Question about Garmin Forerunner 305 GPS Receiver
Seems like a loose connection? Have re set and loaded software again.
Shuts off all the time, hard to get back on, trouble finding satellite
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 84 Answers
My wife's did the same thing. There was a connection inside that wasn't making contact. There are no screws holding the unit together. I used a exacto blade to very carefully pry the unit apart along the side seam. It's not easy to do. Be very cautious and gental. Work the thickness of the blade into the joint to gently wedge apart. You are not trying to remove material! Once apart you will see some fingers that make a connection between the upper and lower part of the watch. This is where the problem was with my wife's 305. I gently raised these tabs to make a better connection and used automotive silicone and tape to hold the unit together . Once the silicone was dry I removed the tape. It's been working ever since. I didn't try it before but try pressing very hard on the unit where it says Forerunner 305. The case is very hard so it might not work. But if it powers up when pushing you found your problem. Hope this helps.
Posted on Jun 08, 2009
My laptop shuts down randomly
Tell them to give you a NEW computer. You got a lemon. They WILL give you a new one if you've had this much trouble with it. I'm serious, they do it all the time on lemons. Be assertive! They will cave.
Jun 29, 2012 | Dell Computers & Internet
Nuvi 660 cannot acquire sattelites
do a proper reset like take the battery out if its optional then press the power button for 30 seconds without connecting the power,if that doent help then you need to reset the software to the factory setting thorugh the menu itself.
Jul 04, 2008 | GPS
Toshiba Satellite P25-S5093 screen/boot problem
the memory cards are loose or are dirty and need the contacts cleaned with pencil eraser.
when the memory cards lose connection you lose video on screen.
Jun 18, 2010 | Toshiba Satellite P25-S5093 Notebook
I see yahoo 10 messenger has a problem when i try to open my e-mail it says windows is haveing trouble with loading also with getting into the chat rooms that windows shuts off most of the time
Yahoo products like messenger and mail, rely its connection through windows Internet Explorer. If you are currently experiencing trouble loading this browser, chances are your yahoo messenger will not work completely.
The best thing to do is upgrade the Internet Explorer to version 8, compatible to the operating system of your computer. After that, uninstall your yahoo messenger 10 and reinstall again. Restart your computer.
The nest time you try to sign in, it will take you only seconds and will never experience loosing connection again.
You may also refer to a helpful tips on solving " can't sign-in problem " with yahoo messenger.
Please give me a good rating when you have successfully restored to connection of your YM.
Thank you for using Fixya.
Jun 09, 2010 | Yahoo Messenger
No Audio Output Device is installed
I would try a system restore. Did you down load something since then? Hopefully you have a restore point set?
click start-->all programs-->accessories-->system tools-->system restore. (this will set everything to default,if you made any changes.)
If it is a hard ware issue you will know if this solution does not work. Then I would uninstall the drivers then reinstall. If you have access to the internet you might find the any necessary software online.
If this still does not work seems the speakers are bad.
Feb 15, 2010 | Toshiba Satellite A205-S4607 Notebook PC
Toshiba Laptop is having trouble booting up.
hi,
Please reinstall vista once.If the issue is not fixed this seems an issue with HDD
Jul 14, 2009 | Computers & Internet
Garmin 60CSx - Cant find satellites
Try a re-load of the chipset driver. It is available from the Garmin website. I find that it occasionally becomes corrupt.
You can check by entering the "Main Menu" then "Setup" then "System" then press Menu and choose "Software Version".
If the "GPS SW Version" is 0.00 then a reload of the chipset driver will correct the problem.
Cheers.
Dec 29, 2007 | Garmin GPSMAP 60CSx
Load a new hard drive
Hi Dutshy1,
On back of the hard drive did you move the jump on your main hard drive and set it to Master and your secondary hard drive set to Slave.
Where the jumper is suppose to go is printed on the sticker on top of your hard drive.
The jumper is the little plastic thing on the back of the hard drive connecting two pins together next to the power port and where the IDE cable is suppose to connect.
let me know if that works.
-Daniel
Nov 06, 2007 | EliteGroup 661FX-M Motherboard
Satellite cannot locate my Magellan 700 - Please Help
All zeros ehh? nice.. :) I'm not sure that having that wire that was "loose" solderd on was a good idea. Pretty sure your talkin about the RF cable from the main board to you I/O card (the card with the power connections). this cable isn't supposed to be soldered on, although I don't see what it could hurt as long as the connection was good before the solder cooled. If you open the unit up.. (again) and take out the I/O card (power card) . Look on the back of that circuit card and make sure that there are three small ICs' in a row at the position that sits in the outter beveled part of the back cover. I know this is hard to explain, but basically, if your missing an IC chip and you can't find it, then there's no hope.. look at some of my other posts and try various software resets. if you find the small IC chip I'm talking about (somehow) then call that professional solderer guy back. Let me know. -Daniel
Apr 16, 2007 | Magellan RoadMate 700 GPS Receiver
Garmin Forerunner 305 GPS Receiver Logo
208 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
