Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
I have install rhce 4.0 server( linux) i want to access the internet.
Pls provide steps for making a internet conection
also provide how i can  install printer ( i have hp all in one printer )
  • 188 Answers
To make a connection go to controle panal..>internet option>and follow the instruction carefully...
to install printer-----------------------
plugin ur printer to u r computer-   new hardware found massage appears..>now insert u r printer cd (which come with printer) to install printer driver...>select automatic instollation of driver for  u r printer......................
i m sure u r problem will be solved..
dont forget to tell me u r problem solved or not
best regards & best of luck..
even u can mail me at my mailing add-
Posted on Oct 13, 2007
    SHIVAJI YADAV Nov 06, 2007
    hey dude.....u did not make any repley....for u r problem solution ...
    hope it is solved.......
    Was this solution helpful? Show your Appreciation by rating it:
What version of Linux runs on DL580 G4?
Minimum Supported Red Hat Updates •Red Hat Enterprise Linux 5 Update 1 •Red Hat Enterprise Linux 4 Update 5 6-Core/4-Core Intel Xeon Processor 7400 Series •Red Hat Enterprise Linux 5.22 •Red Hat Enterprise Linux 4.7 Minimum Supported Novell Service Packs•SUSE LINUX Enterprise Server 10 SP1•SUSE LINUX Enterprise Server 9 SP31 6-Core/4-Core Intel Xeon Processor 7400 Series •SUSE LINUX Enterprise Server 10 SP23 •SUSE LINUX Enterprise Server 9 SP44
Nov 28, 2012 | HP Compaq ProLiant DL580 G4 (430811001)...
Set up a home office LAN which access internet through USB wireless gadget
The following networking job I have done in this Lab. It is enough for a small office to access or transfer file Printing and access of shared Internet in different type of operating system.
We have recently set up a home office (small laboratory) LAN. All the computers access the internet through a USB wireless (CMDA) dongle. The USB stick is Huawei EC168C and internet service provider is Reliance Infocom (India). But any USB internet dongle can be use to share internet in a LAN in the following way. And you don't need a router for that. In the areas where ISP cannot give wire line internet connection this type of USB wireless sticks are really helpful for home office.
Basic LAN Connection:
Here this lab has 4 PCs. One Windows XP, another Windows Vista starter and two RedHat Linux server systems. Here in this lab I have done the basic LAN connection using cat5 cable & RJ45 connector and an 8 port hub. I have connect the two windows based OS. Using cross cable I have connected two windows system with the hub. Then I put static IP address in Ipv4 of TCP/IP. After that I set workgroup name to join in a workgroup in windows PCs. Then I tried to ping the systems, and it was pinging. Then I have setup a home or small office network in both windows system. That I have enabled the Printer sharing. After that I can share file, data and printer through the system gateway.
Now I have to connect other two Linux PCs in this network. With same cross cable I have joined the both Linux system with the hub. Then to detect the Ethernet device I have put down "DEVICE=eth0" entry in /etc/sysconfig/network-scripts/ifcfg-eth0 file. Then I set IP address in Ethernet device in network configuration in graphical mode (or System-config-network in text mode).After doing this job I restart the network service with "service network restart" command. Then I am trying to ping the systems to one another, And It was pinging.
Now Linux system can access with each other and files also shared through SSH, Telnet,FTP using process and command.
Linux Configuration:
I have configured the Linux system in the following way. First I have set the host name in /etc/sysconfig/network file by VI editor. Next I have edit /etc/sysconfig/network-scripts/ifcfg-eth0 file with "Device=eth0" to detect the Ethernet device. After that I have put the IP add in network configuration file and Restart the network service. To keep the eth0 on permanently I also use the chkconfig command.
After doing this job File sharing can be possible through network file sharing (Nfs). I have install Nfs package & shared the nfs dir by editing exports file. Then I am trying to automount the NFS dir by automounting process. So that I put automounting entry of nfs file in fstab file. After that it's automounted in other system's mount location.
Windows & Linux Networking:
Through basic LAN both OS can only ping each other. To share file or data samba server (a client server in Linux) must be configured in Linux system. So I Install smb rpm package from yum repository. Then I have Configure the samba/smb.conf file. I put the Workgroup name on Workgroup column of samba/smb.conf file. Then I Set the network IP without host to route in network in Host allow column. At last I put down all details of Samba dir, users at the end of the configuration file set the samba password. After that I restart the samba demon to up the samba server. Now files can shared through samba server. In windows I Set the workgroup name pairs with samba server and also set username and password same as samba server. Now I trying to send or access file through samba in both OS and it happened.
USB Net Connect:
Here in this lab workers are use internet from an Usb net connect. So it must be shared in Network. It is too fast so shared internet can be access easily. In Windows XP system I connect the USB netconnect & share it in network. IF all the network setting is ok then all the systems can access shared internet through gateway. Here all users use this shared internet now.
Access of Another System:
VNC Server & Viewer is software through which we can access of another system easily. I just install the software & set the password. Then I run the vnc server. After that I Put the IP add of vncserver from vncviewer of another system and type the password & start access the vnc server system. It can be access form WAN also. I just Run the Vnc server and connect the internet and I got a Wan IP add provided by ISP.
on Jan 12, 2011 | Network Computing Devices (NSH800S/A)...
How to install linux operating system
A free software operating system based on Linux was created and it was named Ubuntu. It offers all services needed by ISPs, mail servers, DNS servers, FTP servers, MySQL servers, POP3/POP3s/IMAP/IMAPs, Quota, and Firewalls. Red hat, Apache and Ubuntu are Linux software distributors. Ubuntu is widely used because it is free and you don't have to pay any licensing fee. Updates are also available for free and accessible online.
To install Ubuntu Linux software you can use the program "Wubi."
The first thing to do is to download Wubi to your desktop and then run the executable program. Then choose the drive in your computer where you want your installation to go. Wubi will place a file on your local drive. It will use this drive as a virtual hard drive. Most often the C drive is used for this purpose. Choose a bigger installation size to allow installation of other programs and storage of data. Choose your language. Type in your username and then your password for security reasons and for your installation to proceed. You will use this for logging on to your computer, installing programs and making changes to the system. Once you click "Install" Wubi will start to download the installation files. When the installation files have completely been downloaded, you have to reboot. Restart your computer. You'll see on your screen a prompt that asks you to select the operating system that you like-whether you like to boot Ubuntu or Windows. Choose Ubuntu. This will complete the installation of your Ubuntu Linux OS. Another way of installing the Ubuntu Linux software is by using:
An Ubuntu CD installer An Internet connection Everything you need to install Linux comes in one CD that provides a complete working environment. You can get the additional software you will need online for your installation. The available graphical installer makes installation easy and quick. Your computer will have Internet, drawing and graphics applications, and games after Linux has been installed.
Now your computer is ready to work to the max. You'll have it functioning the way you want it and enjoy its features as well. Working on a computer is as much fun as it is functional. You can now browse for information you need, play a variety of games and even listen to your favorite music and watch some videos.
Hope this helps, if so do rate the solution
Jan 16, 2011 | Red Hat Enterprise Linux ES Basic Edition
How to configure Remote access/VPN server role (using windows as my operating system)?
You can configure a server that allows remote users to access resources on your private network over dial-up or virtual private network (VPN) connections. This type of server is called a remote access/VPN server. Remote access/VPN servers can also provide network address translation (NAT). With NAT, the computers on your private network can share a single connection to the Internet. You can find a step by step guide here:
Aug 15, 2010 | Belkin Computers & Internet
How to get job in "Linux administration" ?
Register with Sites Like Monster Jobs and search for jobs there. There are plenty of Jobs available for RHCE and RHCT profiles.
If you can let me know your country or region then I would be able to give you a more clear picture of where to look,etc..
Best Regards NextDoorNerd
Jul 29, 2010 | Red Hat Enterprise Linux ES 3 Standard...
Internet Bandwidth problem
try and get install polipo
it may solve ur promblem
Jun 17, 2008 | Computers & Internet
Linux server
Please refer to Linux Administrator guide. The process is not writable in short space. Pls add more dependencies like hardware etc
Jun 05, 2008 | Computers & Internet
Firewall is not configered is linux centos
try and go for it..all d best...
Use yum command as follows:
# yum install squid
Loading "installonlyn" plugin Setting up Install Process Setting up repositories Reading repository metadata in from local files Parsing package install arguments Resolving Dependencies --> Populating transaction set with selected packages. Please wait. ---> Package squid.i386 7:2.6.STABLE6-4.el5 set to be updated --> Running transaction check Dependencies Resolved ============================================================================= Package Arch Version Repository Size ============================================================================= Installing: squid i386 7:2.6.STABLE6-4.el5 updates 1.2 M Transaction Summary ============================================================================= Install 1 Package(s) Update 0 Package(s) Remove 0 Package(s) Total download size: 1.2 M Is this ok [y/N]: y Downloading Packages: Running Transaction Test Finished Transaction Test Transaction Test Succeeded Running Transaction Installing: squid ######################### [1/1] Installed: squid.i386 7:2.6.STABLE6-4.el5 Complete! Squid Basic Configuration Squid configuration file located at /etc/squid/squid.conf. Open file using a text editor:
# vi /etc/squid/squid.conf
At least you need to define ACL (access control list) to work with squid. The defaults port is TCP 3128. Following example ACL allowing access from your local networks and Make sure you adapt to list your internal IP networks from where browsing should be allowed:
acl our_networks src
http_access allow our_networks
Save and close the file. Start squid proxy server:
# chkconfig squid on
# /etc/init.d/squid start
init_cache_dir /var/spool/squid... Starting squid: . [ OK ] Verify port 3128 is open:
# netstat -tulpn | grep 3128
tcp 0 0* LISTEN 20653/(squid) Open TCP port 3128 Finally make sure iptables is allowing to access squid proxy server. Just open /etc/sysconfig/iptables file:
# vi /etc/sysconfig/iptables
Append configuration:
-A RH-Firewall-1-INPUT -m state --state NEW,ESTABLISHED,RELATED -m tcp -p tcp --dport 3128 -j ACCEPT
Restart iptables based firewall:
# /etc/init.d/iptables restart
Flushing firewall rules: [ OK ] Setting chains to policy ACCEPT: filter [ OK ] Unloading iptables modules: [ OK ] Applying iptables firewall rules: [ OK ] Loading additional iptables modules: ip_conntrack_netbios_n[ OK ] Client configuration Open a webbrowser > Tools > Internet option > Network settings > and setup Squid server IP address and port # 3128.
See also You may find our previous squid tips useful:
Nov 26, 2007 | Computers & Internet
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
53 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
