Question about Dell Inspiron 640m PC Notebook
I cannot login to Windows and I need to create a second partition so that I can install an OS temporarily to rescue files. However, in Windows Setup there is only one partition, which the one that Windows is installed on. I see no options for splitting this partition into two. Is there any way I can do this?
  • magian_dlc May 30, 2009
    The solution from Ekse would have been the most appropriate solution. However, I have not yet had the chance to go purchase the adapter.
    I ended up using a rescue CD to recover the files.
  • Dell Master
  • 13,433 Answers
I think a better solution would be to take the hard drive out from the laptop, buy a few dollar adapter (depends, not all drives need one, if its sata it will plug directly to your desktop computer) and connect it to your computer where you can back up any files before installing windows again.
You can also use the windows installation cd to install into another folder without format, you won't loose any files aslong as the drive has space for another windows (1-2gb)
Posted on May 11, 2009
I cant format my data traveler 200 128 gig kingston all i get is 8 mb unallocated
Try to format to another PC.
or
You should install your OS again ,only the reason your PC affected with virus.
At the time installation you must delete partition and create partition and install.
Installation guide click here.
http://www.microsoft.com/windowsxp/using/setup/winxp/default.mspx
There are an another solution you can try also.
DONT USE KAV because it will delete your windows file
http://www.techmixer.com/free-f-secure-rescue-bootable-cd-to-clean-virus-and-malware/
OR
http://www.techmixer.com/free-bootable-antivirus-rescue-cds-download-list/
HOW MAKE BOOT CD
http://www.raymond.cc/blog/archives/2008/07/26/free-f-secure-rescue-cd-300-to-clean-virus-from-unbootable-windows/
SET THE BIOS SETUP for BOOT FROM CD
http://www.windowsreinstall.com/articles/bios/
Hope this helps. If you need more information, reply me soon.
Thanks .
May 14, 2011 | Kingston Technologies 512MB DataTraveler I...
Tip
How to do Fast and unattended Setup of OS in multiple machines
<span> <p><span>Here I have an Idea for primary setup of a large lab quickly. Suppose you have to setup a lab where have more than twenty or thirty system but must setup it quickly. At that time if you don't have enough CD Rom drive or not enough OS installer CD then the task will take a long time. To save time at the same moment I like to prepare an unattendent operating system installation. Before this task I must check for presence of some requirement.</SPAN><br> <p><span> </SPAN><br> <p><span>Verify for unattended Installation:</SPAN><br> <p><span><span> </SPAN>To perform an unattended installation from a CD-ROM, the following conditions must be met:</SPAN><br> <p><span>The computer must support booting from a CD Rom<span> </SPAN>The unattended answer file must be renamed to Winnt.sif and copied to a floppy disk so Setup can access it. So must need a floppy disk drive.</SPAN><br> <p><span>The answer file must contain a valid [Data] section. This is explained later in this article.</SPAN><br> <p><span> </SPAN><br> <p><span>Before installation it has some conditions:</SPAN><br> <p><span><span> </SPAN>1&gt; the installation is limited to a single partition.</SPAN><br> <p><span><span> </SPAN>2&gt; you cannot specify third-party drivers during Setup </SPAN><br> <p><span> </SPAN><br> <p><span>Prepare For an Unattended Installation:</SPAN><br> <p><span><span> </SPAN>To prepare your computer for an unattended installation from a CD-ROM, I've followed these steps</SPAN><br> <p><span>First I've created a Folder in local drive & shared it. Then I create setup manager.</SPAN><br> <p><span>I install Setup Manager by following these steps:</SPAN><br> <p><span>I Open My Computer, and then open the Support\Tools folder on the Windows XP CD-ROM.</SPAN><br> <p><span>Double-click the DEPLOY.CAB file to open it </SPAN><br> <p><span>On the Edit menu, click Select All.</SPAN><br> <p><span>On the Edit menu, click Copy to Folder.</SPAN><br> <p><span>Click Make New Folder. Type the name that you want for the Setup Manager folder, and then press ENTER. For example, type setup manager, and then press ENTER.</SPAN><br> <p><span>Click Copy.</SPAN><br> <p><span>Open the new folder that you created, and then double-click the setupmgr.exe file. The Windows Setup Manager Wizard starts.</SPAN><br> <p><span></SPAN> <br> <p><span></SPAN></SPAN> <br> <img src="alokerdas_9.jpg"> <br> <p><span>Then I Use Setup Manager to Create an Answer File.</SPAN><br> <p><span>I open the setup manager & go to create a new answer file.</SPAN><br> <p><span>Then I go to the unattended installation & windows version option.</SPAN><br> <p><span>I have selected the fully automated option & create an answer file.</SPAN><br> <br> <br> <img src="alokerdas_10.jpg"> <br> <p><span>If you want Windows Setup to delete all partitions on the hard disk and to create a new partition, you must include the Repartition command in the Winnt.sif file. Under [Unattended], insert a new line, and then type "Repartition=Yes"</SPAN><br> <p><span>If you omit this line, you are prompted for the installation partition.</SPAN><br> <p><span> </SPAN><br> <p><span>Add a [Data] section with the following entries to the unattended answer file:</SPAN><br> <p><span>Unattended Install=Yes - Value must be set to "yes"</SPAN><br> <p><span>MSDos Initiated=No - Value must be set to "no" or Setup stops during the graphical portion of Setup<span> </SPAN></SPAN><br> <p><span>Auto Partition=1 - If the value is set to 1, the installation partition is automatically selected. If the value is set to 0 (zero) you are prompted for the installation partition during the text portion of Setup.</SPAN><br> <p><span>Save the unattended answer file as Winnt.sif on a floppy disk.</SPAN><br> <p><span>Insert the Windows CD-ROM into the CD-ROM drive, and then insert the floppy disk into the floppy disk drive.</SPAN><br> <p><span>Change the boot order in the CMOS so that the CD-ROM is first in the list.</SPAN><br> <p><span>Restart your computer. When Setup is started from the CD-ROM, the Winnt.sif file located on the floppy disk will be used to complete the unattended installation.</SPAN><br> <p><span> </SPAN><br> <p><span>This is an easy process to save time & effort.</SPAN>
on Feb 15, 2011 | Computers & Internet
Tip
How to do Fast and unattended setup of OS
Here I have an Idea for primary setup of a large lab quickly. Suppose you have to setup a lab where have more than twenty or thirty system but must setup it quickly. At that time if you don't have enough CD Rom drive or not enough OS installer CD then the task will take a long time. To save time at the same moment I like to prepare an unattendent operating system installation. Before this task I must check for presence of some requirement. Verify for unattended Installation: To perform an unattended installation from a CD-ROM, the following conditions must be met:The computer must support booting from a CD Rom The unattended answer file must be renamed to Winnt.sif and copied to a floppy disk so Setup can access it. So must need a floppy disk drive.The answer file must contain a valid [Data] section. This is explained later in this article. Before installation it has some conditions:
1> the installation is limited to a single partition.
2> you cannot specify third-party drivers during Setup Prepare For an Unattended Installation:
To prepare your computer for an unattended installation from a CD-ROM, I've followed these stepsFirst I've created a Folder in local drive & shared it. Then I create setup manager.I install Setup Manager by following these steps:I Open My Computer, and then open the SupportTools folder on the Windows XP CD-ROM.Double-click the DEPLOY.CAB file to open it On the Edit menu, click Select All.On the Edit menu, click Copy to Folder.Click Make New Folder. Type the name that you want for the Setup Manager folder, and then press ENTER. For example, type setup manager, and then press ENTER.Click Copy. Open the new folder that you created, and then double-click the setupmgr.exe file. The Windows
Setup Manager Wizard starts: alokerdas_2.jpg
<SPAN style="FONT-FAMILY: 'Courier New
Format
How to partition and format the hard disk using the Windows XP Setup program loadTOCNode(2, 'moreinformation'); You can use the Windows XP Setup program to partition and format the hard disk. To do this, use the following steps: Step 1: Partition the hard disk loadTOCNode(3, 'moreinformation');
  1. Insert the Windows XP CD into your CD or DVD drive, or insert the first Windows XP Setup disk into the floppy disk drive, and then restart the computer to start the Windows XP Setup program.
    Note If you are using the Windows XP Setup disks, insert each additional disk when you are prompted, and then press ENTER to continue after you insert each disk.
  2. If you are prompted, select any options that are required to start the computer from the CD or DVD drive.
  3. If your hard disk controller requires a third-party original equipment manufacturer (OEM) driver, press F6 to specify the driver. For more information about how to use F6 to supply a third-party OEM device driver while the Windows Setup program is running, click the following article number to view the article in the Microsoft Knowledge Base: 314859 (http://support.microsoft.com/kb/314859/ ) Limited OEM driver support is available with F6 during Windows XP Setup
  4. At the Welcome to Setup page, press ENTER.
    Note If you are using the Setup disks (six bootable disks), the setup prompts you to insert the Windows XP CD.
  5. Press F8 to accept the Windows XP Licensing Agreement.
  6. If an existing Windows XP installation is detected, you are prompted to repair it. To bypass the repair, press ESC.
  7. All existing partitions and non-partitioned spaces are listed for each physical hard disk. Use the ARROW keys to select an existing partition, or create a new partition by selecting the non-partitioned space where you want to create a new partition. You can also press C to create a new partition using non-partitioned space.
    Note If you want to create a partition where one or more partitions already exist, you must first delete the existing partition or partitions, and then create the new partition. You can press D to delete an existing partition, and then press L (or press ENTER, and then press L if it is the System partition) to confirm that you want to delete the partition. Repeat this step for each existing partition that you want to include in the new partition. When all the partitions are deleted, select the remaining non-partitioned space, and then press C to create the new partition.
  8. To create the partition with the maximum size, press ENTER. To specify the partition size, type the size in megabytes (MB) for the new partition, and then press ENTER.
  9. If you want to create additional partitions, repeat steps g. and h.
  10. To format the partition and install Windows XP, go to step 2.
    If you do not want to install Windows XP, press F3 two times to exit the Windows Setup program, and then do not follow the remaining steps in this article.
    To format the partition without installing Windows XP, use a different utility.
Step 2: Format the hard disk and install Windows XP loadTOCNode(3, 'moreinformation');
  1. Use the ARROW keys to select the partition where you want to install Windows XP, and then press ENTER.
  2. Select the format option that you want to use to format the partition. You can select from the following options:
    • Format the partition by using the NTFS file system (Quick)
    • Format the partition by using the FAT file system (Quick)
    • Leave the current file system intact (no changes)
    Notes
    • If the selected partition is a new partition, the option to leave the current file system intact is not available.
    • If the selected partition is larger than 32 gigabytes (GB), the FAT file system option is not available.
    • If the selected partition is larger than 2 GB, the Windows Setup program uses the FAT32 file system (you must press ENTER to confirm).
    • If the partition is smaller than 2 GB, the Windows Setup program uses the FAT16 file system.
    • If you deleted and created a new System partition, but you are installing Windows XP on a different partition, you are prompted to select a file system for both the System and Startup partitions.
  3. Press ENTER.
  4. After the Windows Setup program formats the partition, follow the instructions that appear on the screen to install Windows XP. After the Windows Setup program is finished and you have restarted the computer, you can use the Disk Management tools in Windows XP to create or format more partitions. For additional information about how to use the Windows XP Disk Management tools to partition and format your hard disk, click the following article number to view the article in the Microsoft Knowledge Base: 309000 (http://support.microsoft.com/kb/309000/ ) How to use Disk Management to configure basic disks in Windows XP
Tanks. Cheer!
Mar 23, 2010 | Computers & Internet
Tip
CONFIGURING YOUR SYSTEM FROM HOME FOR XP
For you to sit at home for your system configuration on how to setup your xp program
1. When you run the Windows XP Professional Setup program, you must provide information about how to install and configure the operating system. Thorough planning can make your installation of Windows XP Professional more efficient by helping you to avoid potential problems during installation. An understanding of the configuration options will also help to ensure that you have properly configured your system.
I won't go into that part right now but here are some of the most important things you should take into consideration when planning for your XP installation:
* Check System Requirements
* Check Hardware and Software Compatibility
* Determine Disk Partitioning Options
* Choose the Appropriate File System: FAT, FAT32, NTFS
* Decide on a Workgroup or Domain Installation
* Complete a Pre-Installation Checklist
After you made sure you can go on, start the installation process.
2. Beginning the installation process
You can install Windows XP in several methods - all are valid and good, it all depends upon your needs and your limitations.
* Manual installations usually come in 3 flavors:
* Boot from CD - No existing partition is required.
* Boot from the 6 Setup Boot Disks, then insert the CD - No existing partition is required (see the Create Setup Boot Disks for Windows XP page).
* Boot from an MS-DOS startup floppy, go to the command prompt, create a 4GB FAT32 partition with FDISK, reboot, format the C partition you've created, then go to the CD drive, go into the I386 folder, and run the WINNT.EXE command.
* Run an already installed OS, such as Windows NT 4.0 Server. From within NT 4.0 go to the I386 folder in the W2K installation CD and run the WINNT32.EXE command.
* If you want to upgrade a desktop OS such as Windows 98 into Windows 2000 Professional you can follow the same procedure as above (You cannot upgrade Windows 98 into W2K Server).
There are other non-manual installation methods, such as using an unattended file along with a uniqueness database file, using Sysprep, using RIS or even running unattended installations from within the CD itself, but we won't go into that right now.
It doesn't matter how you run the setup process, but the moment it runs - all setup methods look alike.
3. The text-based portion of the Setup program
The setup process begins loading a blue-looking text screen (not GUI). In that phase you will be asked to accept the EULA and choose a partition on which to install XP, and if that partition is new, you'll be asked to format it by using either FAT, FAT32 or NTFS.
i. Start the computer from the CD.
ii. You can press F6 if you need to install additional SCSI adapters or other mass-storage devices. If you do you will be asked to supply a floppy disk with the drivers and you CANNOT browse it (or a CD for that matter). Make sure you have one handy.
iii. If you want, you can press F2 to run the ASR sequence. For that you need a good backup created by the Windows XP backup program, and the ASR floppy disk. If you plan to install a new copy of XP - don't do anything.
iv. Setup will load all the needed files and drivers.
v. Select To Setup Windows XP Professional Now. If you want, and if you have a previous installation of XP, you can try to fix it by pressing R. If not, just press ENTER.
vi. Read and accept the licensing agreement and press F8 if you accept it.
vii. Select or create the partition on which you will install Windows XP Professional. Depending upon your existing disk configuration choose one of the following:
viii. If the hard disk is unpartitioned, you can create and size the partition on which you will install Windows XP Professional.
ix. If the hard disk is already partitioned, but has enough unpartitioned disk space, you can create an additional partition in the unpartitioned space.
x. If the hard disk already has a partition that is large enough, you can install Windows XP Professional on that partition. If the partition has an existing operating system, you will overwrite that operating system if you accept the default installation path. However, files other than the operating system files, such as program files and data files, will not be overwritten.
xi.If the hard disk has an existing partition, you can delete it to create more unpartitioned space for the new partition. Deleting an existing partition erases all data on that partition.
If you select a new partition during Setup, create and size only the partition on which you will install Windows XP Professional. After installation, use Disk Management to partition the remaining space on the hard disk.
4. Select a file system for the installation partition. After you create the partition on which you will install Windows XP Professional, you can use Setup to select the file system with which to format the partition. Windows XP Professional supports the NTFS file system in addition to the file allocation table (FAT) and FAT32 file systems. Windows Server 2003, Windows XP Professional, Windows 2000, and Windows NT are the only Microsoft operating systems that you can use to gain access to data on a local hard disk that is formatted with NTFS. If you plan to gain access to files that are on a local Windows XP Professional partition with the Microsoft Windows 95 or Windows 98 operating systems, you should format the partition with a FAT or FAT32 file system. We will use NTFS.
i. Setup will then begin copying necessary files from the installation point (CD, local I386 or network share).
ii (or if setup was run by booting from CD) the copying will probably last a few minutes, no more than 5 max.
iii. The computer will restart in graphical mode, and the installation will continue.
iv.The GUI-based portion of the Setup program
The setup process reboots and loads a GUI mode phase.
It will then begin to load device drivers based upon what it finds on your computer. You don't need to do anything at this stage.
i. Click Customize to change regional settings, if necessary.
ii. Current System Locale - Affects how programs display dates, times, currency, and numbers. Choose the locale that matches your location, for example, French (Canada).
iii.Current Keyboard Layout - Accommodates the special characters and symbols used in different languages. Your keyboard layout determines which characters appear when you press keys on the keyboard.
If you don't need to make any changes just press Next.
If you do need to make changes press Customize and add your System Locale etc.
Note for Hebrew users: Unlike W2K, it is SAFE and it is OK for you to install Hebrew language support at this phase.
To install Hebrew support:
After pressing Customize go to the Languages tab and select the "Install files for complex script and right-to-left languages".
A warning message will appear. Press Ok.
Warning: You must now press Apply!!!
Setup will copy the necessary files from the installation point.
You can now go to the Regional Options tab and select Israel in the Location drop-down list, and Hebrew in the Standards and Formats drop-down list. Click Ok.
1. Type your name and organization.
2. Type the product key.
3. Type the computer name and a password for the local Administrator account. The local Administrator account resides in the SAM of the computer, not in Active Directory. If you will be installing in a domain, you need either a pre-assigned computer name for which a domain account has been created, or the right to create a computer account within the domain.
4. Select the date, time, and time zone settings.
5. Setup will now install the networking components.
After a few seconds you will receive the Networking Settings window. BTW, if you have a NIC that is not in the HCL (see the What's the HCL? page) and XP cannot detect it, or if you don't have a NIC at all, setup will skip this step and you will immediately go to the final phase of the setup process.
Press Next to accept the Typical settings option if you have one of the following situations:
* You have a functional DHCP on your network.
* You have a computer running Internet Connection Sharing (ICS).
* You're in a workgroup environment and do not plan to have any other servers or Active Directory at all, and all other workgroup members are configured in the same manner.
on Apr 06, 2010 | Computers & Internet
Tip
Installing Windows XP
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Every one who owns a computer should maintain it on their own from time to time.
Reinstalling your Operating System is one of the methods of computer maintenance, and is a bit complex.
With these steps, you will successfully install Windows XP into your computer.
These steps are similar to other Windows OS installations (Vista, Windows 7).
Below is the detailed procedure of installing Microsoft Windows XP:
  • Before installing Windows XP or any other operating system, you should backup all your data. Data can be backed up on a separate partition, if the hard disk is partitioned or you can back it up on external storage devices like CDs or on a network.
  • Restart the computer and go to the Setup menu by pressing F2 and change the first boot device to CD, press Esc and save settings.
  • Insert the CD labeled Microsoft Windows XP into the computer and restart the computer.
  • When the pc restarts, a message will appear telling you to press any key to boot from CD, press a key immediately the message appears and the setup process will begin.
  • After the files have been loaded, Windows will start and it will give you an option of repairing using Recovery Console by pressing “R” or continue with setup by pressing “ENTER”; press enter to continue with setup.
  • Setup will list all your disk partitions, highlight the partition where you want to install Windows, this is mainly partition “C”, press “D” to delete the partition, then press “L” to confirm.
  • Highlight the partition you deleted, and then press “C” to create a new partition, press “ENTER” to create the partition.
  • Press “ENTER” again to install Windows on the New (Raw) Partition you have created.
  • Format the partition using NTFS file system.
  • After format has completed, Windows will restart and setup will prompt you to boot from CD again. Ignore the message and let setup continue automatically.
  • Follow the next steps which will ask you to setup the system Time and Date, Network and enter a serial key, until setup finishes.
  • After setup has finished, Windows will restart and will welcome you for the first time; Microsoft Windows XP will have successfully been installed on your computer.
on Jan 07, 2010 | Computers & Internet
Gateway MX6455 - AMD Turion 2.0Gb with 1Gb Ram Stops working and goes to black screen after POST. Will not boot into windows. The more I try re-booting, the faster it stops.
If you recently installed and any new program it could be a corrupt driver. Boot to safe mode by hitting F8 and delete it. If you didn't, you will have to remove drivers individually. Failing hardrive is another culprit.
Mar 04, 2010 | Computers & Internet
Hello, how to install windows xp?
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To install Windows XP, use the following steps.
Jan 08, 2010 | Computers & Internet
How to install xp in HP Pavilion dv6 1030 us Laptop and how to repartition my C: drive especially I have still 150 GB free space in C drive Please help me in this case Thanks in advance.
get a winxp installer CD, you can repartition your drive on the first part of the winxp installation process. Prepare your drivers for your machine especially the network and USB drivers which you will need to copy and transfer files firstly.
If u meant of installing an additional OS like winxp to your extra space, you need a boot loader to switch between OSes.hope this helps
Aug 17, 2009 | HP Pavilion dv6-1030us Notebook
Dell Inspiron 640m PC Notebook Logo
50 people viewed this question
Alun Cox
