Question about RCA HD52W56 52" Rear Projection HDTV
Turn tv on, have sound for a minute then tv turns back off
WHen I turn on the TV I can hear it come on. The sound acts like it is going on and off and then after a few short moments the tv shuts off. I then have to wait for a few minutes to try it again
  • 8 Answers
SOURCE: TV will not power up
LoL!!! I don't know why but all RCA's have Flyback Transformer problems! I have one to here is the part number 259296 if you look around you can buy it for about 15.00 if you know how to solder you can do it your self and save big time! Hey I'm doing it! I don't see paying $500.00 to fix it you could buy a new one. And they are just ripping people off because the parts aren't really that high to fix the flashing light problem. And the part is never on back order so your getting screwed they are probably wanting you to finally say just throw it away. And than they'll fix it for $15.00 and sell it for $600.00 Anyways for the people that are having the same problem go here to buy the Flyback Transformer for the D52W20 http://www.electronix.com/catalog/advanced_search_result.php?ELECTRONIX_CATALOG_SESSID=c5d90cbb7ae2d4c1449ea48542eef46a&keywords=259296&x=4&y=14
Also here is another website if you have access to junk TV's and want to know what other RCA Flyback Transformer will work. The price on this site is higher for there's though
http://www.partstore.com/Part/Thomson/RCA/D52W20/Thomson/RCA/259296/New.aspx
Posted on Dec 10, 2007
SOURCE: tv turns off after a few minutes
I had the same problem with my D61W130. It would turn off and on intermittently. Called a TV repair shop and they said this model was known for it's poor soldering connections on the power board. They came out and took it apart and re-soldered the board. It cost me almost $300 bucks but it seems to have taken care of the problem. It's working great now.
Posted on Feb 20, 2009
fillmore85
  • 62 Answers
SOURCE: My RCA Bigscreen HDTV will not turn on.
If this is similar to the d52w20 then I almost garantee you need to replace a capacitor. You can check to make sure that's what you need by unplugging the tv, taking off the back cover and feeling the top of 3 capacitors. On my d52w20, CP150 (rated at 2200uf 16V) was blown and the top was bulged out. You should also check CP120 and CP114 to see if either are blown. I don't have a clear picture of where it's located, but I have a picture of what you should see after you take off the back cover.
http://i265.photobucket.com/albums/ii209/fillmore85welder/KodakMoment003-1.jpg
In the middle of the picture you see an aluminum heatsink in the shape of a 'C' with the opening facing away from you. That is where CP150 is located. CP120 and CP114 should be located nearby, but if you can feel a bulge on any of the tops of those 3 capacitors replacing them should fix your problem. Replace the existing capacitors with a higher voltage rating of either 25v or 35v.
"4 capacitors on the power/deflection board. CP110 220uf 200v. CP120 220uf 35 Volts. CP114 220uf 35 volts. CP150 2200 16 volt. also check entire delfection board for cold solder especially around flyback. bad connections here can cause problems like some of the fp fuses blowing and cutting off convergence supply"
Posted on Jun 04, 2009
ladywinn
  • 5138 Answers
SOURCE: tv wont turn on most of the time it will try three
On yor Deflection board CK capacitors cp114 cp120 220uf 35v and cp150 1000uf 16v if cp 150 is swollen or puffed up on top replace all 3 caps Deflection board is the bottom board on left hand side with FBT flyback transfomer
Posted on Aug 13, 2010
Slinteriors
  • 8617 Answers
SOURCE: power up, attempts to turn on, then shuts off,
Replace the three deflection capacitors CP150, CP120 and CP114. You can get the repair kit by that same name from www.tvrepairworld.com which also contains the CD with instructions.
Posted on Aug 21, 2010
I have a Samsung HL-R5678W DLP TV that is acting up. When I first turn it on everything works, after 5 minutes it shuts itself off. After 2 minutes it will come back on without sound. It will do this a...
U turn tv on hear any squiling,grinding or motor noises?Picture show up before it shut down picture have flashes of black&white within the picture?Yes,to all of these,this tv have a colors wheel and it dead,require the colors wheel replacing.No,none of these problems.The tv projection lamp,if in this tv like a 1 1/2 or 2 years,tv ben on an watches like 4 or 5 hours a day?The "LAMP" LED light indication lite up or flahes,the projection lamp life is over.Require a new projection lamp.
Oct 22, 2010 | Samsung DLP HL-P5663W 56" TV
When I go to turn on my Vizio 32' Model VP322 HDTV10A, it half turns on then back off, repeatedly for 3 minutes before turning on. How can I fix this problem?
If you are not able to hear sound during the this process, the power supply of the TV is likely failing.
If you are able to hear sound during the 3 minute ordeal, then likely the inverter for the backlight is failing, which can also be caused by a failing lamp as well.
Try this: turn the TV on, wait for it to do its thing. Goto the menus, picture settings, and turn the brightness *down* as far as it will go. Exit out of the menu (save if prompted). Turn the TV off, wait a bit, then back on. If still same issue, it could be the power supply or inverter / lamp assembly. But, if the cycle is shorter, or comes on right away, then it is likely the lamp / inverter.
Jun 23, 2010 | Vizio VP322 32 in. Plasma TV
Tv takes to long to turn on and screen resizes
sounds like a power supply issue. partstore.com might have a power supply for this tv
Mar 18, 2010 | Sony KDS-R50XBR1 50" HDTV
Have flat panel hdtv monitor 1080i samsung no picture or sound
Tv has no picture or sound; will go out while watching. The picture will go into a line and sound and picture will go out; shortly after that tv will turn off. Did this last nite and I did not turn back on until this morning, it worked no problem. On for couple of hours and now it's out again. What could be problem and how do I fix myself
Feb 27, 2010 | Televison & Video
Rca Model number R52Wh73 Tv is not acting right
3 capacitors on your deflection board cp150 2200uf 16v cp114 cp120 220uf 35v
Dec 12, 2009 | RCA R52WH73 Projection Television
Samsung dlp acts as though the lamp is gone. Put
It may be the ballast or aother problem. First, unplug your TV for about 5 minutes, plug back in. LISTEN very carfully when you turn the TV on. (put ear on the left hand side of TV towards the back) if you hear a clicking sound. It may be your light engine. BUT most important what lights on front panel are blinking.
Hope this was helpful, Big Irish.
Nov 21, 2009 | Televison & Video
My TV pictures turns black afetr a few hours but I still can hear sound perfectly!!!
It sounds like your rptv lamp is going out. If this is an older DLP this is most likely the cause. You can get a replacement at www.laptopsforless.com part number BP96-00224J for $151. If the tv is still under warranty, I would have them do it, otherwise replace it yourself. If so here is a link to give you step by step instruction. Please give me a good rating. ;-)
Dec 18, 2007 | Samsung HLN567W 56" Rear Projection HDTV
My 60" lcd projection tv wont turn on sometimes and throws a lamp light, and if i watch tv for a while and turn it off it wont turn back on and throws the red lamp light
The buzzing sound you most likely hear is the ballast trying to fire up the lamp. I would say replace the lamp and yes they can act up at will. If this is the first lamp replacement ever then you are doing good.
Feb 01, 2007 | Hitachi 60V500 60" Rear Projection...
RCA HD52W56 52" Rear Projection HDTV Logo
50 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
