Question about Epson TM U210PD Matrix Label Printer
Epson U210PD printer ribbon is shredding and jamming in the machine. Could this be anything other than a pin head problem?
  • thermalrolls May 11, 2009
    I believe it has been installed correctly as they are changed by the same person regularly without problem. My initial thoughts was it could be an issue with a faulty pin and thank you for your advice re pin proximity to the ribbon.
    Genius:
  • 1,447 Answers
Hi
Have you tried reseating the ribbon for the printer? chances are its not installedcorrectly. other factor as well is that the pins are to close to the ribbon and for you to adjust the lever you have to bring it to an epson certified servicer. call epson for authorized service center for this type of printer.
Posted on May 11, 2009
Dot matrix printer head not properle work head jam problem
check
1- ribbon quality ( it might damaged )
2-Printhead gap - adjust the gap with the scaled arm aside the numbers related to the past thinketh ( no of copies)
3-ribbon mask ( metal plate in front of printhead - might be damaged)
Nov 06, 2014 | Epson LQ-2090 Matrix Printer
My DFX 8000 Printer head is moving, but it is not printing, ribbon and head is OK. i change the head and ribbon but problem is same.
Thanks, I Try it. but it is still not printing, because printer head pins
are not coming to the paper. Head pins printing sound is coming.
thanks
Aug 13, 2013 | Epson DFX 8000 Matrix Printer
Printer head of fx 2175 one side jam making noice
The printer may need a service.
Dirt and grime on the print bar causes the head carriage to jam
It may also be caused by:
Damaged Gears
Faulty Form Starter Sensor
Snagged Ribbon
But i would start by just cleaning the bar thoroughly
Do note that cleaning the bar is just a temporary solution
The machine needs to be stripped and the bushes and all parts needs to be cleaned.
Do not attempt this if you dont have experience in this
Feb 14, 2011 | Epson FX 2170 Matrix Printer
Hi I work in a restaurant and we have a Epson TM-U220A Model M188A printer. The last few days the printer has not been printing on the White receipt paper. We've tried replacing the ink and it doesn't do...
If this is the thermal head model, you will need to have the print head replaced. These were also sold under the Dell label, so finding a used replacement printer may be more economical. If it takes ribbons, you will need:
Ribbons
This printer needs a ribbon cassette to print receipts.
EPSON ribbon cassette, ERC-38 (B) (Life: 3,000,000 characters / Color: Black) EPSON ribbon cassette, ERC-38 (P) (Life: 4,000,000 characters / Color: Purple) EPSON ribbon cassette, ERC-38 (B/R) (Life: 1,500,000 characters / Color: Black)
(Life: 750,000 characters / Color: Red)
You can order replacement parts here: http://www.umd.com.au/itd/products/spareparts_epson.html
Thanks
Jan 08, 2011 | Epson TM-U220 Matrix Printer
IM HAVING DIFFICULTY REMOVING THE INK CARTRIDGE FROM MY EPSON LX-300+II, THE RIBBON MUST BE JAMMED ON TO THE PRINT HEAD
first pls remove the power cable after >Open the top plastic lid. > Slide the printer head to the middle of the printer. > Pull the printer cartridge up and out evenly.
Feb 22, 2010 | Epson LX-300 Matrix Printer
I have an Epson LX-300 dot matrix. The problem is the print is smudged/with black lines patches along the printed matter. The ribbon mask is lost. I'm curious to know the purpose of this ribbon mask. Does...
The mask stops this sort of problem and the print head could do with cleaning so that the pins don’t get stuck. The ink coagulates over the years and causes the pins to jam and eventually tear up ribbons of just burn up the driver coils in the head assembly. The head face needs cleaning with a cotton bud or two or three with isopropyl alcohol to remove all the ink residue from the pins and shafts. If you can remove the head assembly this is much easier to do.
Oct 30, 2009 | Epson LX-300 Matrix Printer
Needed winxpdriver tm-u210pd
reinstall its driver from its disk or epsons site
Dec 17, 2008 | Epson TM U210PD Matrix Label Printer
Ribbon jam
i get the error RIBBON JAM anytime i try to print,even though i have changed the ribbon.Dan
Sep 11, 2008 | Epson DFX-9000 Matrix Printer
Problem with my Epson Dot Matrix printer
Chances are, you didn't installed the ribbon correctly...
A. Open the printer cover
B. Use a pin to guide the ribbon between the print head and the ribbon guide, then turn the ribbon tightening knob to help feed the ribbon into place, it shouldn't be twisted or creased.
C. Slide the print head from side to side to make sure it moves smoothly
Feb 21, 2008 | Epson LX-300 Matrix Printer
Epson TM U210PD Matrix Label Printer Logo
232 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
