Question about Car Audio & Video
Thermostat, where is it? Easy to replace?
My grandfathers buick park avenue keeps overheating. It's just an extra car so he doesn't want to take it to a shop. Where's the thermostat located? Any tips to replacing it?
  • oncetwice3ti May 11, 2009
    Thanks..I'll go check it out for him!!
    Problem Solver:
  • 19 Answers
It should be on the intake manifold, should also have a water hose running into it coming from the radiator, remove the hose from intake manifold and the thermostat should be right there
Posted on May 11, 2009
My 2002 buick park avenue ultra supercharged is overheating. Replaced water pump and radiator. The thermostat seems to open up. Tested spark plugs so I dont think its a head gasket issue. Any ideas?
I don't know what else would cause this overheat with the new parts you have installed other than a leaking (combustion gases getting into cooling system) head gasket
Sep 23, 2016 | Buick Park Avenue Cars & Trucks
What would make a 2000 buick park avenue over heat and shut off
over heating is from ---low coolant level--blocked radiator cores--fins missing from radiator cores--thermostat not opening--coolant temperature sensor not operating the cooling fan-- driving to fast and not engaging over drive ---if the fan is mechanical and there is a viscous fan hub then the hub is faulty ( overheating at lights but cools down on moving)-- faulty radiator cap--- air in cooling system--run fault codes to check for problems with mixture and timing---low tyre pressures at speed ---over loading--pulling a heavy trailer ---hilly conditions
Perhaps some where in that list you will find an answer to your question
Aug 20, 2014 | 2000 Buick Park Avenue
Overheating
You need to have the thermostat checked. if it's not the thermostat, its your heater core.
Jan 17, 2013 | 1991 Buick Park Avenue
How do I replace a thermostat in a 2000 buick park ave
drain radiator remove hose remove two bolt on thermostat houseing clean place new thermostat in copper side with spring down in hole revers steps
Jan 17, 2013 | 2000 Buick Park Avenue
My temp gets hot but my car doesnt seem to be overheating what could it be its a 2000 buick park avenue
Here's a link to the coolant temp. switch,could be bad,its near the thermostat cover.Here's how to remove.
Dec 04, 2012 | 2000 Buick Park Avenue
How to change a voltage regulator for 95 Buick Park Avenue
The voltage regulator is built in to the alternator. It's better to replace the whole alternator then to just replace the regulator. The regulator and other parts like the bearing all have about the same amount of life time, unless the battery is weak which can put extra taxes on the regulator. Good luck and hope this helps.
Nov 03, 2009 | 1995 Buick Park Avenue
1997 buick park avenue does the odometer turn over
you can reset these odometers and it will go back to 0 after 999,999 miles but if you find a car running after that many miles id be highly surprised anywy the procedure isnt easy and it carries high penalties , most individual car sellers cant do it and most large dealers wont because of the illegalities involved
Aug 31, 2009 | 1997 Buick Park Avenue
95 Park Avenue blows cold air.
Yes it is easy to get to. should be where the top radiator hose connects to the radiator housing . Housing is bolted to the engine. Two bolts, thermostat sits under this.
Jan 16, 2009 | 1995 Buick Park Avenue
Car Audio & Video Logo
121 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
