Question about ViewSonic N2750w 27 in. HD-Ready LCD Television
Why do compoenent cables look blurry?
When I hook my ps3 or 360 up to this tv using component cables, they always look very blurry, especially with a higher resolution. I set my ps3 to 1080p, but it looks incredibly blurry, as well as on my 360. So, I am forced to scale down to 720p, as 1080i is also very blurry. Why does this tv do that?
    Problem Solver:
  • 13 Answers
Hey wats up ok do u have a hdmi cable if u do hook it up and tell me if it's d same
Posted on May 11, 2009
I unplugged my cable from the back of my tv to try and hook up and Xbox... Well when I plugged the cable cord back in to the television i got a blurry white and black screen
this happenned to me before and maybe clean the area with a spray or even you need to get a new cable hookup.....these are quite reasonably priced especially with generic brands....
Jan 15, 2013 | Televison & Video
I just hooked up my Flat TV to my Panasonic VHS-DVD recorder player and the screen only shows blurry Black and White when displaying or recording, The TV itself is fine.
Sounds as if you hooked up your player wrong. If you are using a composite hook up. You should have a yellow, red and white cable. Make sure it gets hooked into the same on the TV. If it is a component connection, then RED, Green and Blue. It sounds like you have your Yellow composite going through your Green component. If by chance your TV is a new Sony, then you might have to go into the user menu and turn component off and composite on.
Apr 05, 2011 | Televison & Video
The picture quality on our WD 52528 is horrible - dark, blurry, and hard to see picture at all if not looking at the tv straight on.
Your satellit receiver should have the capability to hook to your TV either by using HDMI cable out from sat unit to HDMI in on TV. This sgould give you sound and audio, or it should have component output which is a series of three cables red, blue and green.The component cablesdon't provide audio so you have to use digital optical or composite cables for sound. Whos satellite box are you using?You should be able to press your menu and get into "system set up" and, there should be an option for HDTV. Go for the highest resoulution(1080 And a ratio of 16 x 9. You tv manual should tell you about screen set up. Let me know
Dave
Apr 04, 2011 | Mitsubishi WD-52528 52" Television
We just bought a new 32" panasonic led tv. Hooked everything up and works fine with normal television broadcast. However, we have a Sony DVD/VHS combo hooked up that doesn't perform well. When we play...
If you are using the composite cables (RWY) make sure the red and white are plugged into the audio jacks and NOT the component cable plugs (RGB.) If you have the red audio cable plugged into the red component plug this will cause issues, especially with the sound.
Aug 10, 2010 | Panasonic Televison & Video
Why is my LED TV blurry using coxial cable input
HDMI, Component Cables are recommended for hifg definition viewing. coax has many strands of copper wire with a sheathing around it of aluminum foil. at a distance of a few feet it can easily be a bad crimped connection. but the wires with a bad ground will always cause issues.
you see, coax cables are good for standard broadcasting and normal tv sets,for a quality connectyion they havre specialhmdi cables thjat use bandwiths to send colorts along eatchother like rg and b they will easily transmit clear and stable images. coax uses F-type connectors and are prone to many problems.
but in the spirit of A DIY option. getting a cable line amplifier might just clear up the blurriness by injecting a signal boost in the line. good luck.
here is my suggestion for you a 50 dollar quick fix plug and play.
http://www.amazon.com/Motorola-Signal-Booster-BDA-S4-Amplifier/dp/B000WPGRKK/ref=pd_cp_e_1
Feb 18, 2010 | Televison & Video
I hooked up my HDTV with a HDMI cable but when I used the Audio L/R cables, I can't get any sound. I can get sound if I hook up the TV with regular cables but then I don't get the HDTV picture. Any...
You may have to go into the TV setup menu and change a setting for Sound (or Audio) that tells the TV which input to use (HDMI or component) for sound. Usually the HDMI connection will work automatically but if you connect cables to Audio L/R that may override the HDMI sound input.
Dec 07, 2009 | Televison & Video
Insignia 42 LCD TV Blurry Picture. Computer
tuner is going bad use a cable box that has hdmi or component video to bypass the tvx tuner
Jul 02, 2009 | Insignia IS-LCDTV32 32 in. Television
Blurry picture when hooked up to direct tv.Why?
try lowering the sharpness on your tv, because if the sharpness is to high it will make NonHD objects look blurry, also try changing the input cable or type of input.
May 20, 2009 | Element Electronics FLX-2610 26 in. LCD...
Blurry Screen on Panasonic CT-32HL44
I solved my problem. Apparently the RCA cables where missing with the image. So I bought some Component cables and that fixed my problem.
Dec 30, 2008 | Panasonic CT-32HL44 32" TV
No Picture, Only sound
You need to tell the PS3 that you are now using the new video method. It is still trying to output video on the yellow cable, not the component. If you go to settings>video and tell it to use component, and then switch the cables real quick, it should work.
An easier solution is to do a backup from the system menu, then a "restore" (quick restore is fine), and then power it off, hook up the new cable, and it will detect the video method when it turns on for the "first" time (since the restore).
You do have component input on your TV, and that is the input you are on when you are trying this, yes?
Jul 22, 2008 | Sony Playstation 3 (PS3) Console
ViewSonic N2750w 27 in. HD-Ready LCD Television Logo
227 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
