Question about Philips 37PF7320A 37 in. HD-Ready LCD Television
My Phillips flat screed TV model # 37PF7320A 37 won't turn on. When I press the power button the indicator light blinks 1 long red then 4 short. I tried to change both of the fuses but I couldn't find the ceramic 5M so I substituted with a glass 5 M. Could that be the problem because it hasn't solved the problem. Any suggestions?
  • 1 more comment
  • jumper14 May 18, 2009
    Your post is identical to my problem: On power up attempt green light shows; five seconds later a ''click'' sound heard; system goes to standby red flasher. Sequence is one long and four short flashes repeating. Nothing recommended to date will allow the tv to respond in a positive manner to remote or onboard power switch. Set about year old. Tried power disconnect, disconnect from cable box, channel changing, you name I have contacted Philips and will advise...
    Your post is identical to my problem: On power up attempt green light shows; five seconds later a ''click'' sound heard; system goes to standby red flasher. Sequence is one long and four short flashes repeated. Nothing recommended to date will allow the tv to respond in a positive manner to remote or onboard power switch. Set about year old. Philips no help! Tried power disconnect, disconnect from cable box, channel changing, SadinskyML@aol.com Charlotte NC 5.16.09
  • ESTEBAN MERINO
    ESTEBAN MERINO May 11, 2010
    HELLO MY FRIEND SINCE YOU OPEN THE SET. DO YOU KNOW WHAT IS A CAPACITOR, I WILL LOOK FOR SWALLEN CAPS. SOME TECHS CALL THE PREGNANT CAPS.
    GOOD LUCK
    CAYPIANAN@YAHOO.COM
    Problem Solver:
  • 17 Answers
Common short the cover cap over the video & sound boards short out if you remove it the cap only (shield metal) it usually will fix this i have the same tv it works like new
Posted on May 13, 2010
  • Todd Hill
    Todd Hill Jun 01, 2011
    r3318 100 ohm pwr supply
Philip tv no picture no sound
I have the model Philips 37PF7320A/37 won't turn on and MOST articles on the Internet say it's the Capacitors capictors capictors..I checked all of them. My tv just blinked red lights, had the clicking sound at first power on, but then goes black. No sound. No picture. Nothing. Just blinking red lights.
MINE WAS RESISTOR no. 3318 , a 100 OHM RESISTOR ON POWER SUPPLY BOARD.
I BOUGHT REPLACEMENT FOR .99 CENTS SOLDER IT, AND EVERYTHING WORKED!!!
THAT WAS ALL IT TOOK.
JUST A SUGGESTION..
1. CHECK FOR BULGING CAPACITORS (90 PERCENT OF THE PROBLEM)
2. THEN CHECK FOR RESISTORS WITH MULTIMETER ( FALLS INTO THE OTHER 10 PERCENT OF THE PROBLEM.)
TELL ME IF THAT HELPS..normanw1@yahoo.com
Oct 30, 2011 | Philips 52PFL7422D/37 TV
Philips tv model number 50PFP5332D 37 wont power up
JUST A SUGGESTION..
Oct 30, 2011 | Philips 50PFP5332D 50 in. Plasma...
Screen goes black but still sound
JUST A SUGGESTION..
Oct 23, 2011 | Philips 37PF7320A 37 in. HD-Ready LCD...
I have philps 37pf7320a/37 blinking 1 long 4 short red. what could it be the issue?
Need to check the electrolytic caps on the main power supply,for bad or bulged caps, and replace them , or just replace the power supply.
Jul 08, 2011 | Philips 37PF7320A 37 in. HD-Ready LCD...
I have a 37" Philips (37PF9431D/37) flat panel tv. It won't power on. When you plug it in you can hear a click the green light stays on for a few seconds then goes out. I've checked the power board for bad...
i am having the same problem. My Phillips 37" 37PF9431D/37I LCD High Definition TV won;t turn on. When I press the power button i hear a click and the green light comes on for a couple of seconds and then the red light appears. I can;t figure it out. Did you find a solution?
May 20, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
I have a 37" Phillips LCD TV. it will not turn on and the light that used to show green (to signal the tv on) now blinks red. What does that mean?
how many times does it blink red. the will help determine whats wrong. Most lightly its going to give you 6 or 7 blinks whick points to the power supply this is sometimes a false indication to the ssb/signal board being bad. you coulb try the parts or have a tech come out and verify which is the problem.
Apr 27, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
No picture or sound just six red blinking lights
Use your warranty in a hurry before it expires. Your TV when into protection mode to prevent further damage. Most TVs have a 1 year warranty. Good Luck.
Jan 24, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Blinking Red Lights
Sound like an error code 14 (Audio supply) is beeing blinked...
You probably would want a qualified technician to take a look at it.
Jan 16, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
That blinking led is an error code for the audio standby board in the set. It should not go out this soon and yes it should last longer.
Aug 21, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Phillips 37pf7320a 37in.hdtv-ready lcd
The TV is in some kind of protection mode, the blinking LED show you an error code.
Try pressing 062596 and then press menu button (do these in quick motion, don't let them to time out while keying)...see what happens
I also heard that this problem appeared with some people because the of the burnt fuse in the TV. To fix that it has to be taken to the tech shop. mecry.gif
And yes I also heard about this issue many times, seems like this TV set is very popular with this kind of problem.
Oct 16, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips 37PF7320A 37 in. HD-Ready LCD Television Logo
498 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
