Question about Canon Office Equipment & Supplies
I don't know what to do with the pull tab on the left side of the cartridge. The instruction just show it pulled out about an inch and nothing else, where does it go?
  • itskatie May 11, 2009
    I have the cannon x25 cartridge and it is new, the picture only shows a hand pulling the tab out about 1 inch and I don't know what to do with it after that,
  • Canon Expert
  • 1,326 Answers
It depends on what model you have..... Mostly, all Canons toner box's have pictures on them to show how to install the toner... and in the older models if you look on the front door there are pictures that show you step by step on how to install the toner... and if you have a newer one, you can push the "?" on the control pannel and it will show you how to install the toner... Good Luck
Posted on May 11, 2009
Trying to remove a kenwood car stereo from a 91 vw golf
If you didn't purchase the radio new, then you probably don't have the pull tabs. New radios come with pull tabs. Basically they are designed to fit into both sides of the radio, just where the locks that keep the radio in the dash are. The old school method is the find the thinnest knives you can, one for each side. Remove the trim ring. Slide the knives (one on each side) inbetween the stereo and the metal mounting sleeve. You will need to keep both in place until your radio is about 1/2 way out. CAUTION, don't pushe the knives in too far, The locks are about 1 inch - 2 inches in.
Hope this helps
Aug 15, 2011 | Car Audio & Video
Don"t know to change the toner it was donated and
There are usually picture instructions on the Canon toner box. But here it goes - Gently shake the toner cartridge to break up the fine toner powder. Then open up the front door, the you should see a blue handle on the right side, rotate this in the counter clockwise direction. The Developer should move to the right and gently pull this out as far as it will go. Put the toner cartridge on top of the developer assembly and gently push down until it locks in. You will have to angle the rear facing end of the cartridge so that it slips into a slot. When the cartridge is lock the tab should break away. Before pulling this tab away from the copier lift up on the cartridge to guarantee that the cartridge is locked into place. You don't want to pull the tab until locked because you will have abig mess to clean up. The tab will open up the developer unit and the toner will drop inside. The you close up the slide and at the end of this procedure you may have to place a thumb on each side of the slide and fingers on the blue finger catches to fully close the developer unit. The cartridge should release and then remove the empty toner cartridge. Throw it away, return the developer to its normal position, close the front cover.
Jun 20, 2011 | Canon imageRUNNER 2200
The instructions tell me to lift the lid, but I don't know how, it seems to be locked, is there something underneath I need to push or pull. I need to change the ink cartidges
On this particular printer there is no locking mechanism to access the ink cartridges. In order to open the cover, use a single open hand and place your fingers just underneath the screen on the front, and pull upward. The entire scanner piece should raise and a plastic bar on the right-hand side will lower down to prop it open.
If you're having a lot of trouble opening it, you may want to check around the sides of the printer to see if there is any tape leftover from when the printer was packed in its original box. When they ship a printer it is always covered in tape to make sure that nothing falls open or breaks before it's delivered, and there may be a piece of clear (almost invisible!) tape left over preventing the printer from opening.
Once it's open, the ink cartridges should come to the middle. Press down on the small lever on the print head (the ink cartridge holder) to pop the cover open so that you can install the cartridge.
Hope this is helpful!
May 09, 2011 | Lexmark P6350 All-In-One InkJet Printer
How do you change the cartridge? i am having difficulty removing it.
hi,
you open the front door and pull out the toner cartridge/drum. when you open the door there is a little handle on the left that unrestricts the cartridge from coming out. once its out, you push a button, (there may be 2) on the right side and possibly left, you push them down to separate the toner from the drum
thanks
Sep 01, 2010 | Brother HL-2040 Laser Printer
Trying to put new cartridge in my moen bathroom faucet and i don't know how to do it. It is a teardrop one handle faucet. Please help a single woman not have to call a plumber!!!
shut water off under faucet,open it to prove wtr is off. pry off cap , slide edge of putty knife,butter knife.etc should see a phillip's screw.remove,pull handle off, pull chrome sleeve off, now. toward's top you should see a little tab sticking out, it is part of a horse shoe shaped clip,pull with needle nose plier's,or similar.pay attention how it come's apart ,your new cartridge come's w/detailed instruction's,calmly refer to 'em, you may need or may not need a moen cartridge puller,(use a good grip,steady pull,)
Apr 25, 2010 | Moen Bathroom Sink Faucet - 4-inch...
How to install toner cartridge in a Canon 920
On your Canon PC 920, there is a recessed gray latch located on the left side of the machine towards the top front...press upwards on this latch to release the top part of copier (same as removing a misfeed or clearing a paper jam). The copier opens up.....now, located in the top unit, about center, is the drum / toner unit. It has a black plastic handle on it. Grasp this handle and pull towards you...slowly...until it is free of machine (support the rear of the unit with your other hand) Open new cartridge (unit) and install in reverse order (there should be instructions with the new cartridge) The copier has rails that the cartridge mounts on. Another note, before installing....gently shift the cartridge from side to side.....this distributes the toner evenly (again, covered in the installation instructions packed with the cartridge) There is a tab that needs to be removed to allow the toner to get where it needs to go for copying....attatched to this tab is a strip of plastic, pull all the way out. I have a PC 940...it uses the same cartridge.
Mar 24, 2010 | Canon Office Equipment & Supplies
Cannot remove toner cartridge from Brother HL 2170W
Had the same thing happen to me today. When you open the door to pull out the cartridge, there is an arm (less than an inch away from the green tab) on the printer which should connect to the door. When you open the door it retracts a wheel which releases the toner cartridge/drum assembly. This had become disconnected from the door.
Oct 03, 2009 | Brother HL-2170W Laser Printer
Spin brush removal
Brush Disassembly Hoover STEAM VAC Owners Manual F9514-900 (F9514900) does not
explain how to take the brush assembly apart. The instructions are as
follows:
Figure 1 shows the key
features. There are two
clear plastic outer pieces
which are held onto the
white inner piece with 3
tabs each. The clear
plastic tabs go underneath
the corresponding white
extended tabs on the white
plastic inner piece.
Figure 2 shows where the
screwdriver is inserted
(flat blade) and gently
pushed down while pulling
the clear plastic outer
piece away from the inner
white piece.
Figure 3 shows assembled
unit. Note extended brush
axle goes in center, which
fits into the female drive
unit on the shampooer.
I used the hose nozzle out
on the lawn to direct high
velocity water stream
trying to get the hair out
of the brushes. Hair and
fuzz remarkably entrained
in brushes, but I got 90% of it out.
Oct 19, 2008 | Hoover SteamVac F5914-900 SpinScrub...
I am using the workcentre 4150 and the printer keeps giving me an error saying. "toner supply failed, remove seal tape from toner cartridge and reinstall" I can't find any tape on toner...
The seal tape might be inside the cartridge, attached to a pull-tab.
I am only specifically familiar with the HP toner cartridges, which have a colored plastic pull-tab attached to the tape which seals the toner drum during transit. You have to pull on the tab which in turns yanks the sealing tape out after it.
Each HP cartridge has a small instruction sheet included which shows the location of the pull-tab. Perhaps your Xerox cartridge came with a similar diagram sheet?
Apr 03, 2008 | Office Equipment & Supplies
Inserting staples
If the machine has an in-built finisher, the stapler is located in the rear of device. Pull the finisher release handle and pull the finisher towards you. Extract the staple cartridge by pulling up in the green tab at the rear right of the finisher. The staple cartridge can be opened by squeezing the sides together to allow the spring to act. (Sometimes it can be helped with a screwdriver popping the clear tabs located on the underside). Insert the replacement staple pack and pull the orange tab before closing the cartridge shut. Reinsert into the finisher and push down to locate it. Should work ok after all that.
Nov 26, 2007 | Canon imageRUNNER 3570 Copier
old marine
old marine
