressor.
So the short answer is, it's broken :)
Oct 21, 2009 | Whirlpool AD25BBK Dehumidifier
Motor runs fan works does not produce water and black tank in back (compressor?) is very hot
Make sure that the coils of the evaporator are clean, and that the unit is getting proper airflow across the evaporator and condenser coils. Hope this helps
Sep 25, 2009 | Fedders A7DH45B2A Dehumidifier
Runs but does not collect water.
compressor run but gas charge not enought
so it not very cool,and no water come out
Aug 23, 2009 | LG LHD45EL Dehumidifier
Frostguard 36 Dehumidifier runs, but collects no water.
unfortunately it sounds as though your refrigerant leaked out. If your compressor is running and no moisture, this is probably the case. What is the temperature of the air coming out?
Jun 20, 2009 | Woods Dehumidifiers
Dehumidifier Brand haier HD456E does not pull water and the tank is empty, after 24 hours of running with water on wood floor. Can't find manual or online info for this model.
I have 3 HD656E Haier Dehumidifier with the same problem runs but no water in bucket. How many did the Haier company make with this problem?
Apr 12, 2009 | Haier HD656E Dehumidifier
Not working
Hate to tell you, but it may be a goner. Many units have a rectangular air filter that may be clogged, but I would still expect to see some moisture removal. Without exact model I'll have to be general,.... remove cover (front or back, depends on model) to see cooling coils. If the compressor is running, these coils should be wet or may have a light frost on them for a time. Not = refrigerant leak. (not economical to repair) If you see one small area of ice,... it's also a goner. If the compressor does not run you could have a bad compressor, a bad defrost control, or a bad control / humidistat. Other than the filter or possibly a fan motor, these unit are rarely economical to repair.
Aug 27, 2008 | Dehumidifiers
Kenmore dehumidifier runs but won't collect water
If you haven't done so already, try removing and cleaning the inlet filter screen which is almost certainly just behing the inlet grille. It may slide upwards out of the casing or downwards unto the bucket area. If this is blocked with fluff then no moist air will get to the cold pipes, so little or no water will be extracted. There's also a chance that the humidity sensor is clogged with fluff, so fooling the system into thinking the room is pretty dry, in which case the compressor will probably not run.
A running compressor can usually be detected as a deep throbbing from the machine. If it is running, but not cooling the pipes behind the intake grille, then you may have lost the refrigerant from the system via a leak. If the air coming out of the machine is warm (caused by the compressor running) but there is no water produced this may be the cause.
Explore along these lines and let me know what you find.
Cheers, D
Jul 31, 2008 | Dehumidifiers
Running but not collecting water...
Dehumidifiers have only a few components, and operate on the same principle as a refrigerator, freezer, or air-conditioner.
Components Residential dehumidifiers have a cooling system made up of these primary components:
  • The compressor is the quiet motor (engine) of the cooling system. It's the black, football-size component at the bottom of your dehumidifier. The compressor runs as long as the dehumidifier humidistat (the humidity-sensor) calls for a reduction in the humidity.
  • The condenser is a series of finned tubes, similar to a radiator. It's usually near the circulating fan.
  • The evaporator is located near the back of the dehumidifier, right above the water-collection container. It also resembles a radiator or a coiled-up set of tubes. When the dehumidifier's humidistat senses increased humidity, it cycles on, which starts the compressor and circulating fan.
  • The circulating fan circulates the air over the evaporator and condenser coils.
Principle When the unit runs, the circulating fan and compressor also run. The fan continually draws room air over the evaporator coils, which are cold, and then over the condenser coils, which are warm. Because the evaporator coils are cold, the moisture in the room collects on them--just as the outside of a glass of icy liquid "sweats" on a warm, humid day. When the moisture on the coils increases, it drips off of the coils into the collection container.
The air then flows over the warm condenser coils and out into the room. This process removes water from the air and, because of the heat from the fan motor and compressor motor, the exiting air is somewhat warmer, as well as dryer.
Jul 29, 2008 | Maytag M7DH65B2A Dehumidifier
Amana D545M Dehumidifier Logo
191 people viewed this question
Top Amana Dehumidifiers Experts
jasbo
jasbo
Gil Shultz
Are you an Amana Dehumidifier Expert? Answer questions, earn points and help others
