Question about Kitchen Ranges
Oven not heating relay keeps turning on and off
We own a frigidaire stove it's a year old was working fine yesterday turn on to bake a turkey and oven was not heating up the relay kept turning on and off (clicking)
    Scholar:
  • 43 Answers
It's not common (it has happened though), but perhaps your thermostat is either faulty or out of calibration which would turn on and off the power going to the elements.
It's possible to try to re-calibrate it yourself but I wouldn't advise replacing the thermostat. Leave that to the professional (and ask for a warranty of service).
Posted on May 11, 2009
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
I own FRIGIDAIRE ES100/105 (electric stove and oven). Yesterday I was using the oven and suddenly I heard a loud sound. I went to check it I found out the both the oven and stove were off. And not working....
HI. The actual issue will be with the main logic board, which is where the main element control relays are mounted. These very important relays are damaged. The main board will need to be replaced, asap.
With that said, if you could be so kind; Please post the entire model number so that i may pull up all necessary part numbers needed, as well as, service manual links and diagrams to help with your repair.
Dec 02, 2011 | Frigidaire PLEF398AC Electric Kitchen...
Top heating element does not work but it still cooked our turkey in the cooking bag just fine. the stove is only a little over a year old.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Nov 26, 2010 | Frigidaire FEF366 Electric Kitchen Range
Frigidale 10 years old stove bottom heating
Have 10 year old fridgidare elec.oven. Model no.FEF355ASE and both bake and broiler have stopped working have power and ohm's are good. Whats next ?
Jun 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
I have a 2 year old smoothtop GE stove. I was
that clicking usually means that the erc is trying to turn on the burners,
i would unplug the range
pull it out and check all the connections of the bake element
Oct 16, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Yesterday I heard a loud pop from inside the stove. Frigidaire smooth top professional series just about 5 years old. Looked inside and my parchment paper had caught on fire which had never happned before...
Is this an oven or the cook top?
A blown oven element is possible. You may still be able to bake but the oven will seem to take forever to warm up. An easy check would be to crank the heat up full bore and put your hand near the top then the bottom. You should feel more intense heat the nearer you get to a working element.
May 08, 2009 | Kitchen Ranges
Kitchen Ranges Logo
124 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
