Samsung HT-DM550 System Logo
M
Marcel Punt Posted on Dec 04, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Switch on If I switch on the device, it does only blink and doesn't switch on anymore
Audio Service Clinic
Level 3:
  • Samsung Master 924 Answers
  • Posted on Dec 05, 2013
Samsung Master
Level 3:
Answers
924
Questions
Helped
351363
Points
1710
Most likely, your unit has a condition known as DC Offset, meaning you have a bad amplifier. For more information, please visit my website at audioserviceclinic.com. Thank you.
Hello everyone I have a Sony tv Model : kdl-55EX621 Doesn’t turn on and the power red light keeps flashing twice every time I mean flash.flash———-flash.flash——flash.flash———And so on. Any help what part I...
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
3helpful
2answers
I have accidentally had the mains plug taken out of the wall socket for my blender while it was switched on and had not turned it off first. Now it doesn’t work anymore.
I think that the fuses are not working anymore and need to be replaced and the blenders motor is no longer working and needs to be replaced too. It would be more convenient to buy a new blender than to fix the current blender that you have that is not working anymore.
Jan 26, 2021 • Blenders
1helpful
LCD TV does not turn on from first time
http://electro-medical.blogspot.com/
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
1helpful
TV have power, but when turn it on, the red light blink a few time but no display
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
3helpful
Hello i have a panasonic TC-P50S1 plasma tv (2009) and it does not turn on properly anymore. You turn it on and then it turns off and start to blink repeatedly.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
The status light just blinks and tv doesn't come on
Try changing the input device to something you are sure, works such as a DVD player.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
My tv rca tr29e26 it have the front panel LED constantly flashing and it doesn`t turns on while is connected !!
My Sony Trinitron televison, model number KV27FS100, does not have a picture anymore. There is a flashing red light at the timer that flashes 5 times and then repeats this sequence of 5 flashes again and...
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Hi, My g. door opener doesn't work. The
5 Blinks on the logic board LED indicates that possibly the motor has overheated. If you have unplugged the unit and waited minimum of 30minutes before plugging it back in, and it still will not operate, then the logic board will need to be replaced.
I hope this helps
I have a Panasonic Viera TH-PZ4285U and when i turned on 2 blinking lights appear on the power light, no image, somebody told me to change the power supply board, and also i don't know if is an A or D...
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://homenol.blogspot.com/ http://electronicshelponline.blogspot.com/ If blinks continue without any pause, the main board is faulty. Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
