Question about Olympus FE-230 Digital Camera
XD Card "locked" since computer crashed.
My Olympus compact digital camera was connected to a PC and was transferring data when the PC crashed. Now, when I turn my camera on, it says that it's locked.
It uses XD Cards which do NOT have a little switch on the side for me to move. Please can anyone help???!!!
It's definitely the XD Card itself that's locked, because when I remove the card I am able to take a few photos with the (tiny) inbuilt memory.
Thank you.
Sarah
    President:
  • 919 Answers
As long as the xD card was not formatted it is possible to recover the images that were accidently erased,lost or corrupted. You can go to the following website link and download an image recovery software program that is free of charge.
http://www.z-a-recovery.com/
You want to download a program called Zero Assumption Recovery. It is a very simple program to use and many people have had much success in recovering images.
Data recovery is a booming industry, and many appropriate services and software can be found by searching regional phone and business directories or the Internet for terms such as "image recovery" or "data recovery".
Posted on May 11, 2009
How do i move pictures from my camera to my computer without my CD?
Olympus FE-340 Digital Camera uses a the xD memory card, you can use a card reader to read the xD memory card and transfer your data to the PC, just like any external storage drives.
Olympus Software download @ http://www.olympus-europa.com/consumer/208_software.cfm?category=5&productgroup=266&product=&os=11&result=
Hope it helps.
Jul 03, 2011 | Olympus FE-340 Digital Camera
I have had the my olympus 520 camera almost a year. i have never taken the memory card out until today. Now my camera will turn on without the card but will not turn on when the card is in the camera. it...
Which card are you using the XD card or a compact flash card? If you have an external reader, confirm that the card can be read on a computer still, or if you have another card, try that to see if it works. It is possible that in reinsterting the card you may have damaged the contacts in the socket. More likely with the Compact Flash than XD card.Very nice camera, sorry to hear you having problems, hopefully it is nothing serious. Media cards can fail. Have you already backed up the pictures that were on the card? If so, try to reformat the card if you have a connection for it on your PC.
Mar 11, 2011 | Olympus E-520 Digital Camera with 14-42mm...
I have a fe-200 olympus camera, after i transferred the images, the memory card say write protect, the memory card has no switch on the side, and now i cant take any pictures happened to both of my memory...
Your camera uses xD memory cards, and they never have a physical locking switch.
Your problem is most likely due to having used the xD card in an external card reader. The host pc sometimes sets the xD card as a "read only" drive. If so you must go back to the host pc and connect the xD card again. If using Windows then click on My Computer and highlight the xD card. Right click and select Properties from the device menu. Uncheck the box marked Read Only.
If that's not the cause of your problem then try re-formatting the card in your camera. NEVER re-format it using a computer.
If those options both fail, try another xD card which is known to be fully functional in your camera. This will determine whether the camera or the card is at fault. The camera is too old to merit the cost of a professional repair, and there's nothing more to be done with a faulty xD card, so replace whichever item is faulty.
You may also wish to consult the user manual for your model which you can download for free from Olympus in .pdf format.
I hope that I've been of assistance, please take a moment to rate my speedy and free answer.
Mar 08, 2011 | Olympus FE-230 Digital Camera
Impossible to transfer shots to my PC. Corrupted shots.
Instead of putting the card in the computer leave it in the camera and try using the usb cable that came with the camera. After hooking up the cable turn the camera on. If you have vista and are connected to the Internet, Vista should find what it needs and install it. If you don't have Vista, try installing the disc that came with the camera.
Jul 04, 2009 | Olympus Stylus 770 SW Digital Camera
Clean or format card error on Olympus XD card
There are most likely some "corrupted" images on your xD card. Very often a card reader "writes" data to the card while transferring or copying images into the computer. When you re-insert the card back into the camera, it doesn't recognize the new data (because it didn't create it), and gives the error, usually requiring a complete formatting be performed. There are also problems if you use a reader to rotate images, then re-install the card in the camera. The best way to accomplish what you were doing is to transfer the images into a folder on your computer, as the camera shot them (don't rotate them first). That way, you haven't altered any data on the card. For now, however, I suggest you format the card in the camera, so you can start with a "clean slate". Good luck.
May 02, 2009 | Olympus Stylus 850SW Digital Camera
Transferring photos to PC
try using a memory card reader that supports a xd card-very generic plug and play no software to load and computer should recogtnize card-if not open my computer and you will find new drive letters for card reader in there
Jun 03, 2008 | Olympus Stylus 720 SW Digital Camera
XD-Picture Card
Ultra-compact with fast data transfer rates, the Type M xD-Picture Card is currently available with up to 2GB of storage capacity.
Not only do they support the exclusive Olympus Panorama option, they also activate art effect functions including 3D, oil painting, cartoon and watercolor. These extra functions which are used in conjunction with the software provided with your camera will add fun and creativity to your photography.
So just to clarify, you have a TYPE M XD PICTURE CARD, MADE BY OLYMPUS.
And an Olympus mju770 SW. Now, it is the software on your computer that is going to allow you to make any changes. So first, you need to open that software. Connect the camera to the computer via USB, and voila, extra functions within the software will activate and allow you to edit the pictures with special effects like watercoloring, etc.
You know, you could also achieve the same result by using a powerful image editing tool like Photoshop CS3 or even go back as far as Photoshop 7.0. Or Microsoft Photo Editing can add those effects, and that's free with any XP machine.
Jan 03, 2008 | AOpen Olympus 64Mb xD-Picture Card (AX4C...
Olympus Stylus 750 Digital: Card error..cannot view pics or copy/download
its the card not the camera.
i think you fingers have come into contact with the gold bits on the xd card.
try wipping the card and putting it in several times,if all fails buy your self an olympus 1gb xd card H TYPE.
seekreep@yahoo.co.uk
the best compact of all time was the Olympus C-70 Zoom Camera which can be found 2nd hand over ebay.
Dec 21, 2007 | Olympus Stylus 750 Digital Camera
XD card Error
Try formating the card in the Camera twice. or Download PCinspector from www.convar.com Install this program and run the recovery program with the card in the media slot. Then back to camera and format, Come back
May 21, 2007 | Olympus Camedia C-350 Digital Camera
Olympus FE-230 Digital Camera Logo
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
