Balance - Blue Screen during shut down stop error 0X0000007E
I have a Balance computer - model CP2401 with an 845GV-M2 motherboard. When I'm shutting down my computer gives me a blue screen with a stop error: ***STOP:0X0000007E (0XC0000005, 0XF7A769AC, 0XF7B9D9B4,0XF7B9D6B0) The next line down says: ***kbdclass.sys - Address F7A769AC base at F7A76000, DateStamp 48025372 Can you tell me what this means and what I need to do to fix it?
    Problem Solver:
  • 9 Answers
Check your hardware settings it could be the codes for the hardware that cannot recognize of your systems. it could be change with the wrong specs. if you cannor configure it out. you better set the bios configuration to default setting and try to repair the system using your operating system cd installer. thanks
Posted on May 11, 2009
Aspire One netbook BSoD
Those error codes don't really mean very much to the general consumer, but blue screens of deaths are caused by bad RAM memory in your computer, not viruses. I'm going to take a guess that your computer is either several years old and/or it constantly get quite warm? Heat can shorten the life of computer components by quite a bit. You may need to get one of your RAM cards replaced to solve this issue.
There's a free program called Memtest86 that you can run to determine if this is the case. It will scan all your memory and look for bad sectors. You can download it here: http://www.memtest86.com/ and burn it to a CD. What it does is create a bootable CD that will execute the program as the computer turns on to scan all the memory. There are full instructions on their website. The process can take an hour or two depending on how much memory your computer has, and if it turns up any bad sectors then you know what your problem is.
A computer can run with bad sectors in the memory, but it makes it unstable that it will keep bluescreening, so if you have bad sectors in your memory it might be better just to replace the RAM. Luckily, this isn't too expensive. For instance, if your computer has 4GB of memory, it probably has 2 2GB RAM cards installed. You can get a 2GB replacement notebook memory for, I'd say $30 or $40. Installing RAM is very simple, and if you're willing to install it yourself, it won't cost you more than that.
Dec 06, 2012 | Acer Aspire One Netbook 8.9" Notebook
I keep getting this stop error after Windows loads?!
Seriously, contact Toshiba Tech Support. Give them the information you put up here. If you need to you can use a PC in the local library, or a friend's PC, to contact them. Or, just call them on the phone.
Have you tried going into Safe Mode?
-a.
Jun 23, 2012 | Toshiba Computers & Internet
My computer shut down when I play a game,i have a mcp6p-m2 motherboard,when i play a game after 10 -15 min the computer shuts down...
Can you please tell me only shutdown when you play game.
There is some problem with Windows operating system.
  • you reinstall your windows.Problem will be solve.
Mar 08, 2010 | Biostar MCP6P-M2 Motherboard - v6.0,...
My laptop has come up with a blue error screen and will not let me in. The screen says "A problem has been detected and windows has been shut down to prevent damage to your computer.... Technical...
Don't give up try booting into SAFE MODE press F8 at bootup and choose safe mode, with networking. Then at least you can troubleshoot what is wrong, it is often a bad Video driver. It may require reinstalling or updating, or some other driver that is giving you this BSOD.
Feb 01, 2010 | Computers & Internet
How do i fix blue scree error tha reads stop:0x0000007E
is this a recurring problem. There isn't much you can do, usually a software crash causes this,
maybe defrag the computer, uninstall any unneccary software, run a virus scan, etc. Sometimes it just happens, if it happening all the time, there maybe a hardware problem, or you may need to restore to factory settings.
Jan 06, 2010 | Dell Dimension E310 PC Desktop
Error code Stop: 0x0000007E
General Memory dump failure, least thats what I kinda get from the Error that you have displayed. This actually happens for quite a few reasons. Over heating, video graphics error, CPU failure (over heating), or something wrong with a prime system failure in a file. Most of time time on labtops it would be with the overheating, or not enough ram to run the processes that are active. Use Msconfig and under the startup tab turn off what you not need during start up. Also make sure you have the Labtop mounted and the legs are down, letting air access to the bottom of it to help with cooling. Also on the back and sides there should be exhaust vents, used compressed air to clean them out and make sure nothing is restricting them.
DrakeTech
Dec 29, 2009 | Sony VAIO VGN-NR160ET Notebook
Error code
Apparently the XP Pro CD you are using is pre-SP2, thus causing the error. With XP RTM and SP1, you need to supply the proper SATA drivers for the chipset on the motherboard since there is no built-in support for SATA drives. You can download the drivers from http://www.ecs.com.tw/ECSWebSite/Downloads/DownloadFile.aspx?catid=1&driverid=2214&areaid=2&LanID=0
During the XP setup you will need to press F6 to install these driver before attempting to copy the XP files to the drive. Or you could make a custom XP CD using the directions at http://maxeasyguide.blogspot.com/2008/04/preparations-for-winxp-installation-cd.html that has these SATA drivers already slipstreamed into the installation procedure.
Or if you know someone who has the WinXP Pro SP2 CD, you could borrow that for the install.
Apr 07, 2009 | Foxconn (945G7MA-8KS2) Motherboard
Computers & Internet Logo
511 people viewed this question
David Payne
David Payne
