Question about Cameras
I want to configure my IP camera
I need the Soho IP camera driver to installmy camera with D-link router
    President:
  • 272 Answers
It's available for download here:
http://www.intellinet-network.com./en-US/products/8118
Posted on May 11, 2009
  • rjbeg123 May 11, 2009
    If my solution helped you please rate me!
I cant view vivotek IP7135 from internet
.Probably you need to set your router to port forwarding. Use these guides to help you learn how to forward ports for well known applications such as uTorrent and Minecraft, as well as any other application or program you would like.
Start by selecting your router manufacturer from the list
Apr 09, 2013 | Computers & Internet
Tip
How to configure a Router?
How to determine the WAN configuration or Interntet configuration of a SOHO Router?
1. Connect the computer to the Modem via Ethernet cable. Make sure you are able to going online 2. After confirming you are online. Go to Start->Run. Type "cmd" on the Run window. 3. Type "ipconfig" on the command prompt or Black window or DOS window 4. You will be getting IP address,Subnet Mask and Default Gateway
There are 4 possibilities of IP address you can get
i)Public IP address under PPP adapter. -Router has to be configured in PPPoE mode to get a WAN IP. This will require a Username and Password from ISP ii) Public IP address under PPP adapter and Private IP address under Ethernet adapter -Router has to be configured in PPPoE mode to get a WAN IP. This will require a Username and Password from ISP iii)Public IP address under Ethernet adapter -Router has to be configured in Dynamic IP or DHCP mode to get a WAN IP -If it is still not getting a WAN IP address. * Click Mac clone on the router's WAN configuration * Power-cycle modem and Router. iv)Just a Private IP address under Ethernet adapter -Router has to be configured in Dynamic IP or DHCP mode to get a WAN IP -If it is still not getting a WAN IP address. * Power-cycle Modem and router.
After determining the WAN mode, it is time to configure the Router
1. Connect the Modem to the WAN port of the router. Connect the computer to the LAN port 2. Go to Start->Run. Type "cmd" on the Run window. 3. Type "ipconfig" on the command prompt or Black window or DOS window 4. You will be getting IP address,Subnet Mask and Default Gateway. The Default Gateway will the IP address of your router 5. Open a Web browser and type http://192.168.1.1(where this is the default IP of the router. This will be different from each manufacturer) on the address bar. 6. Go to WAN settings or Internet settings and select the options based on the above mentioned possibilities
on Aug 26, 2010 | Computers & Internet
How do i split out multiple static ip's
You need to attach a DHCP-server to the hub/switch, and configure that DHCP-server to "reserve" a specific IP-address for the MAC-address for the network adapter inside each of the computers that is to receive a "static" IP-address.
For a DHCP-server, you can connect a "cross-over" Ethernet cable from one of the switch-ports to one of the LAN-ports on any "home" wired router. That "home/SOHO" router will become the DHCP-server for all the computers connected to the switch.
Nov 19, 2012 | Linksys Computers & Internet
I am trying to download and install drivers for my dlink dir 615 router but i cannot seem to find them. and install them. HELP??
You can configure it with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi Then save settings and restart router Then connect cable from internet service provider to WAN port of router and connect ethenet lan cable from computer to lan port of router. . Let me know if you need further assistance. Thanks for using FixYa.
Dec 11, 2010 | D-Link Computers & Internet
My computer is telling me "limited or no connectivity." I spoke with my cable company and they said everything was ok on their end and to check with my modem. what should I do?
This error comes when there is same ip address in 2 computers.
So make sure in networks there are not same ip address.
You can also solve this issue with DHCP .
Enable DHCP in router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
Enable DHCP if you want to get ip from router.
Then set "ip get automatic " in network adapter property.
Mar 11, 2010 | HotBrick SoHo 401 Firewall
How to set Static local IP Address for D-link DCS 5220 IP Camera? Am using Linksys WRTG54 Router, with SSID & WPA. I had set the D-Link DCS wireless to use the same SSID and WPA, but once I plug out...
To set a static IP on the camera, do the following:
1. Chose an IP address for the camera that is outside your normal DHCP range but within your network subnet.
For example, if your router uses DHCP and gives out addresses in the range of 192.168.1.1 up to 192.168.1.10, you should chose an IP address beyond that (e.g. 192.168.1.20).
2. Login to your camera's current IP address and go to Setup -> Network setup
3. Turn off DHCP and type in the IP address that you chose into the configuration.
4. Restart your camera.
The above should fix your Static IP address question.
With regards to your Wireless question, you should make sure of the following:
1. Your router is set to broadcast its SSID
2. Your router is setup to use WPA (not WPA2)
3. Your AES password in the camera config is the same as that as the routers
Hope this helps
Nov 24, 2009 | D-Link DCS-5220 Network Camera
What is the default ip address of D-Link DCS-3220 ip cam ?
Hello
The D-Link DCS-3220 have DHCP, that means it gets a automatic address from your router.
IT doesent have a STATIC ip, if you not set it manually.
To configure your D-Link DCS-3220 CAM and find the IP you need to install this program.
Install Wizard You need to unpack it first.
Connect your computer and cam to same router and run the program. Then it should find your cam so you can configure it and see what ip it get your you set.
Then you can browser to the cams IP.
Here is the manual and instruktions for you CAM
Here is Quick install guide
Here is you Dlink cam site to get firmware updates and more.
Hope it works.
Jul 09, 2009 | D-Link DCS-3220 Network Camera
SECURITY CAMERA SYSTEMI
Have you setup a Virtual Server within the D-Link router? This should be on the ADVANCED tab in the D-Links Admin Configuration interface. Upon setup, the router should allow pass through of your request to the network connected device.
You will need the following in this configuration:
Name of device: SSC21WEB (or whatever the name of your device is)
IP Address: 192.168.0.101
Protocol Type: TCP
Public/Private Port: 10000 - 65535
Schedule: Always
Good Luck...
Oct 08, 2008 | Samsung SSC DVR Digital Video Recorder...
Problem with IP Surveillance configuration
Can you view the stream in IE or IP surveillence or is it that you hit the camera in IE, the sign in box shows up (cause you put in a pasword), you put in the password, and it cannot connect and says retry.
Possible problems.....
The IP you are typing in is really not the IP of the camera (comes from the box being checked that says 'reset the IP on reboot') Use the installation Wizard to find the camera and it's IP.
Your firewall is blocking the stream. Try disabling it and reconnecting.
Your cameras IP is not in the range of the DHCP server of the router it's connected to. Review your router's DHCP list to see if the camera IP is in that range.
The password on the camera is corrupt. You will need to hard reset the camera and reset it back up from scratch to connect.
Worst comes to worse, you can always just hard reset the camera and start over.
Apr 05, 2008 | D-Link DCS-3220 Network Camera
Help with installing a sonicwall soho tzw no software.
Hello dlewis2900, What I want you to do is to reset your router by locating the Reset button on the back of the SOHO TZW next to the LAN connection. Using a pointed object, press and hold the Reset button for 5-10 seconds. All settings are returned to the factory default settings including the password and the default LAN IP address of 192.168.168.168. The I want you to reenter your ISP information and configuration settings. Once this is done try to ping your gateway (ISP gateway router) address. Then try to ping the internet try to ping this address: www.dslreports.com This is the quickest way to get back to where you want to be without trying to redo a lot of configurations.
Sep 03, 2007 | SonicWALL TELE2 Firewall
Cameras Logo
47 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
