Question about RCA TruFlat 27F520T 27" TV
T.V. VEIWING PROBLEMS
IT RAINED AND THERE WAS A LEAK IN THE ROOF THAT I DID NOT KNOWABOUT. THE RAIN GOT INTO THE T.V. AND ON THE OUTLET CORD IT'S STILLCOMES ON BUT THE SCREEN IS FUSSY AND IT KEEPS GOING ON AND OFF. wHATCOULD BE THE PROBLEM AND SHOULD I CALL A REPAIR PERSON?
  • 65 Answers
Disarm it and dry it with a hair dryer. if you don't plug it wet, maybe you have luck.     and good luck
Posted on Oct 13, 2007
How do i find drain holes maybe be blocked leaks whenrains
Check the bottom corners, one of them has a white rubber hose coming from the unit and may only be patruding out a little or you may need to look from close to the roof level to see it. Run a flexible wire, say #14 THHN into it about a foot to 18" and rotate it as you push it through. You should see debris and water coming out when its cleared. Yes, splashed rain can contribute to the full collector tray and leak through the duct, and so will a bad roof gasket that is between the roof and the unit. If you still have a rain leak after the tube is clear, then change the roof gasket. Good Luck!
Oct 15, 2014 | Dometic Rooftop RV Air Conditioner
How do you locate roof drain in a three story apartment
I presume you own this building. By "roof drain" do you mean that the building has a flat roof with drains for rain, or are you saying that rain is coming down through an electrical conduit?
Oct 03, 2013 | Plumbing
Leak in front footwell when it rains hard
I would have the windshield resealed first.
Oct 08, 2012 | 2006 Seat Ibiza 1.4
Roof a/c leaks when it rains, whats the best way t...
check cover for leaks and tighten gasket or replace
May 21, 2010 | Dometic Rooftop RV Air Conditioner
Rain water leaks from overhead console (No sunroof)
common problem with these roof racks check for loose bolts holding it on also there are inserts pressed into your roof under the roof rack these threaded insrts tend to come loose or get pulled out use silocone sealant around every bolt and insert.
Sep 19, 2009 | 2001 Jeep Grand Cherokee
2003 Hummer H2 Roof leak fron celing map lights
i had the same probmlem its coming from one of 3 lights is the center quick fix was to use clear silicon from wal mart .. also it can leak from the moulding near the corners of the windsheald but rare...
Aug 08, 2009 | 2003 Hummer H2
1999 Saturn SL Sun Roof Leaks when it rains
Great solution: Use a 8 foot length of weed eater plastic "blade". You can get a small amount from a hardware supply store. While twisting the strand, insert it into your drains that are located in the corners of your open sunroof hole. Feed the plastic thru the tubing... don't force it, use gentle pressure. Test with a bit of water and look under the car for drainage.
Jun 06, 2009 | 1999 Saturn SL
RCA TruFlat  27F520T 27" TV Logo
42 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
