Question about Siemens Gigaset 2420 Cordless Phone
Sticky keypad on cordless sets
My Siemens Gigset 2420 is about 3 years old and the handset button pad gets very sticky, meaning I have to use force to press the buttons to get the number punched out and sometimes I have to press 5, 6 or 7 times to get the expected result.  Any help to bring it back to the previous original position?
Thank you...Mathew at
  • Anonymous Jan 14, 2009
    I have the same problem as Matthew. Siemens sticky keys on our telephones.
  • 106 Answers
Hi Mathew, After a few years, they all collect moisture under the pads. This goes for almost every cordless phone I have opened, regardless of the model. Normally, I can tell how much gunk is under the pad before I open the phone. If they are filthy on the outside, they are normally filthy on the inside, and the dirt and moisture migrate under and over the dialing pad, and all over the circuit board, it gets real nasty. Not saying your phones are filthy, but that is what I observed after opening thousands of them. Once it gets moist under the pad they grind the conductive rubber to a pulp, the harder you push the more it destroys the pad. Unfortunately, in your particular case, that model is nearly impossible to open without damaging it. It has no screws, but there are many plastic tabs holding it together, and if you pry in the wrong spot, in the wrong manner, and break one tab, the phone is ruined and you will have audio problems (plus just cleaning the buttons will only fix it for a very short period) if by some miracle you get it open and closed without breaking the tabs. The plastic is not just for looks, its condition can effect the operation of the phones audio. I wish I had a do it yourself answer for you, but in this particular case the only solution I can recommend is finding a experienced Siemens cordless repair facility. Good Luck
Posted on Jan 11, 2008
My Samsung punch is turning off automatically even if its in full battery.. when i press a keypad, it will now turn on... hope to have a solution.. it is greatly appreciated.. thank you so much..
Welcome to FixYa!
It is most likely that you have a sticky keypad or the metal switch pad underneath the keypad of the power button is broken.
What you can do is to clean the inside of the keypad and check if there are broken metal switch pad underneath the key pad that results to sticky keys. You will need a special cell phone star screw driver to open the front panel of a samsung which will expose the key pad and the switch pad underneath. Unscrew all the screws at the back of your samsung phone and gently lift the front cover.
It is also possible that the problem might be in the software installed on your samsung. In this case, you will need to bring it to a repair center since it requires special software for re-installation and a hardware. Samsung cell phones cannot be re-installed through a USB plug and play.
Thank you for using FixYa. Have a great day. Jas247
May 19, 2011 | Cell Phones
Sticky i key
Sticky isn't a really good description but i'll guess that you mean that you have to press it hard.
Under each key is a foam pad that makes contact. The foam gets old and crumbles, the pads can be replaced but generally not by the user.
Mar 07, 2011 | Brother EM-430 Typewriter
Siemens gigaset 2420. how do i reset pin on desktop base corded station?
  1. I forgot the PIN number on my Gigaset 2XXX system base station. What can I do?
    Please complete the following steps to reset the system PIN on 2XXX back to 0000. On the system base station:
  • Press MENU.
  • Scroll to SYSTEM SETTINGS but do not press SELECT.
  • On the keypad, enter *65# (Star, 6, 5, Pound).
  • It will display "SYSTEM PIN RESET" and return to the idle screen.
  • Note: The base station system PIN will be reset to 0000
  1. I forgot the PIN number on my Gigaset 2XXX cordless handset. What can I do?
    Please complete the following steps to reset the cordless handset PIN on the 2XXX back to 0000.
  • Press MENU.
  • Scroll to MOBILE SETTINGS and press SELECT.
  • Scroll to LOCAL SETTINGS and press SELECT.
  • Scroll to CHANGE PIN and press SELECT.
  • Note: The handset PIN will be reset to 0000
Jan 05, 2010 | Siemens Gigaset 2420 Cordless Phone
27998GE6-C phone and buttons stick
The buttons got "sticky stuff" on the conductor pads. There is not much you can do unless you open the handset which I do not recommend unless you really know what you are doing.
If you do, or, are foolish or brave, open the handset, remove the rubber button pad and wipe the circuit board with rubbing alcohol. DO NOT USE ANY OTHER SOLVENTS.
Good luck.
Mar 16, 2009 | GE 27992GE5 Cordless Phone
Uniden DECT2080 - the Key - square key wont' work at all
After cracked open the handset, I am pretty sure most of problem is not circuit issue. It's the sticky pad somehow aged. I put a small piece of aluminum foil between the rubber key pad and inner plastic conductive pad, and fixed it. No glue needed so far.
Jan 21, 2009 | Uniden DECT2080-2 Twin Cordless Phone
System pin # reset
There is a way to override and reset... I think you need to press *67# when in the system pin area via menu. Confirm this first though. There is a way to do this though- then you reset it to 0000- google it and you will find the answer-
Dec 01, 2008 | Siemens Gigaset 2420 Phone
Siemens 8825 gigset 2 line phone
If your system was working fine, and it all of a sudden started doing this, it sounds like your base has taken a surge of some kind. Your base needs replacing. You can try re-registering the handsets, but from my experience the problem is fatal. Now if this is a new installation and the handsets never work yet on the base, you just need to register them. You can download the manuals or get tech tips at Siemens website, gigaset FAQ pages.
Sep 04, 2007 | Siemens Gigaset 8825 Cordless Phone
Siemens Phone
I just replied to a similar post. This is a common problem, not only with the Siemens but most all manufacturers that used this design of display on many different devices. And in this case, the display connections are pressed on with a special machine and can't be replaced by a do it yourselfer. Sorry I can only recommend sending it in for repair.
Aug 21, 2007 | Siemens Gigaset 2420 Cordless Phone
Siemens Gigaset 2420 Cordless Phone Logo
524 people viewed this question
Top Siemens Lands Phones Experts
Greg Cann
Greg Cann
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
