Question about Garden
Belts will not turn the blades
Belt will not turn the blades
  • sissy64impal May 21, 2009
    I belt keeps coming of and will not engage blade. While mowing it stop and starts cutting grass.
  • 246 Answers
Hello:
Have you Checked the Linkage from the Engagement Lever to the Blade Idler?
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
John
Posted on May 11, 2009
I have a 17.5 HP Yard Machines,8 speed shift on the go, 42'deck. Worked fine last year, The year, blades would not turn, engine pulley burned up the belt. Replaced the belt, did not solve the problem.
take the belt off and be sure the pulleys turn freely. sounds like you mowed through water and they may have some rust on them or the bearings in the spindles are bad. just take the belt off, turn the pulleys and find the one that is bad and repair it.
May 21, 2017 | Mtd Garden
I have a 52" Husqvarna LGT 2654 riding lawn mower and when I engage the blades, the belt does not turn the pulley system. What could be causing this, the pulley idlers, or the belt?
depending on the age of the machine, there could be several possibilities
1-- belts are not tight enough--- belt tension system is not correct, wrong length belts
2--bearings for the shafts for the blades are rusted up and seized - preventing the blades from moving--- switch the machine off , disengage the belt drive and see if you can turn the blades by hand
3--- if you have an electric pto system to drive the belts to the blades then that system is not getting full power to engage the PTO or the clutch is not working--worn facings
take it to a service dealer and have a proper diagnosis done
May 09, 2016 | Husqvarna Garden
What will cause blades on J.Deere G100 mower to Freely turn by hand without causing Spindles or belt to turn even though Bolts are still tight and when installed Blade turned only if spindle turned
Do Ray:
If the blade engagement lever is in the disengaged position, the belt will be loose, allowing you to turn the blades by hand. If you place the blade engagement lever in the engaged position (with the motor off) it will be hard to turn the blades because of the tension on the belt. If the blades are still easy to turn with the blade engagement lever in the engaged position, you need to replace the blade drive belt!
Jun 15, 2015 | Garden
What is tearing up my deck belt rz4621 zero turn husqvarna
Philip:
Could be one of a few problems. Easiest... disengage the blades (engine off) and try to turn the blades by hand. If any blade is hard to turn your blade spindle(s) need to be serviced or replaced. Look for the belt tensioner, and see that it is not loose or out of alignment. Check all of the pulleys for damage. Make sure that you have the correct size belt! If you are mowing very heavy growth, you may be stopping a blade while mowing, and that will eat up a belt in a hurry.
Jun 15, 2015 | Husqvarna Garden
Mower blades won't engage
Did the smoking stop when you disengaged the blades? If so it is most likely your belt that is smoking. Make sure all the blades turn freely by hand to ensure you have not hit anything that may have bent a shaft on one of the blades. If one of the shafts is bent and wont turn FREELY, the belt driving the blades would slip and start smoking as it tried to turn them.
Apr 19, 2015 | Garden
When deck is lowered blades do not engage
Is the belt in place that drives the blades?
Is the belt at the correct tension?
With the mower engine off.....try to turn each pulley the belt drives and on the mower deck with the mower in up position and or down....do they turn a little......this is to check for a seized bearing on one of the pulleys also look under the deck for something stuck........ jamming a blade.
Also check for the mower belt safety system (which stops the blades quickly when disengaging them) that may be stuck in stop mode.
With the mower engine running.....have some one engage the blades while you look under at the belt system....is the engine driving the belt.....is the belt driving the blades.
DO NOT TOUCH ANYTHING......MOVING OR STOPPED while the engine is trying to drive the blades.
Sep 06, 2009 | Mtd Garden
My john deere lt 133 mower with a double blade mulching deck, 1 blade stopped working and only 1 blade cuts now, how do i fix this. Thanks Patrick
This model mulching deck uses a flat/ribbed serpentine belt that is set at very high tension.When belt breaks under the cover only one blade will turn due to IT being driven from PTO clutch as the other blade being turned from serpentine belt.This deck was Deere's first and last shot at making a true mulching deck and only made it a couple years.When you buy the VERY expensive belt it will come with detailed instructions on how to install it.Goog luck.
Aug 07, 2009 | Garden
My blades wont engage and just hear click sound?
No permanent solution, but you probably can get by once by "riding" the clutch engagement lever - pushing it only part way forward and holding onto it.
Jun 27, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Blade on off
Make sure your belt guides aren't to close ,and not allowing
the belt togo free
Aug 30, 2008 | Garden
Garden Logo
85 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
