Question about Dryers
Dryer makes pounding noise when drum spins - Dryers
    President:
  • 1,136 Answers
Hi, Is this a whirlpool brand dryer? They have a rear roller noise when rollers go bad. It sounds like tennis shoes in drum.
Let me know if I can help
Posted on May 11, 2009
Tumble dryer drum making a noise spinning
hi take top off hold back of drum see if u can pull it up if you can feel play its more than liklely the bearing wot dryer is it
Feb 13, 2014 | Beko Dryers
Drum is loose when it spins it make a horrible noise pounding
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Nov 18, 2010 | Kenmore Elite 45986 Front Load Washer
LG gas dryer DLG0452W drum makes a clicking noise
one of the dry drum baffle screw might be lose are there might be something caught inbetween the dry drum front seal are rear
Apr 24, 2010 | LG DLG0452W Gas Dryer
Noise when dryer is spinning
The drum rides on some roller wheels to allow it to rotate and give it support. They have bearings in them that fail and begin to make noise. Replace the roller that is bad. You have to access the drum by removing the front of the machine, support the drum and find the noisy roller.
Jul 13, 2009 | Kenmore 63942 Dryer
Whirlpool dryer drum making noise
window.google_render_ad();There are many places & parts that could be causing your Whirlpool dryer to be noisy. To find out what is causing the noises, you need to find out where are the noises coming from.
Start the dryer and let it run for a while and listen to try to pinpoint where in the dryer the noises is coming from. Once you have an idea of the area, you will need to disconnect the dryer from the wall outlet and take the dryer apart.
Below you will find the parts that you need to check when your dryer is noisy.
The drum baffles:
The drum baffles are use to tumble the clothes inside of the drum, in other words, the baffles job is to separate the pieces of laundry as the drum turns.
When the dryer is getting older and if you use the dryer a lot, the drum baffles holding screws will become loose. Loose drum baffles will cause noises. All you need to do, is to open the top panel and tighten the drum baffles holding screws.
The drum support rollers:
These dryers uses four drum support rollers, tow on the front and two on the rear. The job of the drum support rollers is to keep the drum tumbling smooth.
When the grease on one of the rollers dry out, the roller start to make squeaking noises and the roller bearing will start to wear out until the bearing on the roller is gone. When the bearing on the roller is gone, the noise will change from squeaking to a clanking noise.
The blower wheel:
The blower wheel is use to circulate the air inside of the dryer drum. The most common Whirlpool blower noises are cause by something falling inside of the blower housing and hitting the blower when the motor runs.
The Idler pulley:
The Idler pulley is use to apply the necessary tension on the belt. There are two types of idler pulleys, the pulley with the wheel and the pulley with the teflon slide. A bad idler pulley could cause a Whirlpool dryer to be noisy.
The drive motor:
Worn out bearings on the motor will cause the motor to run kind of noisy. When the motor starts making noises, the solution to this problem is to replace the motor.
The belt:
The belt on most dryers is only about1/4 inch wide. These belts work very hard making the drum tumble. When the belt stretch just 1/2 inch more that it supposed to, the belt will start slipping and that could cause your Whirlpool dryer to be noisy.
As you could see, there are a lot of parts that could become noisy in your dryer. When your dryer starts making noises, make sure to check it out before it gets worse.
Feb 09, 2009 | Whirlpool LER4634J Electric Dryer
Banging noise
You may have had a foreign object slip under a loose drum baffle. Manually rotate the drum to locate wwhich baffle it is in.
Apr 06, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
403 people viewed this question
Top Dryers Experts
