Question about Car Audio & Video
1991 Ford Taurus SHO high-level audio system troubleshooting
I have a 1991 Ford Taurus SHO with a high-level audio system [stock]. I bought it used within the past month and the stereo does not work. I can hear static through the speakers when i turn up the volume all the way and turn up the treble. I have checked all of the fuses i know about. what could be wrong?
    Novelist:
  • 149 Answers
Look into your owners manual and find the fuse diagram-it may be that your sound system has 2 fuses for the audio system. I had the same problem in my explorer with the "premium" sound system -and it was a fuse-one said radio etc. and the other said audio system-so im guessing that one ran the deck and one ran the amp-anyhow i changed it out and it worked fine-hope that helps ya
Posted on May 12, 2009
I am looking for 2007 Ford Taurus SHO or SES
Ford didn't make the Taurus sho in 2007. The sho were made between 1989-1999 and then 2010-present. In 2007 the Taurus was only offered in SE and SEL trim.
Nov 28, 2015 | Ford Cars & Trucks
Where can I get a fuse box diagram for a 1990 ford taurus sho?
The Ford dealer has a book called an EVTM(Electrical Vacuum Troubleshooting Manual). It has the diagram and they will usually make you a copy of it for no cost.
Mar 22, 2011 | 1990 Ford Taurus
COOLING CAPACITY FOR 1993 TAURUS
1993 FORD TAURUS 3.0L 6-cyl Engine Code [Y] SHO
Engine oil, with filter..........4.7 liters
Cooling System, Initial Fill..........11 liters
Good luck and hope this helps, thank you for using fixya
Nov 04, 2010 | 1993 Ford Taurus
I have a 93 taurus sho. it was running fine and now it won't start. any advice would help, also need to find where i can get a owners manual so i know what fuses go where on the fuse box.
try hitting the gas tank with a piece of wood,the fuel pump may have started going bad and by hitting it loosens up the pump so it might work a little enough to start it.Then you will know if thats the problem for sure.I had this problem on a friends 1991 SHO
Feb 22, 2010 | 1993 Ford Taurus
Will a transmission #ax4s from 1988 ford windstar fit a 200 windstar with transmission # ax4s
I dont think that will work ....1988 was aod and aode trans
The AXOD-E was renamed AX4S in 1993. In addition to the name change, improvements in the lubrication of the gearset and capacity upgrades were made. A centrifugal piston assembly was implemented in the intermediate clutch position to improve 1st-2nd and 2nd-1st shift quality and an increase in the clutch's durability was made on some models. High energy friction materials were also introduced. A new twin piston torque converter clutch (TCC) was introduced with the AX4S and the AX4N on some models. The transaxle pan on this model will sometimes read "AXOD Metric" since it's based on the AXOD transaxle. The data plate code for this transmission is "L."
Applications:
The Ford AX4S automatic transmission is a four-speed electronic overdrive transmission used in 1995 to 2000 Ford Windstar minivan. The transmission is also used in 1991 to 2003 Ford Taurus and Mercury Sable, and 1993 to 1995 Ford Taurus SHO models. The AX4S is a second-generation version of the AXOD and AXOD-E transmissions used in 1986 to 1991 Ford Taurus.
Nov 16, 2009 | 2001 Ford Windstar
Where is the fuel filter located on a 1991 SHO? Is the line pressurized?
Underside of right rear frame rail, yes it is pressurized.
Oct 30, 2009 | 1991 Ford Taurus
How do you replace a cam sensor on a 1991 ford Taurus SHO?
wwith a haynes svc manual or other-u can also chec out the chilton books in library auto sec-its probly not hard to remove cause the cam is top of engine-may want to don some glovs,locate it ncarefully rench it out
Sep 18, 2009 | 1991 Ford Taurus
99 taurus won't start,power windows,locks
CHARGING CIRCUIT NOT WORKING PROBABLY ---CHECK THE BATTERY CONNECTIONS FIRST
THEN NOTHING ON OR W NEG CABLE DISCONNECTED CHECK THE aLTERNATOR WIRE CONNECTION
OR THE COIL MAY BE WORKING IMPROPERLY TOO
OR YOU GOT A BATTERY WITH WHAT'S CALLED A DEAD CELL--BRAND NEW
IT HAPPENS ---IF YOU GOT IT AT AN AUTOPARTS STORE OR CAN GET TO A aUTOZONE OR
aDVANCE AUTO --they should be able to test it all if you don't have a volt meter with a dc setting
there is a way to field test the alternator easily --but you need the volt meter --one red lead goes to a Grounding cut on --small in the back of the alternator and the black to a good ground I use the battery neg or a bolt on the engine accessory bractets ---you insert the red lead probe into the
ground plane slot --while cranking needs to exceed 13volts to considered charging
or you can use a Clamp on meter on the positive wire coming from the alternator too
I have the 97 SHO ---3.4 v8 ---now that's a hand full
I did have a 99 merc mystique albeit identical to yours though
My SHO alarm system will slowly drain off the battery to when left parked for a week
probably a short to ground or slow draw bleed off ---I haven't even tried to track it yet
I leave it parked --due to law enforcement harassement and I've had a clean license forever
just can't drive to or from without being harassed and it's 100%stock
ford in 2010 launches the 365hp twin turbo ecotec V6 with all wheel drive ---but I already know
ford techs --won't fix them right when things go wrong and they will --heck they won't change
the oil in a late model sho v8 ---"Not Qualified" or 'Not allowed to per ford corp mandate sorry"
No Dealer service available to date --I've been to 27 dealers for service when traveling =no dice
had to go to Lexus for an oil change --Kudos to Lexus
HAWK
Apr 06, 2009 | 1999 Ford Taurus
1995 Ford SHO
your best bet for a diagram is to ask for a suspension printout at your local dealership. Or take a look under any 86-95 Ford Taurus SLO, SHO, or Sable and they use the same design (the SHO just uses slightly different parts. Here is a link though for a SHO parts list with part numbers. Hope this helps.
http://members.bellatlantic.net/~rbruce/SHOParts.htm
Mar 12, 2009 | 1995 Ford Taurus
Car Audio & Video Logo
111 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
