Question about Mitsubishi WT-42313 42" Rear Projection HDTV-Ready Television
TV has halo effect on the screen
My tv still gets a picture on the tv but has a halo type effect on the screen. Didn't know if that has something to do with the projection part or what.
  • the350stud May 15, 2009
    Model - WT-42313
    Make - Mitshubishi
    Master:
  • Mitsubishi Master
  • 688 Answers
    Problem Solver:
  • 13 Answers
It sound's like have a convergence problem send me d model and make of d tv
Posted on May 11, 2009
  • Bobby Davis
    Bobby Davis Apr 28, 2015
    I got same problem with my tv model# D52W20 RCA 52"
  • Bobby Davis
Philips 43p8341/37, The menu does not appear on the screen when selected by either the remote or the unit, also the picture is bowed at the top and the bottom of the screen making the center of the...
The board you will be working on is the signal module. The signal module is the board on the floor of the TV. When you locate the RCA connections and the RF connectors on the back of the TV, you will know that you are where you should be. You will see two large silver fins, these fins are heat sinks and two ICs are attached to them. They will be STK-392-110, and both will need replaced. Also check and measure the 6.8 ohm 2 watt resistors next to these ICs just mentioned. Should be ten or eleven resistors. Replace as necessary. The next problem you describe is a halo effect on the screen and no menu on screen. You will need to replace contaminated fluid in one of the picture tubes. You will find three picture tubes, lit, they are red, green, and blue. I would suspect the blue has the contaminated fluid. You may look in the tubes and decide which one is cloudy. For more detailed instructions and photos, I would suggest you see the website, www.TvRepairKits.com. H ave your TV model number and symptoms near by. You can purchase a kit or kits to restore your TV. The instructions are very detailed along with photos as how to repair. Thanks for asking and show all hands of support!
Mar 30, 2011 | Philips 43P8341 43" Rear Projection...
The Color On My Mitsubishi Rear Projection Tv model- WS-55908 looks to be off, picture looks blue and Yellow.
its sounds like the convergence on your TV needs to be adjusted. (this adjusts all of the color guns in the back of the tv to line them up again, when they get off, you start to get yellow blue or red halos around objects in the picture. In the setup menu on your TV under picture or Display there will be an item that says "convergence" follow the instructions in there so all the crosses on the screen no longer have colored halos anymore.
Mar 10, 2011 | Mitsubishi WS-55908 55" Rear Projection...
I have a Hitachi Projection TV 51G500A 2004 ,
These sets have several common problems which are listed below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 03, 2010 | Hitachi 51G500 51" Rear Projection...
Hitachi projection hdtv has 3d effect and bowed shape
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 15, 2009 | Hitachi 53SWX01W 53" Rear Projection...
Bush RFT TV
The picture tube of the tv has 3 color in CRT Red, Green, Blue. The red cathodeof tv set has no function, its either the resistor become higt resistance, that why u need a repairman to replace it.
Apr 10, 2008 | Televison & Video
Bush RFT TV
try the thermistor degauss coil,
Mar 13, 2008 | Bush 5693D 24" TV
Foggy HD projection TV
I think your refering to the CRT colant needing to be changed if it has a halo effect on the blue and green colors Also some times your picture can get dingy because the mirror gets dull. Try cleaning the mirror and tube lenses. Use a damp soft cloth on the mirror and lenses not windex.
Jan 20, 2008 | Televison & Video
Yellow corners on 56" RCA Rear Projection TV
possibly cleaning of the lens and the mirror might improve the picture. it could be what is termed a glycol or fliuid issue. dirty glycol will cause this yellow halo effect. the glycol came be changed a rather expensive and evovled repair i think
Jan 15, 2008 | RCA P46810LV 46" Rear Projection...
Mitsubishi VS-50703 blurry after move
A halo effect usually means the coolant in the CRTs need replacing in the effected color usually blue goes first followed by green. red seems to be less prone for some reason.
Jan 14, 2008 | Mitsubishi VS-50703 50" Rear Projection...
Mitsubishi WT-42313 42" Rear Projection HDTV-Ready Television Logo
385 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
